Old 07-29-2018, 10:11 PM   #1
tow rig
Drop hangers for 1970 GMC C2500.
I am having trouble finding a drop leaf spring hanger for my 1970 3/4 ton pickup. It has the HD rear leaf springs. They are the same 2.25 inches wide as the standard & C10 springs. There must be at least 5 different manufacturers making drop hangers for the 73-87 trucks. Does nobody make a version for the narrower leaf 67-72? (I am looking for a 4" drop in the rear, and do not want to notch the frame.) I have drop shackles and a set of "pancake" bump stops. The cab and bed are off of the frame. Does any one know where to get the drop hangers that I need?
tow rig is offline   Reply With Quote
Old 07-30-2018, 08:32 AM   #2
Mike C
Mike C's Avatar
Re: Drop hangers for 1970 GMC C2500.
Crown suspension:
http://www.crownsuspension.com/lower....25-wide-leaf/
DJM at Speedway motors (I have a DJM flip kit on back of my '69. ECE front setup)
https://www.speedwaymotors.com/DJM-S...op,351294.html
Summit has Classic Performance shackles:
https://www.summitracing.com/parts/c...up?prefilter=1
There are others as well. Western Chassis, McGaugheys, CPP I think all make shackles as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-30-2018, 09:27 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
www.earlyclassic.com also sells them
Keith
Convert to disc brakes.
Old 07-30-2018, 09:40 AM   #4
BlueBoy72
Active Member
Check these out at www.x2industries .com
Part number HNG-CHVC132 $175.95.
BlueBoy72 is offline   Reply With Quote
Old 07-30-2018, 12:31 PM   #5
tow rig
Thanks Blue Boy. That looks like what I need. Ordered a set today. I don't know why they chose to call them C10 hangers (C10 trucks have coils in the rear.) I think they could sell a few more, if they knew what to call them.
Old 07-30-2018, 12:42 PM   #6
lolife99
lolife99's Avatar
Not all C10 trucks were coil spring in the rear.
GMC trucks had more than Chevrolet,... but you could get them in both.
Keith
Old 03-30-2026, 11:32 AM   #7
s102000
I know this is an older thread but I can't find these drop hangers on the x2industries site. I've got a 1969 GMC with leaf springs and I'm wanting to find these drop hangers. The 73 to 87 are all over the web, and I'm wondering if these 73 to 87 would work. The mounting holes may be different but I'm willing to drill new holes if needed.
Thanks.
s102000 is offline   Reply With Quote
Old 03-31-2026, 03:32 PM   #8
SCOTI
SCOTI's Avatar
Thanks.
Spring widths were different (67-72 vs 73-87 leafs) for the half-ton trucks. What width are your leafs?
As far as using 73-87 hangers, where there's a will.... there's a way.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old Today, 03:18 PM   #9
s102000
Thanks SCOTI! Yeah that's my moto too. Spring width is 2 1/4. I'm thinking I can make them work, if I can't then I'll send um back.
PO put a 73 to 87 front end and rear end to have the 5 lug. But the leafs are original as for as I can tell. I took a leaf out a few years ago and it lowered it about 1/2" or so and it made it ride better too, and I have drop shackles on as well. I'm probably going to do a flip kit if I can't get the drop hangers to work.
Thanks again for your time!
Old Today, 04:46 PM   #10
SCOTI
SCOTI's Avatar
Some spacers to take up the difference should work. Check McMaster Carr for some hardware. If you can find what you need, it would be easy enough to tack the spacer/washer/bushing in place making the stopgap more robust.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
drop, hanger, leaf, lowering, shackle
