08-08-2018, 11:00 PM | #201 |
BMW & ASE Master Certified
Re: LT1 GenV swap
Was excited and then bummed at the same time about the L83 swap headers from speed engineering. E-mailed them and asked what did they mock them on, what mounts.. basically LS swap headers with L83 flange. I've already bought all the exhaust bends, custom flanges and collectors so I wont ne buying them. Based on their reply, passenger side will should look like this:
And didn't snap a picture of the driver side cause it just wouldn't bolt flush, hit the frame. So I would be curious if someone buys them and posts up how it fits. Got the electric fan shroud all cut out and mocked up, just need to break it down and fully weld it. Took a 19" 600 watt PWM fan , rigged up a surfacing fixture and used a router to make the edge pretty flat. Pleased how it turned out, now the cooling portion of the swap will operate like factory. Tested it and man it moves some air! End is near.. planning on October ish hopefully.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 08-09-2018 at 12:15 AM. |
08-09-2018, 10:27 AM | #202 |
A guy with a truck
Re: LT1 GenV swap
Is the gen 5 wider/angled differently? Mine fit like magic (gen3):
http://67-72chevytrucks.com/vboard/s...8&postcount=71
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-09-2018, 10:54 AM | #203 | |
Re: LT1 GenV swap
They mentioned having the motor 1" rear offset.. I have my motor pushed back as far as it could go, mount brackets close to vacuum pump and compressor. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 08-09-2018 at 02:08 PM. |
08-28-2018, 08:25 PM | #204 |
Re: LT1 GenV swap
Designed a forming tool, got tired of grinding and test fitting. Got it pretty dam spot on..
This Saturday, I plan on getting the driver side header done. I've got the flanges, and starter tubes made so it's time to get these made! Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
08-29-2018, 07:41 PM | #205 |
Re: LT1 GenV swap
Got all the tubes to about 3/4 tall which is the thickness of the MDF flange I'm using for mockup. Need to make 12 more starter tubes , 4 for the other side and 8 for the other set and put an ad on Ebay. With the starter tubes should make it stand out and hopefully sell quick since it makes it easy for the fabricator. Need to recoup some costs of the header build. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 08-29-2018 at 08:13 PM. |
08-29-2018, 08:10 PM | #206 |
Re: LT1 GenV swap
Looks like that forming die worked real nice...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
08-30-2018, 12:41 AM | #207 |
A guy with a truck
Re: LT1 GenV swap
Very nice work
09-09-2018, 06:09 PM | #208 |
Re: LT1 GenV swap
Re did the header mockup, got a little more room and made it closer to equal length as I could.. wasn't trying for it, but turned out good. No special spark plug wires required
These plumbing caps work great if u needed to purge a tube.. I dont have that setup, be nice but works good for leak testing... just drill a hole in the middle of the bolt and connect a hose to it. I made one, just need to find it. Also, if you take it apart and have some BMW n62 valve cover bolts laying around (I'm a BMW Master tech, and just happened to have a few old ones in my tool box), you can take the rubber grommet off, push the bolt out, shorten the sleeve and presto, tight fitting insert that can be pushed into the small disc end so it can then be used to mount/hold a tube to the mockup MDF flange. Just snug the bolt to the flange and test fit till it grips the tube. Wrapping tape around a bolt and washer works too..
09-16-2018, 07:47 PM | #209 |
Re: LT1 GenV swap
Slow progress, but 2 tubes fully welded, 3rd all tacked and ready to be welded. Ran out of time tonight.
Fits pretty good Time got divided between another project. Got a good deal on a set of the Wilwood c-10 pro spindle kit. With hours of research and cad work and think I got a working setup. 330mm x26mm /13" x 1.25 rotor on the C6 Corvette calipers. Corvette rotors wont work on these massive hubs. Got another rotor in mind that only requires a small mod. It looks like it may not clear my 17" torq lite American racing wheels.. they did a goofy stupid inner barrel design and it has such an angle it makes putting wheel weights on a bear.. so if the 13" setup doesn't fit, just gonna use the larger 350mm / 13.7" rotor and c6 caliper. Clint
09-23-2018, 08:50 PM | #210 |
Re: LT1 GenV swap
Almost done with the driver side
Clint
09-24-2018, 08:58 AM | #211 |
Re: LT1 GenV swap
Excellent work Clint
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
09-29-2018, 08:37 PM | #212 |
Re: LT1 GenV swap
Got a little side tracked but now back on track.
Wilwood c-10 pro spindles with 328mmx30mm rotor and the dual 52mm piston PBR gmt900 caliper from 08+ trucks. Phew, successfully successful in mockup! I have about 1/8 of room between the caliper and rim/wheel weights. If I had larger than 17" wheels I could have done the 350mmx32mm rotors but dont so didnt... Clint
09-29-2018, 11:53 PM | #213 |
Re: LT1 GenV swap
nice build thread. subscribed! is there an easier way to swap in the LT1 gen V engine and transmission? is it so new that the aftermarket hasn't caught up yet? Are there any issues with this swap? Who makes a LT1 GenV harness? are there Adapter plates to mount the motor? who flashes the PCM's to operate in a standalone? the reason im asking these question is because ive done a few LSx Gen 3 and Gen swaps. im trying to stay abreast with this information.
09-30-2018, 01:47 AM | #214 | |
Re: LT1 GenV swap
09-30-2018, 11:53 AM | #215 | |
Re: LT1 GenV swap
The LT1 Gen V is a different animal imo. I used the BRP swap headers and they fit perfect. Dirty Dingo have some swap stuff for the swap specific to 63-72 c10’s. The demand isn’t real big yet, so many items are pricey. I know of a guy that did my harness, again, pricey but he was an excellent source for info. One huge hurdle I had was a different year of trans, that stumped a lot of tuners. We finally got that resolved tho. I am by no means even an amateur at these swaps but, I am willing to tell you what has worked for me so far. Btw, truck is running and driving, just doing some minor tweaks before calling it done. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-30-2018, 05:47 PM | #216 |
Re: LT1 GenV swap
@clyde65 and 87chevy.com, thanks for your replys. I have a friend, that has a friend, that trying to move a motor. I'm just looking at time and energy factor. I can easily swap in another gen III and Gen IV and call it a day. it ma
09-30-2018, 10:18 PM | #217 |
Re: LT1 GenV swap
It's more money than LS for sure.. but its newer, more power, more gears
10-07-2018, 08:21 PM | #218 |
Re: LT1 GenV swap
Driver side just needs the collector diameter shrunk down to 2.5" before welding itto the header but other thanthat, driver side is done.
Final tube fit great after fully welding it .. phew Fits great around the motor mount, knock sensor shield and stock linkage Gonna take the collector to work and use the shrinking cone to see if I can have one less weld... Clint
10-07-2018, 10:43 PM | #219 |
A guy with a truck
Re: LT1 GenV swap
Really nice work
10-13-2018, 07:57 PM | #220 |
Re: LT1 GenV swap
Made the mock up passenger side header, not as easy as I thought, but not to bad.
One down, 3 to go.. Clint Knocked out one more Got the first 3 bends cut out for #1 and the. Called it a day.. as difficult as #1 looks, is easier to work with than #3. I'll go about it the same way once tube #1 is all tacked up I weld the starter tubes to the flange. Afterwards I will surface it aka belt sander it flat. Install the flange and start tacking the 3 tubes to the flange, then tack the tubes at the collector. All that's left is to remove the header and fab tube #2. I do wish I had bought a double hump crossmember though.. maybe I'll just mod the one I already made.. or just leave it
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 10-14-2018 at 07:14 PM. |
10-28-2018, 02:14 PM | #221 |
Re: LT1 GenV swap
Ran out of argon.. but before I did, managed to get most of the header tubes fully welded to the flange, and got the final tube chopped out and tacked up.
Almost... almost....
10-28-2018, 02:16 PM | #222 |
A guy with a truck
Re: LT1 GenV swap
Your dedication is inspiring
11-07-2018, 10:19 PM | #223 |
Re: LT1 GenV swap
Not the standard swap progress, but progress....
Stock Somehow terrible shot of the knucle/spindle Clint
11-08-2018, 09:54 AM | #224 |
A guy with a truck
Re: LT1 GenV swap
What spindle? Is that a C5 hub?
11-08-2018, 11:04 AM | #225 |
Re: LT1 GenV swap
Wilwood c-10 pro spindle drop spindle, stock wilwood hub that comes in kit, custom brackets 12.9" rotors and 2018 Silverado calipers... same as 08+, not PBR brand , there Akebono brand.
Clint
