Old 09-11-2018, 04:56 PM   #1
jmon1123
Need some advice on chevy buyin’
Thanks for stopping by my post, I’m a 16 year old looking to buy a squarebody for my first. From working on a farm and doing landscaping, I’ve made about $4800. I’ve found a 69 C20 Longhorn about 3 hours out from where I live, so if I go down to take a look, I wanna be sure I have the knowledge to make the right call and have an idea of what I’m getting myself into. I guess I’m trying to put together a checklist/ buyers guide.
Here is a link to the truck page: https://bend.craigslist.org/cto/d/19...690085385.html
If you’ve got any spare time, I’d really appreciate all the chevy wisdom I can get. If you know any other 2 tone (preferably a brighter color scheme) for around $2500 or less, I’d also love to see. Thank you, have a nice day
jmon1123 is offline   Reply With Quote
Old 09-11-2018, 06:53 PM   #2
1968k20
1968k20's Avatar
Re: Need some advice on chevy buyin’
Bend is a great place to get a rust-free truck! Longhorns are popular in the fact that I believe they didn't make many of them. Take the 3 hour drive!
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 09-11-2018, 06:54 PM   #3
1968k20
1968k20's Avatar
It also seems like a rare color combo; orange with saddle interior.
Old 09-11-2018, 07:02 PM   #4
jmon1123
Thanks for the reply! I figured, I haven’t seen any other longhorns.
Old 09-11-2018, 09:14 PM   #5
aerotest
Hard to tell by the pictures but doesn’t look like a bad truck. Look around that windshield for rust. Also look underneath at cab corners, supports, etc. Look for any shoty work. I would plan on relocating that fuel tank and putting shoulder harnesses in your budget. Those are key safety mods in modern day roads. Should make a great first truck.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 09-11-2018, 09:57 PM   #6
3drburb
That looks like a nice truck. Get under it, inside and on top to look for rust also an extra set of eyes are sometimes helpful but for a 3 hour drive I would be asking for those areas in pictures first.
If you are looking for a Squarebody why not wait for one. If you can't find one there, head north.
Good luck.
3drburb is offline   Reply With Quote
Old 09-11-2018, 11:08 PM   #7
HO455
HO455's Avatar
Welcome Aboard neighbor! Do a search for rust repair in the search box above and be sure to check the 67-72 box. There you will find lots of photos of the common rust prone areas. Some are not too tough to deal with and others are more involved repairs.
Be sure to start the engine stone cold (beware of sellers who warm the vehicle up for you). Then get it nice and hot and restart the truck. This will help detect common carburetor issues.
Look for wiring that has been cut and patched with lots of crimp connectors. Especially under the dash. Inspect the fuse block for corrosion.
Check the color of the engine oil, transmission fluid, brake fluid, power steering fluid, and if possible the rear end lube. If your not sure how to check these YouTube will be helpful.
If you have a voltmeter check the voltage before starting and RPM both running at idle and about 2000 RPM to see if the charging system is operating as it should be.
Loud clunks and rattles going over bumps are a sign that the suspension is worn. The truck should stop straight under firm braking.
The transmission should shift smoothly and not pause or delay on gear changes. If possible coast down a hill at 40-50 mph and listen for rattles or vibrations that weren't there while cruising.
Plan on replacing the alternator, water pump, master and wheel cylinders soon after purchasing if the truck has sat for couple of years or more. These are likely to fail.
I'm sure that others will chime in. There is a lot to cover especially if it is your first truck. I recommend making a check off sheet to refer to once your looking at the truck. And when you get there actually look at it. Don't be afraid to ask questions and doubt what you may be told. If possible I find that sleeping on the decision to buy can keep from getting caught up in moment. These trucks are fairly common to find around these parts. So there is no need to buy the first one you see.
Luckily for you there are some good local sources for new and used parts as well as the internet. Longhorns are not very common as they were only built for a short period. That doesn't necessarily make them worth more but they are truly cool to some of us.
Good luck!
RIP Bob Parks.
Old 09-14-2018, 12:14 PM   #8
jmon1123
Thanks to all who took the time and replied! replied!
Old 09-14-2018, 09:24 PM   #9
HO455
HO455's Avatar
Your welcome. I'm sure you would get a larger response if you posted the question in the pick up section. The things to check would be the same for a pick up as a Suburban outside of the sheet metal parts aft of the windshield. Then for the most part rust would be the concern to look for.
Good luck with your search.
RIP Bob Parks.
Old 09-19-2018, 11:27 PM   #10
Suburban Steve
Suburban Steve's Avatar
Good luck bud... and you made the right choice... BUT a "squarebody is actually 73-87/91 not sure what nickname is for a 67-72 ... even though I have built Chevys my entire life and a ton of SQUAREs... this is my first venture into 67-72s... Good luck and DONT get into a rush!
Steve
Suburban Steve is offline   Reply With Quote
buying, chevy, question
