05-16-2004, 12:47 AM | #1 |
Tires
I'm going to get some BFG Radial T/As soon for my truck...I beleive I remember reading that 275 was the biggest I can go in the front but how about the back? 72 lwb. I'm looking to run probably 295/50 or 60/15s, maybe even 315s if they will fit. Probably 275s in the front or 255s even.
05-16-2004, 02:06 AM | #2 |
A 295/50 should fit pretty good. That's what I have on my truck right now, but the back spacing on the wheel doesn't tuck the tire into the wheel well as "well" as I'd like. With that, I have an extra 1 1/2" or so cleareance to the inside.
Another thing, not sure how low your truck is, but that tire doesn't fill up the wheel well enough in my opinion. It is 26.8" tall and seems a little small. My truck is pretty low, don't ask me how much it's lowered I couldn't tell you -- Ford 9 in, lowered blocks and looks to be lowered coils. Goodluck!!
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
05-16-2004, 02:16 AM | #3 |
Got Horsepower?
i have 295/50's all the way around on my truck
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
05-16-2004, 02:32 AM | #4 |
71,
I'm actually thinking about getting taller and wider tires for the front of my truck. What width are your front wheels? Any rubbing? Thanks
05-16-2004, 02:45 AM | #5 |
295/R15's 50's back and 235/R15's 60's up front.
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
05-16-2004, 02:58 AM | #6 |
I am running a 225/70-15 on the front and a 285/70-15 on the back. I love the height of the 285's they fill the wheel well perfect.
1968 swb IM-Bufechevy56 If its to loud then your to old |
05-16-2004, 10:37 AM | #7 |
Almost done!
Here is some info that may help you pick your tires.
The first number (295) is the width of the tire, measured in mm. The second number (50) is the aspect ratio, sidewall height, as a percentage of the width. Now to knock it down to understanable terms. Use this formula to get the actual heigh instead of a percentage. 295 x 50% = 147. With this example the tire width is 295mm and the height is 147mm. This is how the tire sizes in the thread above break down. 235/60 = 235 x 141 225/70 = 225 x 157 285/70 = 285 x 199
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
