Old 11-03-2018, 08:05 PM   #126
7D2N
7D2N's Avatar
Re: My winter project
I rounded up some straight down exhaust manifolds. I could use some help from you guys with stock AC. I have the brackets, compressor and some bolts but not sure of right placement.
7D2N
Just for the fun of it
7D2N is offline   Reply With Quote
Old 11-27-2018, 08:23 PM   #127
7D2N
7D2N's Avatar
I finely got the AC brackets in the right place and now ready for start up and break in, just a little fuel and hope all is good.
7D2N
Old 04-05-2019, 10:15 PM   #128
7D2N
7D2N's Avatar
I may have to rename the thread to (My many winters project) I'm getting things done slowly and a lot of boring stuff but I've found out that the phrase “It’s been rebuilt” means....do-over. Transmission rebuild= shift kit and motor rebuild= cam
Old 04-16-2019, 09:35 PM   #129
7D2N
7D2N's Avatar
I now have the needed puzzle pieces to start floor and body repair stuff. This will be a challenge for me.
Old 04-17-2019, 12:07 AM   #130
lks dcvn
lks dcvn's Avatar
Go slow, take pictures, ask questions, etc. Many have been down this road before and have made pretty good progress.
It can all be fixed.
lks dcvn is offline   Reply With Quote
Old 04-18-2019, 08:38 PM   #131
7D2N
7D2N's Avatar
Thanks, your rust repair information will help me greatly.
7D2N
Old 05-21-2019, 08:59 PM   #132
7D2N
7D2N's Avatar
Just a little progress but no welding. I have trimmed and fitted, trimmed and fitted again, put the door on and then take the door off. This takes a lot of time. I plan to start welding soon.
Old 05-23-2019, 11:39 AM   #133
lks dcvn
lks dcvn's Avatar
Great work so far! Looks like you are making awesome progress.
Old 05-24-2019, 07:10 AM   #134
jaros44sr
jaros44sr's Avatar
I agree! if can make past the "B" post ,you've got it made. they're like like pcs. at that on intersection. I actually added one more for additional support
I took the guts out of my door, it was getting to heavy, for the amount of times I took it off and on
good luck on the welding
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-14-2019, 10:43 PM   #135
7D2N
7D2N's Avatar
I started welding and grinding and not very good at either.
7D2N
Old 08-14-2019, 11:00 PM   #136
7D2N
7D2N's Avatar
still, lots to go.
7D2N
Old 08-14-2019, 11:08 PM   #137
maldo
maldo's Avatar
That is really starting to take shape, nice job.
maldo is offline   Reply With Quote
Old 08-15-2019, 06:00 AM   #138
psuedopimp
psuedopimp's Avatar
Just don’t stop! Keep plugging away. Progress looks great.
Justin
1970 Blazer in progress
psuedopimp is offline   Reply With Quote
Old 08-15-2019, 08:38 AM   #139
Paul72
Paul72's Avatar
Great job so far!
I'll be referring to this thread many times this winter as I start my project...
Keep up the good work!
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 08-16-2019, 08:41 AM   #140
jaros44sr
jaros44sr's Avatar
Thanks for the pic inside 'B' post, didn't cut mine open that far. worried something rusty was goin' to stare back at me. bottom of 'b' post is one of the most complex parts of the blazer
great work so far, thanks for posting up and entertaining me while mine sits in electrical prison
SAFETY FIRST
AS usual, off topic
Jim
Old 10-03-2019, 10:08 PM   #141
7D2N
7D2N's Avatar
I'm working on the outer B panel patches and I have some questions if anyone has replaced these, should there be a flang or tab on the bottom panel to attach the panel to the end of the rocker box.
Old 10-16-2019, 01:45 PM   #142
orange72blazer
orange72blazer's Avatar
Here's a couple of pictures of how it should be. The b pillar area on this Blazer is original & unrestored . They are just a tab that is spot welded on.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 10-16-2019, 09:33 PM   #143
7D2N
7D2N's Avatar
Thank you for the response that will help me a lot. I had no reference of how it should have be attached since mine and had rusted away.
Old 10-16-2019, 09:56 PM   #144
jaros44sr
jaros44sr's Avatar
had no idea they were under there ty
You did an excellant (speling), job on the sheet metal work
SAFETY FIRST
AS usual, off topic
Jim
Old 11-30-2019, 07:33 PM   #145
7D2N
7D2N's Avatar
Small update. I have the outer rockers and B pillar patches alined with the fenders and doors and ready to weld. My doors need work, do you think door patch panels or complete door skin?
Old 01-16-2020, 09:24 PM   #146
7D2N
7D2N's Avatar
I decided to repair my doors with lower skins and made some inside B Piller repairs. oh, make sure you have your door seals on before adjusting door gaps.
it will save time. I should have know that I read it here.
Old 01-17-2020, 12:08 AM   #147
Ptjsk
Looks great! Keep it going and you will be done in no time.
Pat
Ptjsk is offline   Reply With Quote
Old 01-28-2020, 09:23 PM   #148
7D2N
7D2N's Avatar
The B pillars are welded in and the outer rockers are tacked for panel alinement. I did run into this problem after I got things alined, the top of both doors leaning out. I'm wondering about these welds, should I grind them off and reweld them in the right position?
Old 01-28-2020, 09:33 PM   #149
Harold Holbrook
The Exhaust manifold on the driver side I think is for a 2 WD ,4WD goes straight down.
Great Build
Harold Holbrook is offline   Reply With Quote
Old 01-29-2020, 10:15 PM   #150
7D2N
7D2N's Avatar
Great Build
Yes, you are correct on the manifolds, the straight down on that side turned out to be cracked and had to use the other one to get the motor brake-in done.
