Old 05-23-2004, 08:24 PM   #1
Blue_71
Bloo
Blue_71's Avatar
strange shimmy
i know this is the wrong board but im gonna try to fix this tomarow so i wanted to post it here where it'd be seen.
drove my dads 94 k3500 dually on a long trip... had a major shaking / vibration in the rear drive train... doin good to hold it steady at 55, sometimes 65... This morning we found the rear outer tire had a busted valve stem - had the tire fixed at a wal mart-- and got back on the interstat, and it is still doing the same thing. its not AS bad, but still major vibration at 65 and up -
i checked the carrier bearing and it has alot of play in it. would that cause a shake like that? it doesnt show up untill at least 55, and isnt bad untill 65. how long would it take to fix the carrier bearing?
Thanks~
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-24-2004, 12:17 AM   #2
walker
walker's Avatar
Seems to me those had composite drive shafts that were prone to going bad. They go bad at the union between the yoke and the shaft I think.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 05-24-2004, 07:59 AM   #3
Huck
Huck's Avatar
Josh, check the composit to metal connection at each yoke on the rear drive shaft by pulling on the shaft real good----any play is not good. If the carrier bearing is letting the driveshaft slop around---that could also be the problem. I usually have the carrier bearing changed at a parts store that can do that as they usually have to be pressed on/off and I didn't have a large/long enough press to do that.
At speed --55-65 if you shift into neutral, does the noise go away? Can you jack the truck up SAFELY at the rear axel and then run the sucker----you can sometimes see/hear what is going wrong---bad tire, bad axel bearing, bent drive shaft, spring mount, shock mount, etc.
Huck is offline   Reply With Quote
Old 05-24-2004, 11:11 AM   #4
Baradium
Binder Rep
Baradium's Avatar
Good be as simple as a bad u-joint... that carrier bearing could be it too though. Either way, if the carrier bearing is bad, you need to replace it... you can do some carrier bearings at home, but I don't know about that one.
Baradium is offline   Reply With Quote
