Old 01-18-2019, 06:48 PM   #1
bigmoe
bigmoe's Avatar
What rear shocks for 4-5" rear drop?
I've done 3" drop spindles and Jeep Wrangler rear springs which are a 4 or 5" drop from what I understand. I put in a frame notch. I've installed some rear shock relocators.
I did some measuring for shocks. If I lift up on the frame until the wheels just about come off the floor the extended shock length would be 18 1/4". If the axle came right up to the snubbers (which it probably won't), the compressed length would be 10 1/4". I grabbed an old rear shock and measured 19 1/2" - 12". I'm wondering if stock shocks would work? This truck will never haul a load. What's ideal for a shock, longer than actual travel length (18 1/4") and shorter than the actual compressed distance ( 10 1/4")?
bigmoe is online now   Reply With Quote
Old 01-18-2019, 07:04 PM   #2
kdad
Re: What rear shocks for 4-5" rear drop?
Take a look at my build and you will see what has become the norm for rear relocated shocks on a 5" drop. "Not my design" but it is perfect for using factory length shocks. IMHO...…
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 01-18-2019, 11:25 PM   #3
Backpayne
Shocks from the front. No lie.
Backpayne is offline   Reply With Quote
Old 01-19-2019, 08:09 PM   #4
bigmoe
bigmoe's Avatar
It appears front shocks are 14" extended, 10 1/4" compressed.
Old 01-19-2019, 08:11 PM   #5
Clyde65
Clyde65's Avatar
What rear shock relocators did you use?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-19-2019, 08:20 PM   #6
bigmoe
bigmoe's Avatar
Saw your pics kdad. Looks like a great idea.
Old 01-20-2019, 08:21 AM   #7
bigmoe
bigmoe's Avatar
This one on the top and stock bkt on the bottom. I think I'll have to build or modify the bottom to raise it up.
Old 01-20-2019, 01:41 PM   #8
TxCajun
TxCajun's Avatar
I installed a 3" heavy-duty drop spring and I fabricated some new rear upper shock mounts following the same basic design that you used, but I did alter the design slightly to position the top of the shock a little further back and more upright.
After a little research, I chose to use Monroe Gas-Magnum 34904 shocks instead of the Monroe 32207 that are often suggested on this forum with that fabricated mount. The 34904 are very close in length dimensions to the 32207, but are a little beefier in that they have a larger diameter rod and cylinder. My truck has a tread plate rear bed floor that I estimate adds 250 to 300 pounds to the bed, so I think the additional damping may be helpful.
However, the shock-fully-compressed-length measurement on my truck is a little longer than what you mentioned for yours, so these 34904 shocks with a 11.875" compressed length work for me.
Monroe has a good website for determining shock dimensions: http://www.monroe.com/en-US/e-catalog/34904/
It appears that the often recommended front shock is Monroe 33033 which has a 14.63" extended length and a 10.13" compressed length.
TxCajun is offline   Reply With Quote
Old 01-20-2019, 10:26 PM   #9
bigmoe
bigmoe's Avatar
Thanks TxCajun. I think I'll go with the sturdier 34904. I'm using a rear gas tank which will add a little weight.
Old 01-24-2019, 10:08 AM   #10
kdad
I got that from the FAQ section.. credit to Frizzle Fry.
Just flip the rear mounting plates drill them out and use front upper mounts at new location on frame. Im using stock front length shocks.
