Driveline issues
OK I’m going from a small block 350 long wheel Bass to a 454 in the same truck so we tried to put the driveline in and obviously I knew the motor had moved back we could almost get it all the way in but there will be no space for the yoke to go inside of the tranny so I’m going to cut the driveline down in the front portion of it in front of the carrier bearing so my question is how much gap should I have between the tail shaft of my tranny and the Botom of the yoke I was thinking about cutting off 1 1/2 inch
Posted via Mobile Device |
#2 | |
Re: Driveline issues
![]() Join Date: Nov 2018
Unless you have some way to balance it your pissing in the wind my friend.
It’s going to be cut by my drive line shop for sure but can’t take the truck there just was wanting to know if any one knows how much of the yoke should I be able to see out the back of the tail shave cause I know there is suppose to be wiggle room just thought some one on here might know how much....
The Older Generation
I have always inserted the yoke as far as it would go and pulled it back out 3/4-1", then measured the length for the shaft. That has always worked for me. Make sure the splines inside the yoke are clean all the way down. LockDoc
#6 | ||
"I ain't nobody, dork."
Call the driveline shop that's doing the work and ask them what measurements you should take. This isn't an area you want to guesstimate or wing-it.
When I had a custom 1 piece driveline made for a 1979 K25 I had, the guy at the driveline shop talked to me on the phone while I was crawling under the truck with a tape measure. Gary
Old member
Just had all this answered on another site and the answer is as stated push it all the way in to the transmission and then pull it out 3/4" to 1" and mark it. Then have it cut to fit.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Just curious because I am going to go to a short bed does the factory short beds have a two-piece driveline with the carrier bearing?
#9 | |
Old member
![]() Quote:
When I did the 6.0 LS with 4L80E swap I got a 1 piece for my LWB truck installed. ![]()
Who Changed This?
![]() Join Date: Jan 2013
This is the answer, right here.
