![]() Join Date: Apr 2016
Make my own LED tail lights
I would like to make my own LED tail lights on a circuit board. Does anybody here have experience with doing that and who can share what the manufacturer and part number of the LEDs are, where to get them, and how many of them together on a board will approximate a stock bulb brightness or a little brighter?
Re: Make my own LED tail lights
check youtube ----i am sure someone has posted something on that
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
I saw that one a while back and had forgotten about it. I will have another look and see if I can figure out what LEDs specifically he ordered, and order some for myself.
meowMEOWmeowMEOW
He's on instagram also and posts pics of his LED builds. His name is Disciple.2RC
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Old member
0o
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I was unable to get any useful information about the manufacturer, part number, or legitimate source of the LEDs. I am starting from scratch, ordered some generic superflux LEDs off of eBay. So, I will see when they get here if they are useful, or if they just need to be chucked in the trash and try again.
#8 | |
My favourite local auto wrecking yard has tons of parts to turn into LED tail lights. I made my own conversion using a pair of LED arrays from the high-level brake lights from a couple of SUV's. Kia or Hyundai, or some such brand. Here's what they look like in action: https://youtu.be/r8LR6g6aekg
Bob 1967 2wd Burb, 350/TH350, 3.73 posi Last edited by 67 Burb; 03-26-2019 at 01:03 AM. |
I ran into some trouble trying to use those arrays as both tail lights and turn/brake lights, so I ended up using them solely for the turn/brake lights and added some LED strip lights down each side of the inside of the lens for the tail lights.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
I made the new lights plug-n-play by making plugs out of the bases of 1157 bulbs so they could easily be removed if needed.
Good idea. I don't have a junk yard to go to here. I would like to order what I need online. I can't buy the arrays like that without knowing the actual make/model/year they come off of. Can you tell that information, or perhaps a part number off of the assembly?
#12 | |
I think they were Hyundai or Kia vehicles. Sorry, but that's about all I can remember.
I found some info on the lens. It looks like they came from a 1999 Hyundai. The re is a number 92750-26 on them and SAE U3 99 DOT Korea and the company initials HMC. That's all I got.
That is great info. Searching for "Hyundai Santa Fe stop lamp 92750-26" shows they are from 2001 to 2006 model years and available for about $40 to $55 each used. They do look very good to use in our trucks.
| Bookmarks |
| Tags |
| bright, led, lights, tail lights |
