Old 04-12-2019, 12:54 PM   #1
Danman09
Junior Member
Adding Vintage Air to inline 6 250 ?
I just picked up a 1970 c10. The guy took it apart, put on all new bed and fenders with ash and stainless, new front fenders, had it painted , frame off, had a machine shop rebuild the 250 inline 6, dropped the motor back in then quit. Never put the bolt-ons onto the motor. Left engine holes all covered. It sat in his garage for years and I asked and got it for a steal. Here's the question. It has power steering , front discs, and power brakes. HEI distributor and original one barrel Rochester. Will this motor handle the addition of Vintage Air ac if I install it, or should I just not try to finish the engine assemble and buy exhaust etc for this and just get a V8 ? I would like to drive this truck almost daily.
Danman09 is offline   Reply With Quote
Old 04-12-2019, 01:11 PM   #2
Danman09
Junior Member
Re: Adding Vintage Air to inline 6 250 ?
It is a 3 speed on the column. 12 bolt rear end but I have no idea what gear ratio it might be.
Old 04-12-2019, 08:26 PM   #3
Hugh in NC
Hugh in NC's Avatar
I put a/c on a 1951 Chevy car with the stock 235 and powerglide. I could not tell any difference in engine performance whether the a/c was on or off. These Sanden compressors take very little hp to operate. Go ahead and add the Vintage Air and you will not regret it.
Hugh in NC is offline   Reply With Quote
Old 04-12-2019, 09:48 PM   #4
Danman09
Junior Member
Thank you for the reply. I think I will keep the 6. Just what I had hoped for.
Old 04-12-2019, 10:40 PM   #5
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Yup. Millions of four and six cylinder engines with AC on them. That six will pull it just fine.
~Steven
Simi Valley, CA
Old 04-13-2019, 03:04 PM   #6
70 shorty
Where's my beer?
70 shorty's Avatar
Does vintage air, or some other supplier make the brackets needed to add the compressor to the engine? Adding VA or something similar is something I've considered on my 70 C10 with an inline 6.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 04-13-2019, 03:16 PM   #7
RichardJ
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-13-2019, 04:12 PM   #8
flattie39
Junior Member
The AC bracket for 250s that VA offers is for the smaller original point distributors and won't fit over an HEI distributor. I found a bracket from Davis Speed Equipment that was made to fit over the HEI. Their part # is 10001 and runs about $155 incl shipping. Nice, well made bracket.
Ken
flattie39 is offline   Reply With Quote
Old 04-13-2019, 05:20 PM   #9
Danman09
Junior Member
Vintage air also sells a bracket that mounts the compressor down low on the passenger side that they say will work with the HEI distributor. Discussed it with them yesterday. A $200 additional charge on the package.
Old 04-13-2019, 06:53 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
If you want to go GM HEI [and not Pertronix] you might want to look into the separate Coil set up. Coil is mounted between the lifter covers, and distributor cap is a ''Low-Boy''. L6 distributor body is the same as the coil-in-cap, but a different coil-to-distributor harness is required.
I found it had less interference with the 292's taller head, so I got one for my L6, even if I don't have AC.
Old 04-13-2019, 09:49 PM   #11
70 shorty
Where's my beer?
70 shorty's Avatar
Thanks guys, I've got an HEI so I'd have to take that into consideration.
Old 04-13-2019, 11:43 PM   #12
RichardJ
The 292 has a taller block so it sits the AC bracket a little higher. I still have to take the belt off and swing the compressor up to remove the cap. I made this bracket myself, using the adjuster slots from another.
a/c, inline6
