04-25-2019, 10:07 AM | #1 |
CPP PS Pump installation
I bought a 500 Series PS CPP conversion kit on sale at Summit. Everything went together fine until i tried to install the PS pump and brackets that came with the kit. I have a 1969 C10 with I believe the original 307 motor. The bracket puts the pump in the way of the Alternator belt. Anyone on here have any experience with this issue?
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
04-25-2019, 07:30 PM | #2 |
Re: CPP PS Pump installation
You can flip the brackets over and run the pump lower.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-26-2019, 01:00 AM | #3 |
I just got done installing that POS kit. I ran into the same issue on my 350, and flipping the brackets did not work. I had to order a bracket made by Alan Groves, pn 400L http://www.alangrovecomponents.com/S...Short_Pump.htm . I ordered mine from Yogis Inc. The kit was a huge pain, and trying to sort it all out took my truck off the road for a while.
04-26-2019, 07:41 AM | #4 |
I'm running the brackets as low as they go. I'll flip them over an go to the high side and see if it works? The bracket in the front to adjust tension on the belt is whats hitting. The directions say the front bracket can be flipped also but when It's flipped it doesn't fit.
04-26-2019, 07:43 AM | #5 | |
04-26-2019, 12:30 PM | #6 |
After calling Summit (not able to help) and calling CPP Tech lines, here is the outcome. The brackets will not work for my set up and is a known problem at CPP and working to correct it. I asked for a discount or help with acquiring the correct parts with no avail. So the three options are: 1) Buy the bracket as above in young Grasshoppers reply...78 dollars. 2) Buy a bracket from CPP to raise the alternator out of the way $109 dollars. 3) Buy the bracket to move the alternator to the passenger side ? dollars along with rewiring the harness to reach. Needless to say the best route in my opinion is option #1. If I didn't have everything already installed I would of returned it!!! Hope this helps anyone in their decision making to PS conversion kits.
04-26-2019, 01:54 PM | #7 |
I had the same issue with the first Power steering bracket I bought. I found another one that fit. I used this bracket so my belt would clear.
(63-14304) 63-70 Power steering pump brackets - Small block V8, will clear8 $46.00 X 1 = $46.00 www.truckandcarshop.com |
04-26-2019, 03:07 PM | #8 |
[QUOTE=dondb;8513408]I bought a 500 Series PS CPP conversion kit on sale at Summit. Everything went together fine until i tried to install the PS pump and brackets that came with the kit. I have a 1969 C10 with I believe the original 307 motor. The bracket puts the pump in the way of the Alternator belt. Anyone on here have any experience with this issue?
I went through the same problem on my 350. I am running the 400L power steering bracket and 232L alternator bracket from Alan Grove. I had to use the extra crank pulley, and get a double groove alternator pulley. That way you use the outer crank pulley for the power steering and the second groove on the crank pulley for the alternator. The crank pulley groove closest to the engine is not used. It's a tight fit getting to the steering pump cap but you can get it off to service it. You might source an original alt. bracket and get more clearance to get to the cap off? Here's a few pics to show my set up.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
04-26-2019, 03:09 PM | #9 | |
04-26-2019, 03:30 PM | #10 | |
That's a nice set up!
I should be able to use a original PS bracket with the 2 grove pulley on my crank, utilizing the inner groove for my alternator and the outer for the PS? The current alternator bracket is original, it came like that from the factory....and should all work, but we'll see?? I think the 2 groove pulley I got from Summit for the PS pump should line the outer grooves up......I HOPE ANYWAY! It gets pretty frustrating when you want to get the truck out and so many little things crop up. Not to mention my original goal was to do just the bed wood this winter and morphed into a total chassis repaint, Disc brake, PS conversion and front end rebuild....... [quote=RodnRudy;8514250] Quote:
04-26-2019, 11:03 PM | #11 | |
The first power steering box I received had bad threads where the pitman arm attaches, the nut would go up a little and then get stuck. I found this out when I was bench test fitting it all. I tried to work with CPP to explain the issue, sent videos. It was not like I cross threaded it, but somehow when it was machined and tapped the angle of the threads was off. I sent the gearbox back to CPP at a cost to me of $50+. I received one back a few weeks later, and later found out they charged me for shipping $50+ more on the new unit, and when I contacted them, they blamed me for cross threading it. Again, I am done with CPP they obviously do not stand behind their product. |
04-26-2019, 11:07 PM | #12 |
I didn't use the 232 bracket, just the 400L which the belt barely fits. I just knew I did not want to relocate the Alternator, in case I want to add A/C later.
04-27-2019, 09:55 AM | #13 |
Yes...I do find it hard to believe they are still in business? I guess the people buying their product are use to making adjustments to parts not working without modifications. And most of the time the pricing is usually less and us do it our selfers like to save money
Thanks for the heads up on the pitman arm threads on the gear box. Mine is just finger tight right now and i can make sure the nut goes on correctly before final tightening.
