Old 05-16-2019, 12:43 PM   #726
amoore1972
Re: LS swappers, post up your pics!!
What year is the LS you used ? Do you have Factory AC ? If so, did you have to relocate the AC compressor high passenger side ? Can't tell from the pics.. Also is your alternator down low drivers side ?
amoore1972 is offline   Reply With Quote
Old 05-16-2019, 04:20 PM   #727
amoore1972
Originally Posted by RatRod68 View Post
My pride and joy. I love this truck more than life itself
What year LS is that ? Is your alternator mounted down low on drivers side ?
Old 05-26-2019, 10:39 AM   #728
kenworth47
l83 in my 72
1972 chevy short box
1986 chevy long box
1998 gmc daily driver
kenworth47 is offline   Reply With Quote
Old 07-19-2019, 06:40 AM   #729
scott123
This is my 72 K5. 350/SM465/NP205 about to do my first LS swap.
Stumbled out of the gate a bit but today will be much better.
Scott
scott123 is offline   Reply With Quote
Old 08-11-2019, 12:03 PM   #730
RockhoundII
It finally runs! 2002 6.0l with ls3 heads and intake paired with a 4l80e.
My 6.0/4l80e swapped 2wd '79 Blazer Project - http://67-72chevytrucks.com/vboard/s...d.php?t=765788
RockhoundII is offline   Reply With Quote
Old 08-12-2019, 10:40 AM   #731
aggie91
I'm just glad to be here!
aggie91's Avatar
My 4th one overall still in progress, and 3rd in a square...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-05-2020, 12:37 AM   #732
Duck1
Originally Posted by chevyc10lover View Post
nice swap. i know is an old tread, but i should ask.. what kind or rack and pinion is that?
Is that mount up side down?
Duck1 is offline   Reply With Quote
Old 03-13-2020, 11:17 AM   #733
OutlawDrifter
My '49 GMC. LQ4 6.0L, 4L80E, Holley intake, DBW, SBC valve covers, and an Cadillac/Olds Batwing.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-14-2020, 09:40 AM   #734
reaper71
reaper71's Avatar
My 52 Chevy 5.3l 4l60e
reaper71 is offline   Reply With Quote
Old 03-23-2020, 12:21 PM   #735
rowdy11
Curious to know who's using stock plastic engine covers vs. keeping the intake exposed. I'm trying to decide if I paint up my intake or keep and paint the cover. I have the Gen IV truck intake meaning it works well but doesn't look very good.
Thoughts?
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 03-24-2020, 12:34 PM   #736
reaper71
reaper71's Avatar
Here are a few examples of a smoothed out stock truck intake.
The last pic is a intake I did for a customer (Blakes 67 GMC build) in that build I show step by step on how I did it.
Mark
Old 03-28-2020, 06:21 PM   #737
Bigru
Bigru's Avatar
Hey guys, I need some help.. this is my first swap and I have no idea what I’m getting into. I have a 6.0/4l80 from a Denali, I replaced the intake from a TBSS. I’ve ordered a adapter plate to use the throttle body from the 6.0 intake. What does these connect to?
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 03-28-2020, 09:48 PM   #738
mongocanfly
mongocanfly's Avatar
bigru...might want to put this in the LS section..this section is mostly for pics
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-28-2020, 09:52 PM   #739
Bigru
Bigru's Avatar
Got ya.
1965 Short Fleet
2008 GMC Denali
Old 04-19-2020, 01:06 AM   #740
Irish1941
Irish1941's Avatar
1972 Chevy original short fleet. Started life as 6 and 3spd.
Built up in 1995 with swapped in V8 and automatic but needed some new blood injected into it.
So I stuffed a 2015 LS3 and TR6060 into it which snowballed into a pile of other stuff.
Z06 14" brakes, 4" and 6" drop on Hotchkis suspension blah blah
Need to get a tune on it, finish up AC and some other details but pretty much ready to hit the street.
Irish1941 is offline   Reply With Quote
Old 04-19-2020, 03:11 PM   #741
Tork?
I love this! You have a build thread? I have an ls3/tr6060 combo too still gathering parts. Did you use the No Limit clutch master setup? Any pics of the transmission setup? Crossmember, trans mount, driveshaft situation?
Tork? is offline   Reply With Quote
Old 04-19-2020, 04:10 PM   #742
LS short box
On my 68 C10 I used the Captian Fab clutch kit. Worked like champ.
Old 04-19-2020, 04:46 PM   #743
KFF 1
KFF 1's Avatar
1972 Suburban C20 Custom Deluxe 6.0 LS ( 402 cu in ) 4L80E 3.73 posi
KFF 1 is offline   Reply With Quote
Old 04-19-2020, 11:51 PM   #744
Irish1941
Irish1941's Avatar
No build thread but I'll tell you what I did.
Im really not a kit guy. Just used Wilwood clutch master. 3/4" bore if I recall. Works perfect. Lining up rod to master was hardest part and that was pretty easy.
Drivetrain only has 20k on it but still swapped in new clutch. Just LuK replacement.
Trans crossmember is a IFS. https://www.amazon.com/Ingenuity-Fab.../dp/B074L8YYY6
Good in fact that you can center the trans plus I couldn't make it for price they charge. Little rough out of the box but very slick piece. Has dual exhaust humps too.
The actual trans mount I made and it takes a TH350/400 rubber or poly mount. Factory '15 Camaro piece was too high for the floor pan.
Driveshaft is modded rear a 2002-03 Excursion 4x4 with slip joint.
Couldn't see spending $1k for a driveshaft.
Old 04-26-2020, 04:36 PM   #745
70inbville
Irish1941
would you be so kind as to tell how the front brake system on your beautiful truck came to be?
Thanks, Chip
70inbville is offline   Reply With Quote
Old 04-27-2020, 11:51 AM   #746
Irish1941
Irish1941's Avatar
87 spindles with hubs and caliper mounts from Kore3.
Tobin from kore3 is a great guy and super helpful. If you want big brakes that work, you can't go wrong.
http://www.kore3.com
Old 04-27-2020, 11:59 AM   #747
70inbville
Thank you. since seeing your one pic of those brakes I have been sent down a very long rabbit hole looking at 50 some pages on gringolocos build and that has opened so many more rabbit holes!
Old 04-27-2020, 02:02 PM   #748
doug_p
doug_p's Avatar
Just ordered the Kore3 Z51 14"/13" kit for my truck, and 2nd the positives on Tobin. Very helpful, and willing to answer a boatload of questions. Cannot say enough about how helpful he was!
doug_p is offline   Reply With Quote
Old 04-27-2020, 08:56 PM   #749
gringoloco
A guy with a truck
gringoloco's Avatar
Glad to be of help
Congrats! Tobin is probably the best vendor I have ever dealt with.
...and a pic of my LS swap, since we’re in this thread:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 04-27-2020, 09:01 PM   #750
gringoloco
A guy with a truck
gringoloco's Avatar
[img]
[img]
[img]
[img]
I like your style! Who makes the wheels?
I like your style, too. How’s you get the big block valvecovers to fit?
-Chris
