Old 06-03-2004, 05:10 PM   #1
Bryan H
Bryan H's Avatar
What Year Power Steering Gearboxes Will Work?
What year power steering gearboxes will work on our trucks? I wanted the later model with the quicker steering ratio and I didn't know what year Chevy went to metric lines.(73-8?) I was wondering before I hit the junkyards.
Thanks,
Bryan
Bryan H is offline   Reply With Quote
Old 06-03-2004, 05:58 PM   #2
tom hand
CCRider
tom hand's Avatar
Anything thru 87 will work....the metric lines are no big deal....just change the fitting on the back of the pump
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-03-2004, 08:07 PM   #3
DR67
DR67's Avatar
Is there any advantage in going with a newer year box, rather than a rebuilt of the correct year? Are the ratios all about the same?
DR67
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 06-03-2004, 09:01 PM   #4
mooneyes
mooneyes's Avatar
..i have an 80 on mine and didnt notice a difference
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 06-03-2004, 09:05 PM   #5
Pont
I need another Barley Pop
Pont's Avatar
I believe 82 was the first year they used the metric / o-ring style fitting. Could be 81, I'm having a senior moment and can't remember exactly what year.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 06-03-2004, 09:15 PM   #6
dinnut
dinnut's Avatar
ive read that the newer (73+) boxes were 1 less turn lock to lock. id really like to know. someone has to
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 06-03-2004, 09:36 PM   #7
jay-dawg
chevelito
jay-dawg's Avatar
You also have to change the coupler on the column to fit the gear box. Someone told me they don't make 'em for original non-power columns anymore.
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 06-03-2004, 09:39 PM   #8
super-k
On 4WD,thru`75 is how GM has P/S box listed.That`s what I ordered.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project
super-k is offline   Reply With Quote
Old 06-03-2004, 10:03 PM   #9
neonlarry
neonlarry's Avatar
Newer boxes 3½ turns lock to lock, ours 4½ turns lock to lock.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-03-2004, 10:36 PM   #10
Bryan H
Bryan H's Avatar
I'm talking about the gearbox and not the pump. Mines a 2wd and I'm going to run the 67-72 pump because I already have the brackets. I'm wondering about the gearbox itself. What years have the standard threads in the gearboxes to work with the older pump?
Old 06-03-2004, 10:59 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You can run one up to 81. The rag joint assembly will have to be changed though. The steering shafts coming out of the 73 and newer power or manual gear boxes are smaller in diameter. I found this out the hard way, but "Red Head" Power Steering gears straitened me out. I am a dealer for them as well as using their gears. I think that I can have custom ones made, but the cost is extra. The late model gears are a full turn faster as stated above. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-04-2004, 08:51 AM   #12
Lobo'74
Lobo'74's Avatar
PO put an '85 power steering box and pump on my '68. Wes, you say up through '81 is workable. Truck feels very touchy, especially above 45 or so. I thought it was because my frame hasn't been dimpled for the steering box. Is it possibly because it was an '85 box? What are the problems with using boxes post '81?
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 06-04-2004, 09:52 AM   #13
crazy longhorn
Fabricate till you "puke"
I have a 85 burb box on my longhorn, & it works fine.....the frame is dimpled on my 69 tho. The difference is the fittings on the hoses on the 80's metric boxes(otherwise they bolt up). It could be that your steering box is not centered , or in "nuetral position" when you are driving on the straight. I think it would be possible to center the box with the wheels straight, by readjusting the tierod ends on both sides. You may loose a little turn radius in 1 direction, but it shouldnt be enough to notice. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
