Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-29-2019, 10:04 AM   #901
7dee2
7dee2's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Great job on the box, you're going to have really great tunes!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 12-01-2019, 04:12 PM   #902
TA_C10
TA_C10's Avatar
Originally Posted by First c10 View Post
Decided to use one of the gas tank bolt locations to run a ground stud through so I can ground the cab and the amps to the frame.
I installed a 12+ bulkhead lug in the floor to supply power to the fuses for the amps. I will get a picture of the power into the cab from under the truck when I get a chance.
Looking great man. I'm taking notes. Question. I see your using a large gauge wire for grounding here. Most places I read say to use the flat ground straps instead so you don't get feedback into the wiring system causing things like your speakers to have feedback from vibrations and engine revs. What are your thoughts on this?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-01-2019, 06:50 PM   #903
First c10
First c10's Avatar
Thank you for the props.
I have installed grounds from the frame to cab kind of like what was stock.
The ground you see is basically for the amplifiers only. By installing the ground stud in the original nut that is welded to the cab that secured the original gas tank. I added the 4gauge ground to each amp then a 2 gauge ground under the cab to the frame.
From my experience the ground loop (engine noise)is usually caused from the signal equipment. Stereo, EQ etc.
I hope this makes sense.
I hope to get back on the truck next week.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-02-2019, 01:47 AM   #904
TA_C10
TA_C10's Avatar
So if your stereo gets ground from the cab, and you have that big ground connected, will that cause issue? Or did I miss your point? My mustang always had engine noise in the stereo especially when I had my phone plugged into stereo with aux cable and also charging via cigarette lighter at same time. I don't want to make the same mistake in my truck but I don't really know what caused this...
"It's only money".
Old 12-02-2019, 11:44 AM   #905
First c10
First c10's Avatar
On your application you would need a ground loop isolator.
It happens when you connect signal wiring like AUX cords and/or phone chargers to your stereo.
My son had the same probably you mentioned. I added the ground loop isolator on the rca connectors fixed the problem.
GO GO!!!
Old 12-02-2019, 12:53 PM   #906
TA_C10
TA_C10's Avatar
Thanks for taking the time to answer my questions, much appreciated. And again, your attention to detail is awesome, I've taken notes and tweaked them a little for my own build I like what you've done so much. Keep up the good work, your gonna have a one of a kind really nice truck
Edit. I only grabbed technical ideas btw, didn't want it to sound bad like I'm stealing your hard work, gotta have my own design of course...
"It's only money".
Old 12-02-2019, 06:16 PM   #907
First c10
First c10's Avatar
Edit. I only grabbed technical ideas btw, didn't want it to sound bad like I'm stealing your hard work, gotta have my own design of course....
No worries use what you could use. I like when people use ideas they find here because if I can help someone that is great because many on here have helped me... probably way more than I have helped!!!
good luck!!
GO GO!!!
Old 01-08-2020, 12:07 PM   #908
First c10
First c10's Avatar
Hey guys I hope all is well and good fortune in the new year!!!
Update on the truck:
No pictures but we took the doors off to drill holes in the door and door jam for the rubber boots for door wiring.
We also took the hood and cowl off. We wet sanded all panels and will be re-clearing the truck with 3 heavy coats of clear starting today.
I cant wait to see the finishes product.....
Pictures by the weekend.
GO GO!!!
Old 01-08-2020, 11:41 PM   #909
First c10
First c10's Avatar
3 heavy costs of clear on tonight. Got to love a heated paint booth. I was watching from outside in the cold.
Cab is moving in tomorrow and will be cleared by the end of the day.
GO GO!!!
Old 01-09-2020, 01:23 AM   #910
DWilbur
Very cool gota love that shiny paint.
DWilbur is offline   Reply With Quote
Old 01-09-2020, 02:59 AM   #911
First c10
First c10's Avatar
My painter said a total of 5 coats of clear. He said I won’t believe how flat and smooth it will be when it’s wet sanded and buffed.
GO GO!!!
Old 01-09-2020, 08:53 AM   #912
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Looking great! Can't wait to see the end result. Keep up the good work.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-11-2020, 10:27 PM   #913
First c10
First c10's Avatar
Hey guys. I was able to get the panel cleared and the cab. I drove the truck for the first time down the road because the paint booth was 2 blocks away. It drove great but brakes are a little touchy but there is no weight in the truck. So we will see how it is once the truck is assembled. We are going to let the clear cure for a few weeks before we touch the paint.
I did have a set back. Someone wanted my stuff more than I did I guess because I got broke into. They took all my hand tools, cordless tools, all my air tools and my tig welder. Oh and they also took the vin plate I had in the tool box waiting to get put on. It insured but some thing can not be replaced.
Sucks but I learned a big lesson.
Anyone have a k10-20 Vin laying around????
GO GO!!!
Old 01-12-2020, 02:18 AM   #914
TA_C10
TA_C10's Avatar
Dang man, sorry to hear about your theft... That's terrible man. Truck is looking good, I bet that was cool driving it.
"It's only money".
Old 01-12-2020, 02:22 AM   #915
DWilbur
That totally sucks they stood all your tool. Someone stole box from my house before Christmas. Got lucky and Amazon replaced everything.
Old 01-12-2020, 11:29 AM   #916
First c10
First c10's Avatar
Thanks guys.
I have to figure a way to secure my building and the yard before I replace any tools. The night I got hit 3 other businesses got it also, some for the 5th or 6th time. Sad thing is I had cameras and I got to match a guy with a Spider-Man mask on walk around like he owned the place. Wheel barreling my stuff out the door.
I now have WiFi cameras on the inside that alert my phone and iPad on any type of motion.
Sick feeling. But For $150 I think everyone should have them. $150 could have saved me a lot of headache and grief. I bought the Ring spotlight camera battery type from Home Depot.
GO GO!!!
Old 01-16-2020, 06:43 PM   #917
swamp rat
swamp rat's Avatar
I hate thieves!! Been the victim 3 different occasions myself. Your truck is lookin great though!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-17-2020, 08:37 PM   #918
First c10
First c10's Avatar
$88k ?????
Wow mine will be worth $100k.
Any takers????
GO GO!!!
Old 01-17-2020, 10:31 PM   #919
DWilbur
When 2 people get in the room that just have to have the price can get crazy.
Old 01-17-2020, 11:12 PM   #920
derotoreut
derotoreut's Avatar
$88k ?????
Any takers????
That's funny. I watched that and took the exact same picture of the TV with my phone.
~ Dan
Old 01-18-2020, 01:03 AM   #921
First c10
First c10's Avatar
That’s is crazy right??? I mean I know they are cool but this years Barrett Jackson is off the hook crazy!!! With all the 67-72 trucks and blazers. I can’t believe the sold prices. One 67-c10 was sold for 150K.
GO GO!!!
Old 02-11-2020, 02:46 AM   #922
First c10
First c10's Avatar
Hey guys. Got some great news. Our towns finest busted the guy that ripped me off. I got probably 80% of my stuff back tonight. Tomorrow I will start to organize it and see what is still missing. This guy dumped all my tools plus others is a plastic bin and threw away all the organizers and cases. Wtf. Tweakers!!!
I even got my tig welder outfit back. It was 200 yards from my shop at an apartment complex. It was the maintenance guy for the apartments.
Anyway now to organize my tools and get back to work on the truck.
GO GO!!!
Old 02-11-2020, 03:42 AM   #923
derotoreut
derotoreut's Avatar
That is awesome news! So glad to hear you'll get most of your stuff back and they nabbed the scum bag. Now you can continue to carry on with your great work!
~ Dan
Old 02-11-2020, 03:50 AM   #924
Richard
Great news about your recovery. Like your truck!
Richard
Old 02-11-2020, 11:36 AM   #925
72 tigger
72 tigger's Avatar
Great news! But what about your VIN plate ???
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
