Old 12-30-2019, 11:02 PM   #26
Duncan K
Re: Dunce's 61 SWB Custom
Nice job on the trans tunnel!!
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 01-08-2020, 11:26 AM   #27
dunce79
Doing some repairs to the driver door jamb area, roof corner, and top inside/outside of the windsheild channel. Also filled in the heater cowl in the cowl area. They reproduce the outter panel under the front of the roof but not the inner for 60-63 that I could find so I used an inner repair panel for a later model and cut the ends off. If you don't need the whole length, it works just fine.
dunce79 is offline   Reply With Quote
Old 01-08-2020, 11:39 AM   #28
made2drag
made2drag's Avatar
stellar work! Keep the pics coming!
made2drag is offline   Reply With Quote
Old 01-08-2020, 12:09 PM   #29
doobiebro
doobiebro's Avatar
Top Notch Work! Im also replacing lots of sheet medal on a replacement cab thats going on my 60 truck. 2 years later and still burning on it I dont feel too bad now watching all that massive work you have done on your 61.
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 01-08-2020, 01:31 PM   #30
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Well done! That was a rusty one, but you are making it look great.
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 01-23-2020, 03:38 PM   #31
dunce79
Update time...
-Finished up the upper windshield channel area
-fixed some rust in the driver door jamb knee knocker area
-deleted the gas filler hole on the cab
-dash center speaker delete
-delete heater control and ashtray from the dash.. will put a small vintage control there above a new custom autosound head unit with bluetooth etc.
-With the vintage air unit, won't need fresh air from the cowl so usually I'd want to delete the grille from the cowl panel but did not want to lose the patina there so I chose to make a removable cover for the wiper arm mechanism intead. Fits under the panel and will seal to keep the air and water out of the cowl : ).
-fixed someone's hack job under the gauge cluster where they added some aftermarket gauges. Won't need those small holes either but its back to a factory look now and I think I'll put the check engine light and bright indicator LEDs in those small holes.
-Replacing door bottoms and small sections of the outter skins, again trying to retain as much of the original stuff as possible. Lots of measurements etc when doing the rockers and door bottoms paid off, everything fits damn nice and gaps won't be hard to dial in at all.
-Front suspension coming soon and I have a column and hydroboost brake system to mock up along with the throttle pedal.
Old 01-23-2020, 04:03 PM   #32
cwcarpenter98
cwcarpenter98's Avatar
Looks great! Your rust repair keeps giving me inspiration to fix my 63
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-24-2020, 11:26 AM   #33
Duncan K
Fantastic metal work! I agree with Christian, seeing someone else doing as much rust repair as I am inspires me to keep moving along.
66 GMC 910
Old 03-11-2020, 04:08 PM   #34
dunce79
Time for an update : ) Getting to more of the fun stuff now.
CPP Hydroboost brakes
Scotts Hotrods IFS
Fitting the LS3
Slight dash mod/fix for the radio/heater controls etc
Gauge cluster
Step notch out back with Quick performance 9 inch, 3.90 gears and disc brakes
I have the original deluxe out wheel out for restore, just using an old 66 Nova wheel as a standin
core support mockup, 69 camaro radiator, homebuilt shroud with dual 11 inch SPAL fans
Made some 6x9 rear speaker sections and a place to mount the amp and PCM
Test fit the vintage air AC unit
Detroit Steel Del rays in bare steel... have some trim rings and chevy caps coming
315/30/20 rear tires and 255/30/20 up front - have room to go wider though.
Doug Thorley tri Y headers fit this application near perfectly.
Made some kick panels and put 5x7s where the vents used to be.
Old 03-11-2020, 09:55 PM   #35
Captainfab
60-66 Nut
Nice work
Old 03-12-2020, 06:35 PM   #36
SCOTI
SCOTI's Avatar
Man, there are several of you guys on here just crushing the rust repair jobs!
Nice group of parts & even nicer fab work!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-13-2020, 05:13 PM   #37
dunce79
Started putting my junk on youtube. Anyone interested can catch updates on this here:
EP1 https://youtu.be/T1fuF1z43xw
EP2 https://youtu.be/4eITRNM5ibE
EP3 https://youtu.be/I8NBo45xoWk
EP4 https://youtu.be/FhpecmUKmpo
Old 07-13-2020, 05:56 PM   #38
SCOTI
SCOTI's Avatar
Watched the 1st one. I'll check the other out when possible.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-14-2020, 12:10 PM   #39
dunce79
PART 5 : ) https://youtu.be/Z_fyBCpAAMY
Old 07-19-2020, 10:49 AM   #40
88Stanger
88Stanger's Avatar
DAMN your body work is impressive!!!
88Stanger is offline   Reply With Quote
