Dot requirements ?
With a 4 head light system , is it legal to have all 4 head lamps with low and high beams . Which means I would have 4 high beam head lamps instead of just 2 ?
I am wiring up all the lights now and thought this would be great for lighting if it’s allowed ? |
Re: Dot requirements ?
If your talking about gmcs that the way there sappose to be. All 4 on hi. The low beam is dull element and the hi single elemen. The reason that it is not all 4 on hi is that the low beam bulbe is kinda hard to find. Have to order it. So it was probably replace with a single element bulb.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
On my 94 chevy I made it have the hi for mod so that the lows would stay on with the hi beams. I never had a issues but I don't have state inspection or anything ether.
Ok
I would recommend the relay upgrade to draw power direct from battery . it will take a lot of stress off the original wire and give brighter lights too
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I sure *hope* it's illegal to run 4 hi-beams.
'Way too many drivers running far too much lighting. It may make them feel all warm and fuzzy, but it blinds the rest of us.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
It’s a matter of road respect , I don’t run with my high beams unless I’m on the road and no traffic even close .
#10 | |
Who Changed This?
![]() Join Date: Jan 2013
Old member
The law in your area maybe fine with it but I would check. There are all kinds of vehicles with 4 lights on when on high beam. You just need to find out what your area law is on it.
Yes the relay upgrade is a good idea also. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Oct 2009
I've never owned a GMC - if what 71gmcC15 said in post 2 is correct, then I see no problem - in fact, perhaps all you need is the correct bulbs to make it work the way you're describing. If that's not how it's supposed to work - a modification of the factory lighting system is very likely not legal. I'd check with your friendly State Trooper beforehand. Good luck and let us know what you find out.
All four lights do come on for hi-beam. Do you mean change to four on low-beam? Why? If you need more light use hi-beams. Even if four on low are legal, which I believe it isn't, oncoming traffic will see all four lights lit up and flash you as if you were on high beams. A lot of the difference between hi-beam and low-beam and how they affect oncoming traffic is the aiming. If you aimed your hi-beams the way low-beams are aimed you wouldn't have much better lighting. If a headlamp isn't aimed out and down like a low-beam it will annoy oncoming drivers. I doubt four lights on low-beam would give much more due to the aiming. If they do, you probably need to aim them farther out
![]() Join Date: Feb 2016
I lived in several bigger cities on the east coast long ago and it was common for Checker cabs to have 4 low beam lights. I'm sure it is legal is some states and with the prevalence of aftermarket lights that do not meet DOT standards it not likely you will be stopped for it. Especially if they are aimed properly.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#15 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
High beams are not to be used when meeting other traffic anyway, so it's a moot point.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#16 |
At the body shop.
New F-250s are 4 on low beam.
Really annoying when they're pulling a trailer but legal.
" That didnt make it any newer " " Dont antique the equipment " |
#17 |
Well checked into this a little more , the feds dictate lighting requirements . The states primary get involved when the police get blinded by our head light. At least that’s what I have found.
I did manage to find some one who has the proper head light aiming equipment, so that in it’s self will help . You can not properly aim by the old wall method ? Which is what everyone does even after they rebuild wrecked cars . Anyhow , I misspoke about high beams , I want to have all 4 lights with low beams . |
#18 |
You might get it right using the wall, but I've always had mine aimed by equipment. Same with front end alignment. so basically the law is good enough is good enough. If you can see and people aren't flashing you, you're good to go... except for safety inspection. But that's when you get them aimed properly.
#19 | |
80% of the time, vehicle lighting is primarily to benefit the OTHER drivers--blinding them is counter-productive.
#20 | |
Who Changed This?
#21 |
![]() Join Date: Dec 1999
I run a 4 hi relay kit on my 94 and also have driving lamps. Was curious and looked up my state.
24405. (a) Not more than four lamps of the following types showing to the front of a vehicle may be lighted at any one time: (1) Headlamps. (2) Auxiliary driving or passing lamps. (3) Fog lamps. (4) Warning lamps. (5) Spot lamps. (6) Gaseous discharge lamps specified in Section 25258. (b) For the purpose of this section each pair of a dual headlamp system shall be considered as one lamp. (c) Subdivision (a) does not apply to any authorized emergency vehicle.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#22 |
@ mygmctruck1. For what you want to do, as long as each pair of lamps is hi/low perfectly acceptable.
MICHIGAN VEHICLE CODE (EXCERPT) Act 300 of 1949 257.685 Head lamps; number; modulator; height; auxiliary, spot, or other lamp; exemption. Sec. 685. (1) Except as otherwise provided in subsection (2), a motor vehicle shall be equipped with at least 2 head lamps with at least 1 head lamp on each side of the front of the motor vehicle, in compliance with this chapter. An implement of husbandry manufactured on or after January 1, 2007 shall comply with section 684a. (2) A motorcycle or moped shall be equipped with at least 1 and not more than 2 head lamps that comply with this chapter. (3) A motorcycle or moped head lamp may be wired or equipped to allow either its upper beam or its lower beam, but not both, to modulate from a higher intensity to a lower intensity. A head lamp modulator installed on a motorcycle or moped with 2 head lamps shall be wired in a manner to prevent the head lamps from modulating at different rates or not in synchronization with each other. A head lamp modulator installed on a motorcycle or moped shall meet the standards prescribed in 49 CFR 571.108. (4) Every head lamp upon a motor vehicle shall be located at a height measured from the center of the head lamp of not more than 54 inches nor less than 24 inches above the level surface upon which the vehicle stands. (5) When a motor vehicle equipped with head lamps as required in this section is also equipped with auxiliary lamps or a spot lamp or any other lamp on the front of the motor vehicle projecting a beam of an intensity greater than 300 candlepower, not more than a total of 4 of those lamps on the front of a vehicle shall be lighted at a time when upon a highway. (6) A motor vehicle licensed as an historic vehicle is exempt from the requirements of this section if the vehicle as originally equipped failed to meet these requirements. An historic vehicle shall not be operated in violation of section 684.
