Old 03-31-2020, 10:30 PM   #1
Dabigman04
Dabigman04's Avatar
Exclamation Wiring up a wiper motor with no harness
So the previous owner of my truck appears to have butchered the painless performance wiring harness. I have a motor and switch but the only wire i have is the constant hot one. I need to know what to hook to where so I can get my wipers going. Can anyone help?
Zachary M. Sefcovic
—— 1970 C10 454 BBC +0.030 over, TH400 - lowered
Dabigman04 is offline   Reply With Quote
Old 03-31-2020, 11:44 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wiring up a wiper motor with no harness
Positive is the Yellow wire and it comes from the fuse block to the washer pump then on to the wiper connector. Here is a picture of the wire connections on the wiper & pump. The Brown connector is the washer pump and the 2 Black connectors are for the wiper. The Light Blue, Dark Blue, and Black wires are ground wires and go to the wiper switch in the dash. The wiper/washer switch has to be mounted in the dash before the wiper/washer will work because that is where the system gets its ground......
LockDoc
Leon
Old 04-01-2020, 12:21 PM   #3
Dabigman04
Dabigman04's Avatar
Thanks! That should be enough for me to be able to wire it up
Zachary M. Sefcovic
1970 c10, electronics, sbc 350, wipers, wiring help
