06-22-2004, 12:08 AM | #1 |
2 year project question
Hey all well a few choices I have to make
I have the front control arms and new ball joints installed and the dif is re bearing and sealed. Now do I run brake lines and put in my calipers and wheel cyl or do I start on the body and leave the hyd. til last. The truck will not be ready for the road for about a year and a half or so The frame will be stored inside a shop but will things start to dry out by the time I am ready to drive it? Please share your point of view on how and what order you did your 2 year projects Thanks in Advance Mike
71 Chevy 1/2 ton work in progress 96 Sunfire 03 Montana the truck is a mess but good times ahead |
06-22-2004, 04:54 PM | #2 |
Designated A-hole!
If you installed them and bled your brakes I don't see a problem. On the other hand I don't see a problem with waiting. I guess that's a lot of help, eh?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-22-2004, 06:02 PM | #3 |
I don't think it really matters but personally I would go with finishing everything while you have easy access. I'm working my way from the ground up.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
06-22-2004, 06:48 PM | #4 |
I would finish the frame off and get it out of the way. Can't really bleed the brakes without a MC hooked up. I don't see how brakes and stuff can dry out, if you are worried about them drying out put a layer of brake fluid or oil on.
06-22-2004, 06:56 PM | #5 |
i would do the brakes now while it's easier access
the other thing i've learned about my 2year projects is to allow at least 4 to 5 years to get them done
06-22-2004, 06:58 PM | #6 | |
Very true, at least double the time you think it will get done in. |
06-22-2004, 07:05 PM | #7 |
if you do put all the brake stuff on now DO NOT put brake fluid in and bleed the system you can bolt everything on just leave it empty. when brake fluid sits in one for long periods of time it does bad things to rubber hoses seals and so on swells them and will basically eat them away.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
06-22-2004, 07:07 PM | #8 |
thanks for the insight guys I think I will finish the frame first brakes and all
06-22-2004, 07:52 PM | #9 |
Designated A-hole!
I knew if I posted here everyone would jump on to tell you what was wrong with what I said!
06-22-2004, 09:27 PM | #10 |
Don't worry, you will learn some day :p :p :p :p :p
06-22-2004, 09:38 PM | #11 |
Designated A-hole!
At least the man got some answers, that's more important than my puny ego!
06-22-2004, 10:23 PM | #12 |
Before and After
I can't see how the fluid will harm the system. My truck has had brake fluid in it for 32 years.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
