09-28-2020, 09:47 AM | #1 |
Transmission whine, Help please
I have a 1968 c10 long bed. It has a 350 that was swapped into it sometime since then and possibly the original Saginaw 3 on the tree transmission. Lately the transmission has been making a high pitch whine that can be heard clearely in the cab and seems to come from the dash or underneath. It is not easily heard from the engine bay or underneath the truck but I assume it is coming from the transmission. It starts to make the sound around 2k RPM and up in all gears and it increases and decreases in pitch with RPM. It makes the same sound in neutral and in gear with the clutch disengaged (petal to the floor). Aside from the sound the transmission and clutch work great. No grinding noises, not harsh shifts, no slipping, strong clutch petal feel and engagement. If it were not for the noise there would be no issue. The transmission fluid was a little low, I put about half a quart in it to top it off and the sound remains the same. I have not noticed any burning smells or otherwise. I'm thinking it could be a bearing going bad (pilot bearing was my guess since it makes the noise with the clutch disengaged) and I would like to replace it before it damages the transmission if that is the case. Does anyone have any ideas? I will link a video below.
Thanks |
09-28-2020, 02:43 PM | #2 |
Re: Transmission whine, Help please
Welcome aboard! Unfortunately I don't think I have good news. It sounds like you have a imput shaft bearing going bad. If you had to add a quart the transmission was at least half empty. It may just make noise for the next 10,000 miles slowly getting louder or it could seize at some point. Fortunately if you are going to change the throw out bearing you can do the imput shaft bearing at the same time.
If your not comfortable with opening up a gear box here is a link to gearbox videos. I don't know if he has a specific 3 speed Saginaw video but there are as at least 50 videos on his channel so you could find one. None the less watching the Muncie videos will give you familiarity with how they work and are assembled. Good luck! https://youtu.be/zqeatqmnW0c
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-28-2020, 04:59 PM | #3 | |
09-28-2020, 09:55 PM | #4 |
If the truck is sitting still during the above condition, it's not the transmission.. With engine running, transmission in gear, and clutch disengaged, Nothing inside the transmission is rotating.. If the noise doesn't stop when the clutch is engaged, it's NOT the pilot bearing as the input shaft will be spinning the same speed as the crankshaft.. My money is on a bad throw-out bearing....
09-29-2020, 11:33 AM | #5 | |
10-06-2020, 11:36 AM | #6 | |
10-06-2020, 01:43 PM | #7 |
Good to hear you got it solved and thanks for posting your success.
10-06-2020, 01:45 PM | #8 |
10-06-2020, 07:48 PM | #9 |
YES!!! And thanks for posting that you got the problem solved.. Most of the time the "problem solvers" are left hanging, not knowing the outcome....
10-06-2020, 07:50 PM | #10 |
