SPID with no model or wheel base length
Been looking at a 67 shortbed, truck is old and looks to be all original, SPID looks to be old and all original, but no where on the SPID does it show the model or the wheelbase length. I have never seen one that doesn't show the wheelbase, anyone else know if thats the case sometimes on some of these SPID stickers?
![]() Join Date: Dec 2009
Re: SPID with no model or wheel base length
Here's the out in the shop link below.
There was 4 styles of SPID's. The Model and wheel base was sometimes typed in and sometimes left out. Look at style D on Jeff's site Here is a picture of style C from Jeff's site. He does a great job on the reprints. Link: http://outintheshop.com/2.html .
#3 | |
Ok, thanks. I was just a little worried since it didn't specify model or wheelbase.
landarts
![]() Join Date: May 2005
Decode the vin number that will tell you if it is a longbed or shortbed. If the 4th and 5th digit is 57 then shortbed, if it is 59 then it is longbed.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
Roadtrip!
![]() Join Date: Feb 2003
Looks like an original 67 SPID to me. I know some of the 67s, especially GMCs, didn't come with a spid.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
As mentioned above the VIN will tell.
Here is the link for vin decode Link: http://outintheshop.com/vin_decode.html .
#8 | |
I dont think the vin will tell you on a chevrolet, maybe GMC, but not Chevrolet.
#9 | |
Chevy with _ _ _ 07 _______ is short bed according to this. {All 1967 through 1972 Chevrolet 10 thruough 30 series trucks are identified by this model designation system. It consists of 7 charactors, 2 letters followed by 5 numbers. The first letter identifies the chassis type and the second identifies the engine type. The first number designates the GVW range, the second and third identify the cab-to-axle dimension and the last two identify the body and brake type.} .
#10 | |
I posted the SPID that shows the vin at the top of the thread. That diagram apparently isn't for Chevrolets...or at least not a 67 chevrolet.
![]() Join Date: Dec 2013
I just looked at 2 of my 67's vin plates / titles and spids
CE147A100000 CS147B100000 So there's no mention of wheel base or model # just the vin and paint code . the titles just list the vin . No wheel base or color ![]() The way I read it is C = 2wd E = V8 1 = 1/2 ton 4 = Pickup 7 = 1967 A = Atlanta build https://67-72chevytrucks.com/vboard/...d.php?t=160357 1967-1969 Vin break down (chev and gmcs) series 10-30 only first letter is the chassis type(see codes for model break down) second letter is the engine type(see codes for model break down) third is a number=gvw range (see codes for series id in model code break down) fourth is a number=model code model codes are;2=chassis/cowl/bus,3=chassis cab,4=pick-up,5=panel,6=carryall(suburban)9=stake side fifth is a number =model year if the number is a; 7=1967 8=1968 9=1969 sixth is a number or on caniadan made truck it is a number=assembly plant Assembly plant codes A=atlanta N=norwood B=baltimore P=pontiac F=flint S=st.louis z=fremont T=tarrytown J=janesville 1=oshawa
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 10-03-2020 at 03:36 PM. |
#12 | |
![]() Join Date: Oct 2009
Wheelbase was not listed on 67 SPIDs.
You cannot determine wheelbase from a VIN - only from the model number. I personally have never seen a 67 SPID without a model number listed, but yours certainly appears to be an original SPID. If you can't view it in person and check out the frame, I'd ask for a picture of the frame in the areas where they are usually cut. Btw, your truck was originally painted with an off white top over a dark green body. |
Here's the SPID from my '67 stepper. It is original to the truck. Note the model number in the description column.
#15 |
Here's the spid from one of my 67"s with no model # . Never say never ,
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#16 |
Here is a better picture.
#17 |
Here is the truck Black on black 67 .
#18 |
Yep, agree, never say never. I've just never seen one before - and now I've seen two! Great info. Appears same plant (kinda hard to read the character on both?) and also noticed the typeset for the options is set at the very, very top of the white space on both. OP's truck and Grumpy's are relatively closely spaced on the assembly line.
#19 |
All about them K’s
![]() Join Date: Jun 2014
Aww come on Grumpy... that’s obviously a fake spid
![]() It’s amazing to me that after all the time I spend on here stuff like this comes up from time to time and just makes me realize there’s still a ton of stuff about these trucks I don’t know. Great thread guys. I agree all of the spids in these pictures(even grumpy’s) look original.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#20 |
Both trucks were built in Baltimore , Just another 1967 one year only ( part )
#21 |
I have learned a-lot just from this thread.
I got Slammed (from a member) in a PM about my comments. I was just trying to help with little bit of knowledge I have to try to keep the thread going for an answer for the OP . Bruceman has a great documentation . Link: http://67-72chevytrucks.com/vboard/s...d.php?t=570059 .
#22 |
Tell keyboard Superman he needs to slam this thread with his superior wealth of knowledge.
#23 | |
![]() Not going to mention any names. I don't want to be (Sideways) ![]() .
#24 |
Here's some good info on all years .
![]() https://www.gmheritagecenter.com/gm-...tion-kits.html and the 67's https://www.gmheritagecenter.com/doc...olet-Truck.pdf
