Old 10-14-2020, 10:46 PM   #1
70StepsideC10
Oil pressure gauge needle not on zero at rest
I recently picked up a bunch of used gauges, one of which is an 80lb oil pressure gauge. The gauge is not installed in the truck yet. The needle rests at about 15lbs rather than zero. I tested the gauge with my compressor, and it works fairly accurately, but off by 15lbs (35lbs when actually 20, 65lbs when actually 50 etc). I thought maybe the needle had just got moved on the shaft, but I tried holding the shaft and rotating the needle but it would not budge. Does anyone know how I can get the needle back to zero? Is there something on the gauge mechanism that can bend causing the needle to be off? The alternative would be to pull the needle off and just reposition it at zero, how would I go about removing the needle without damaging anything (it seems to be on there pretty tight).
70StepsideC10 is offline   Reply With Quote
Old 10-15-2020, 01:34 PM   #2
fatbass
fatbass's Avatar
Re: Oil pressure gauge needle not on zero at rest
Bump. My oil pressure gage reads in the middle of the scale when engine is off and goes off-scale when pressurized. Afraid to twist it. The last thing I want is a kinked or ruptured oil pressure line.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 10-16-2020, 06:08 PM   #3
garyd1961
I'm just guessing here but it sounds like the gauge is shot. I would check the line for kinks and make sure it's not clogged. Also before I replaced the gauge I would try spraying a little carb or brake cleaner in the gauge where the line connects to flush out any trash or crud in the gauge.
garyd1961 is offline   Reply With Quote
