12-09-2020, 03:34 PM | #426 | |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
12-09-2020, 03:35 PM | #427 | |
I will be leaning on Scoti for some advice also. |
12-09-2020, 03:37 PM | #428 | |
12-09-2020, 03:48 PM | #429 | |
So inside the cab behind the seats and tucked as close as possible to the rear corners of the cab down bars that will connect to the Frame, going through the cab floor. Somewhere near the floor, install heavy duty tubing connectors, they are like solid steel cut in half and then connect together by bolted connection, then the bar will go as high as possible to the roof then bend to connect to the other side, above the windshield if possible. Then in-between the two down tubes in the corner of cab, just below the ledge that is along the back of the cab have a cross bar that the harness could mount to and then look at cross bracing that bar down to the lower parts of the side bars, then if needed another crossbar above the back of the seats for bracing as needed to make the roll bar functional. Then up top on top cross bar, have another bar exist each side of the cab to the outside - Straight - then angle down to the bed area to a place that makes sense and connect to the frame. Some point in the these bars have those tubbing connectors so that i can remove the cab if needed in the future. Also have some cross bracing in these two angled bars to the bed. Not sure if that helps or not, but please give me your feedback, anyone. |
12-09-2020, 03:57 PM | #430 |
please excuse my drawing.... sad too i am a drafter by trade and i produce this... lol but it is quick and easy.... rough idea please give input though
12-09-2020, 05:24 PM | #431 |
Is your goal/desire to have this as a track 'legal' set-up or other?
I know you did standard cab mounting parts (isolators/bushings) & location mounts. For an effective bar/cage set-up, it will require rigid mounting @ all points.
12-09-2020, 05:34 PM | #432 | |
That make sense? |
12-09-2020, 06:16 PM | #433 | |
http://autoweldchassis.com |
12-09-2020, 06:20 PM | #434 | |
A roll-bar for roll-over protection (cab roof caving in) & harness anchors can be attached to plates welded to the floor & function in that described manor. If you want to pass bars through the cab wall, all anchor points need to match. How dead-set are you on the 'pass-through' bars to the rear frame section?
12-09-2020, 06:39 PM | #435 | |
I think i understand what you are getting at though. Hmmm... |
12-09-2020, 06:40 PM | #436 | |
12-09-2020, 07:17 PM | #437 |
I think i know what you are getting at Scoti. The bed is on bushings that will allow it to flex and move slightly independent of the frame, so anything attached to the frame will only move with the frame, so counter movements could cause damage. Damn, that could be bad. Even if i was to extend out to the bed, it is separated from the cab and can move independent of the cab also.... I think i am learning here.... So I think your idea is to just install a roll bar inside the cab, only attached to the cab, then the seatbelt shoulder straps could attach to that. I think this is what you are referring to.
Damn, great point.... so... maybe i ditch the whole idea of rollcage. I say this now also because that then interferers with my ideas for a boom box behind the seats in the area.... damn, i am learning all kinds of things today.... lol |
12-09-2020, 07:20 PM | #438 | |
Rear suspension type won't matter here. You are correct in that NVH harmonics will transfer on a solid mount set-up. This kind-of 'un-does' some of your efforts/upgrades to make for a better driving experience (interior metal dampening; noise reduction materials). I hate to say it but I think you 'gotta draw a line in the sand & choose between a good all-around driver or an occasional weekend warrior. Build toward that choice. I would reach out to Level 7 Motorsports (https://www.levelsevenmotorsports.com/). He/they are building some of the best pro-touring classic trucks on the road & tracks. This is no corner-cutting shop either. I would ask for his insight on your cage idea & get his feedback. For reference, here's his Squarebody build w/a similar set-up & the way I would go about it so it's less of a visual thing & more of a legit performance addition. . . .....
12-09-2020, 07:23 PM | #439 |
His cab is solid mounted (circled red) & you can clearly see where the gusseting effort that went into mounting the rear bars so they solidly tie into the frame rail.
Also note the oversized hole for clearance (also circled red) since the cab & bed are two separate structures. You could possibly not have to worry about that if the bars are attached @ the top of the loop....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-09-2020 at 07:30 PM. |
12-09-2020, 07:34 PM | #440 |
Yep, I get it now. Damn, Thank you so much for this insight. I would have made a major bobo without your input.
I am making the decision to not install the roll bar connected to the inside of the cab. So now that this is over.... LOL i will start to look at my boom box design now that there will be little to no issues with a roll bar.. lol I still may look at a way to install a bar just to mount a set of shoulder straps to for seatbelts.... maybe.... i do not that there is a truck on here that did just this... i will see if i saved his pic. |
12-09-2020, 07:38 PM | #441 | |
That combo won't stiffen the chassis (make it better) but it would offer/increase 'roll-over' protection but even then your head can hit the hoop which defeats the purpose. This is why street cars should not have cages.... because you're not wearing an approved helmet on the street like you are @ the track.
12-09-2020, 09:46 PM | #442 | |
This is exactly what i was talking about earlier in my little rant. This is the best example of how to respond to a crazy idea that i had but in a very constructive way! So I really appreciate you for that. You saved me from a major mistake and did so in a constructive way. i swear i owe a few of you on here a drink or two some day... LOL I am going to get the seats mounted and test fitted and see what i have to work with after that. Then go with idea on roll bar or maybe just a Harness bar, or maybe no bar.... Last edited by 88Stanger; 12-10-2020 at 11:08 AM. |
12-10-2020, 09:43 PM | #443 |
Update of Seats mounted
12-10-2020, 09:44 PM | #444 |
more:
12-10-2020, 09:45 PM | #445 |
few more with measurements...
12-10-2020, 09:47 PM | #446 |
and yet more... lol
12-10-2020, 09:50 PM | #447 |
last batch.... lol
Sits really nice not to tall, and the steering wheel should have plenty of room. Sit back a good distance also, so all in all should work good. I am thinking about install just a single loop for the Shoulder Harness attachments, then sub box in between that.... make more measurements this weekend and get an official plan then... But taking any suggestions and or comments..... |
12-14-2020, 07:01 PM | #448 |
Well seems like i may have some additional time at home for about 10 days..... damnit... yes, I tested Positive for Covid. I was helping whom i call my sister and her husband move furniture for new carpet and her brother does not help moving, but is there and well now they all have it, I got tested and poof... Positive... damnit. With that said, so far and it is have been a few days, I am not to bad... a bit tired and beat, somewhat dry cough and that feeling of helplessness because there is nothing you can really do unless you are really bad off but just work through it... So, that is what i am doing. Not sure what or how much i can do on the truck, but i will try to do what i can.
Idea is to get the cab ready for good base high build primer and get main body work done... Then get inside cab ready for POR15 on floor, then sound mat installed, then inside paint done... So God willing, I will get some of that done in the next 7 to 10 days....
John 3:16 - Saved me... God Bless |
12-14-2020, 07:26 PM | #449 |
Bummer deal....
12-14-2020, 07:38 PM | #450 |
yep... but what can you do... Pray it all goes good... God has it now...
So far, nothing to bad....
