Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-22-2020, 07:23 PM   #701
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
Originally Posted by Burb View Post
Is the motor the only thing you pulling out of that donor?
its an 01? so it should be dbc. so im thinking at least motor trans pcm engine harness. not sure yet about anything else. what ya lookin for?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-23-2020, 11:42 PM   #702
kev2809
low n' slo
kev2809's Avatar
quick question, i have everything unbolted and unplugged, ready to pull out....except the driveshaft. im having a huge mental lapse with pulling this driveshaft. is this the kind of ujoint that needs to be pressed out? i removed the clips but the damn u joint doesnt move at all.
-_--_--_ _________
Old 12-24-2020, 01:31 AM   #703
LockDoc
The Older Generation
LockDoc's Avatar
I can't remember what you have there. Does that shaft just pull out of the tail housing or does it have a nut on it? Do you have the other end of the shaft loose? You are probably not going to get that u-joint apart while it is still under the truck.
LockDoc
Leon
Old 12-24-2020, 01:35 AM   #704
kev2809
low n' slo
kev2809's Avatar
LockDoc
ill check in the AM but i believe it slips out, i dont remember seeing a nut. and nope, other end is still intact
-_--_--_ _________
Old 12-24-2020, 01:38 AM   #705
LockDoc
LockDoc's Avatar
Then you will have to unbolt the other end and unbolt the carrier bearing bracket if it has one and pull the shaft out of the tail housing.
LockDoc
Leon
Old 12-24-2020, 01:41 AM   #706
kev2809
low n' slo
kev2809's Avatar
LockDoc
ill have a look in the morning. i dont think ive ever pulled this driveshaft but i couldve sworn i had the trans out before
-_--_--_ _________
Old 12-24-2020, 03:55 PM   #707
kev2809
low n' slo
kev2809's Avatar
LockDoc
guess that was the easiest way! i dont know why i was trying to avoid removing the driveshaft, it will need to come out anyways.
-_--_--_ _________
Old 12-25-2020, 02:11 AM   #708
LockDoc
LockDoc's Avatar
It really isn't too bad to remove them, just takes a little time.
LockDoc
Leon
Old 12-26-2020, 01:09 PM   #709
kev2809
low n' slo
kev2809's Avatar
well, i feel like rewinded 5 years but it will be worth it in the end....plus i can do some things to the inner sides of these panels i should of done the 1st time.
used this tiny truck to pull the motor out
*edit* i dont know why these pics always turn out sideways
-_--_--_ _________
Old 12-30-2020, 11:14 PM   #710
kev2809
low n' slo
kev2809's Avatar
found a knock off holley 302-2 pan kit for the motor. trying to stock pile some stuff together for now.
https://www.ebay.com/itm/402091342885
also, going with this 21 circuit rewire kit off amazon. basically a knock off of the EZ wire kit. i know, its not a big name brand, but im on a budget here and hope it works out
-_--_--_ _________
Old 12-31-2020, 11:08 AM   #711
LockDoc
LockDoc's Avatar
The wiring kit may be a little more work but it shouldn't be that hard to get sorted out if you have the old one to lay out and duplicate.
Let us know how it works out.
LockDoc
Leon
Old 12-31-2020, 11:27 AM   #712
kev2809
low n' slo
kev2809's Avatar
LockDoc
oh, im sure ill be asking questions here lol. i plan to take pictures of everything i mount or attatch. not really a how to, but hey this is what i did kind of thing. ive been reading a lot on here about the ls swaps and wiring. i wont know what exactly ill be reusing off the old harness until i see what this one has. from the pictures it looks like it has a lot of our original plugs though
-_--_--_ _________
Old 01-01-2021, 10:48 PM   #713
kev2809
low n' slo
kev2809's Avatar
just ordered these, hope they work out
-_--_--_ _________
Old 01-07-2021, 06:25 PM   #714
Burb
Coordinator of Synchronicity
Burb's Avatar
Hey Kevin, were you running a York
motor mounted compressor for your suspension?
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 01-07-2021, 08:33 PM   #715
kev2809
low n' slo
kev2809's Avatar
i had one on yes, with the small block. but i decided not to run it with the ls swap. i ran it a few times and it pumped super fast...but for some reason oil would spill out of the filter if i remember correctly. i think it might be in the build somewhere...i dont remember. its been about 4 or 5 years i think.
i still have it if ya want it, im gonna to start cleaning stuff up around here and trashing whatever doesnt sell. yard starting to look like sanford and son
-_--_--_ _________
Old 01-20-2021, 11:54 AM   #716
Burb
Burb's Avatar
LOL nothing out of an '01 , was just wondering.
Rick
Old 05-27-2021, 12:47 PM   #717
Burb
Burb's Avatar
Nudge ... Hey Kev
Rick
Old 06-05-2021, 08:20 AM   #718
kev2809
low n' slo
kev2809's Avatar
Nudge ... Hey Kev
heyyyyy....
no updates yet, been putting a little money in my avalanche but about to get started on the suburban again soon hopefully. been doing some remodeling in my house also, floor guy is supposed to come this week. either way I have no choice to at least get my motor in by October, as the city now all of a sudden wants my neighborhood (non HOA by the way) to not have any "junk vehicles" unless they are behind a fence. soooo, had to spend 400 to make a fence around my suburban, and have until October to get rid of the donor vehicle.
-_--_--_ _________
Old 09-21-2021, 09:00 PM   #719
kev2809
low n' slo
kev2809's Avatar
finally a little progress....somewhat. drove my donor truck in the driveway and started the teardown. I been picking at it since Sunday but I'm hoping to have the drive train out by next week. meanwhile, after pulling the intake... this motor looks filthy
-_--_--_ _________
Old 09-26-2021, 09:41 PM   #720
kev2809
low n' slo
kev2809's Avatar
heeyyyyyy got my motor and trans out the donor and on the ground. went and bought my engine stand from northern tool today so hopefully will get it on the stand this week and start the teardown
-_--_--_ _________
Old 09-27-2021, 08:32 AM   #721
LockDoc
LockDoc's Avatar
Sounds good!
It all takes time, especially if you are still working. I started on a new project too and have had some interruptions. Just keep plugging away at it a little bit at a time and before you know it you will be driving it.
LockDoc
Leon
Old 10-02-2021, 02:50 PM   #722
kev2809
low n' slo
kev2809's Avatar
huge setback with this motor...was draining the oil to get it on the stand and a ton of milkshake came out....kind of down to 2 options now. called my buddy where I got it from and he said he has another 2001 tahoe I could get. but I have to sell what I have and whatever I get would go to him for the other truck. other option would be to pull the heads and send them to get rebuilt and/or pressure tested for cracks or warps.
-_--_--_ _________
Old 10-02-2021, 07:58 PM   #723
LockDoc
LockDoc's Avatar
Well that sucks. Maybe it will be something simple like a gasket or "O" ring somewhere. I know that isn't really simple either but maybe you won't have to pull the whole thing....
LockDoc
Leon
Old 10-03-2021, 09:39 PM   #724
HO455
HO455's Avatar
UHGGGGGGG!!!! Man that just blows. .
Personally I would probably pull the heads and have them checked then I would know what kind of shape the cylinders are in. And of course I wouldn't be able to NOT pull the oil pan and inspect the oil pump. The evil demon "Project Creep" has arisen again.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 10-03-2021, 10:11 PM   #725
kev2809
low n' slo
kev2809's Avatar
haha yup. well, I would've pulled the heads over the weekend but ima kind of see how the sale on it goes. if I didn't have the other truck as my other option I would dive deeper into this one.
I started of the frame clean up to keep me busy
-_--_--_ _________
