12-31-2020, 03:48 PM | #1 |
Wiper switch
Does the wiper switch on a 78 have the function of pushing it in to spray fluid? Mine has a separate button to spray and it looks like it has been added be the previous owner. I have a replacement bezel and there is no hole for the spray on the replacement.
Thanks guys
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
12-31-2020, 07:09 PM | #2 | |
Re: Wiper switch
Yes they do. Just get the right one for your option and year.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
12-31-2020, 07:42 PM | #3 |
Awesome thanks for the reply. Might have a busted switch that needs replacing.
Thanks again Posted via Mobile Device |
12-31-2020, 08:00 PM | #4 |
Re: Wiper switch
Might trace out the washer lines and make sure there isn't a PO added washer pump somewhere under the hood. A lot of folks, myself included, have added an aftermarket washer pump after the OEM wiper motor driven pump died. I found a way to use the OEM push to spray washer switch in the existing wiper switch.
Sounds like your PO may have found an alternative solution. |
