#351 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: New 64 Stepper Project
Thanks 88 Stanger.
I may have a line on new 200R4 sheet-metal torque converter dust covers. I'll find out for sure Monday. Nobody has those. Wiring up the engine compartment now.
#352 |
![]() Join Date: Sep 2020
#353 |
Moderator
I think so. You have to mount the lift arm super close to the tool for it to work without removing the hood.
#354 |
Be sure to share if you find something.
#355 |
Moderator
May not look like I've done mush but it's tedious work. Yesterday and today.
#356 |
Looks really good...tedious is right getting all the looms how you want them!
#357 | |
But for the 1966 C10 i rebuilt my 383 motor and added some goodies and going to run the fi-tech on it. I have a mechanic buddy who is a die hard fi-tech guy so i have a good helping hand if i need it.
John 3:16 - Saved me... God Bless |
#358 |
Moderator
Street Demon.
#359 |
Nice! I would venture to say inspiring. Perhaps you could share details on your ignition system?
-JDH Insomnia is a terrible thing to waste https://www.youtube.com/watch?v=jWYVs7widI0 (Misanthropic curmudgeon attempts starting old truck in house at 2AM) |
#360 |
Moderator
40,000V Coil, Small Body HEI. Nothing fancy.
#361 |
Oh ok, i see now. It was hard to tell from the pic, looks just like my fi-tech. The Demon should work great, i like them.
Motor work looks fantastic sir! very nice work... Give me inspiration to get my butt in gear and get mine done.
#362 |
Looking good, what valve covers are you running?
#363 |
Moderator
I think there from CFR? Chrome Aluminum Finned.
#364 |
Moderator
Okay, I worked for two days trying to get the TV Cable/Bracket geometry correct for the Extreme Automatics 200R4. I was finally successful and it is repeatable. I had an old bracket from the cruise control to work with. I don't think I'll be removing it to get it plated or powder-coated.
![]() Looks like hammered cat sh#t but it works.
#365 |
I'm just glad to be here!
Looks fine, but I would take it off to at least rattle can it. If you leave it alone, it will rust and look worse against all your polished & chrome goodies..
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#366 |
Moderator
My plan is to get in there with a Testors paint brush in the morning.
#367 |
Happy to see you check plunger depth, its not a fun ordeal, but you should enjoy the outcome......nice build....
#368 | |
Moderator
It's kind of a requirement according to Extreme. I do understand why though.
#369 | |
Moderator
#370 |
There ya go!! Way to not let that thing beat you, or give in to peer pressure... lol Looks good!!
#371 |
Moderator
Got the trans dust cover pan in today. There was an ear on the starter side that needed to be flattened down, not sure why it was there. One of the holes elongated when installing. Not a perfect piece but then again, there is nothing else out there for the 200-4R. Off to the powder coater it went with the PML Trans Pan. So the Oil Pan Dust Cover and Trans Pan will match.
#372 |
Moderator
Got the distributor ends of the plug wires terminated.
#373 |
What's the 411 on the Demon set-up? Are they square bore or spread? Any other specifics?
#374 | |
Moderator
#375 |
Moderator
More work today, still working on the details but you get the idea.
