Old 04-05-2021, 10:03 PM   #76
JJH Jimmy
JJH Jimmy's Avatar
Re: Budget Build 1985 K20
Got the cab and inner fenders in epoxy.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 04-05-2021, 10:08 PM   #77
JJH Jimmy
JJH Jimmy's Avatar
Then put Raptor Liner on the bottom of the cab and on the wheel side of the inner fenders. I also put Raptor Liner on the bottom of the tub and inner fenders of my Jimmy and with well over 10k miles not one chip and still looks great.
1985 Chevy K20
1994 GMC Yukon
Old 04-06-2021, 04:15 AM   #78
LT7A
Good progress. It looks like the raptor liner layer out nicely.
Old 04-16-2021, 08:48 PM   #79
JJH Jimmy
JJH Jimmy's Avatar
Yea it did. Thanks. I am afraid that progress is going to slow down. I got a ton of spring cores around the house to get done.
1985 Chevy K20
1994 GMC Yukon
Old 04-16-2021, 08:55 PM   #80
JJH Jimmy
JJH Jimmy's Avatar
I did get all the body work on the cab done and into 2k primer. Like everything on this truck way more small dents than anticipated. It appeared someone sat on the roof at some point!
1985 Chevy K20
1994 GMC Yukon
Old 04-16-2021, 09:01 PM   #81
JJH Jimmy
JJH Jimmy's Avatar
I also ordered my clear coat and base. It took me forever to decide what SPI clear coat to go with but I finally settled on the Euro over the universal. This is what $1,200 looks like and I’m not sure if it will be enough for the whole truck!
1985 Chevy K20
1994 GMC Yukon
Old 04-16-2021, 09:11 PM   #82
Greenlee
Greenlee's Avatar
Nice work! Yep, looks like a butt size dent.
Greenlee is offline   Reply With Quote
Old 04-22-2021, 01:11 PM   #83
OutlawDrifter
Awesome work, just joining the build!
This K20 is going to be too nice to drive when you're done!
I'm a big fan of Raptor Liner, I've been using it for about 10 years.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 04-24-2021, 07:45 PM   #84
JJH Jimmy
JJH Jimmy's Avatar
Thanks!
Thank you! I hope it not to nice to drive but it’s heading in that direction.
1985 Chevy K20
1994 GMC Yukon
Old 04-24-2021, 07:56 PM   #85
JJH Jimmy
JJH Jimmy's Avatar
I tested out the base and clear on the glove box door, ash tray, lower column cover, door have hinges, tailgate hardware and bolts. Everything turned out great. Now it’s time for some bigger pieces.
1985 Chevy K20
1994 GMC Yukon
Old 04-24-2021, 11:17 PM   #86
Greenlee
Greenlee's Avatar
Looks great!
Old 04-24-2021, 11:23 PM   #87
OutlawDrifter
Nice work!
1991 Z/28, 6.0L/T56
Old 04-27-2021, 09:11 PM   #88
JJH Jimmy
JJH Jimmy's Avatar
Fenders, cowl and bumper filler block to 400, washed masked then sealer.
1985 Chevy K20
1994 GMC Yukon
Old 04-27-2021, 09:22 PM   #89
JJH Jimmy
JJH Jimmy's Avatar
3 coats of 029 midnight blue base and 4 coats of euro clear. Turned out really nice. A little bit of dust nibs in the clear that I will need to sand out and just a touch of orange peel. I think a quick buff and onto the doors!
1985 Chevy K20
1994 GMC Yukon
Old 04-27-2021, 09:39 PM   #90
OutlawDrifter
Looks good!
1991 Z/28, 6.0L/T56
Old 04-28-2021, 03:00 PM   #91
LEEVON
Moderator
LEEVON's Avatar
Love the midnight blue, glad you went that route!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-28-2021, 03:21 PM   #92
WilliamFd55
Great color!!
WilliamFd55 is offline   Reply With Quote
Old 05-02-2021, 08:54 PM   #93
JJH Jimmy
JJH Jimmy's Avatar
Looks good!
Originally Posted by WilliamFd55 View Post
Great color!!
Thanks! I really like the color too. And it saved me about $500 a gallon going midnight blue over apple red.
1985 Chevy K20
1994 GMC Yukon
Old 05-02-2021, 09:03 PM   #94
JJH Jimmy
JJH Jimmy's Avatar
Didn’t get as much done as I wanted this weekend but me and my shop buddy did get the the fenders sanded and buffed. I just hit the trash with 1000 grit then the whole fender with 1500 then 2000. I then buffed them with a wool pad with cutting compound then hit them with a foam finishing pad and polishing compound they turned out better than I expected. I hope the rest of the rig turns out as good as the fenders did.
1985 Chevy K20
1994 GMC Yukon
Old 05-02-2021, 09:09 PM   #95
OutlawDrifter
Great job on the finish work, nice crisp reflections!
1991 Z/28, 6.0L/T56
Old 05-25-2021, 10:29 PM   #96
JJH Jimmy
JJH Jimmy's Avatar
Finally got the doors and the hood sanded and painted. After the buffer got away from me on the edge of the hood I ended up having to sand them spot in some base and re clear. Ugh! Lesson learned - tape the edges!
1985 Chevy K20
1994 GMC Yukon
Old 05-25-2021, 10:32 PM   #97
JJH Jimmy
JJH Jimmy's Avatar
I also got a new daily!
1985 Chevy K20
1994 GMC Yukon
Old 07-21-2021, 03:35 PM   #98
JJH Jimmy
JJH Jimmy's Avatar
It has been a while since i last updated and i wish i could say that i have made a ton of progress but life gets in the way. I did get the inside of the cab painted, floor pans raptor lined and all finish sanding completed on the exterior of the cab and then i partially tore my achilles tendon. So this is how she sits now.
1985 Chevy K20
1994 GMC Yukon
Old 07-21-2021, 03:40 PM   #99
JJH Jimmy
JJH Jimmy's Avatar
I have started to feel better lately and can kind of get around with out the use of crutches so i have been trying to tackle some smaller projects that i can work on sitting down.
I rebuilt the hyrdobooster i got from a local pick and pull and fixed a EGT probe hole in the headers i plan on using.
1985 Chevy K20
1994 GMC Yukon
Old 07-21-2021, 03:44 PM   #100
JJH Jimmy
JJH Jimmy's Avatar
I also started rebuilding my vent windows. The first task was to weld the pivot stud back on.
1985 Chevy K20
1994 GMC Yukon
