Old 05-05-2021, 11:13 AM   #176
daddyjeep
daddyjeep's Avatar
Re: Project: Tow-Rat (Lil' Blue)
Looks like you are just about to put the sheet metal behind you. The tunnel looks good. The lines flow nicely.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-05-2021, 01:58 PM   #177
lower50's
lower50's's Avatar
Originally Posted by daddyjeep View Post
It was cool to get together and abuse the Jeeps last weekend. Now we just need to get that Canadian guy to come down.
Ya that would be great but I don't think it will be this year as the borders are still closed.
I did get my Jeep out to a local gravel pit last weekend tho. Took my son and his freshly built CJ6.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-07-2021, 08:32 AM   #178
daddyjeep
daddyjeep's Avatar
Attachment 2100074
Nice. I'm glad you at least got to get out and wheel.
04 1500 crew cab
Old 05-09-2021, 10:31 AM   #179
Gregski
Gregski's Avatar
Dang, fab skillz to pay da billz, fer sure!
Gregski is offline   Reply With Quote
Old 05-11-2021, 09:07 AM   #180
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on the trans tunnel! I've got to do one in my 1940 Ford and I need to set down and figure out how to lay out the angles and technical stuff so it can look nice like yours instead of a card board box smashed to fit the not square or round opening.
The 69 Camaro sounds awesome! A lot of history there, if you have the time start a thread on that.
Nice to see you guys getting together to do some crawling in the Jeeps.
Ryan
1969 Chevy milk truck
Old 05-24-2021, 11:42 AM   #181
6DoF
6DoF's Avatar
ok, i finally stopped slacking as bad and did some work this weekend.
the drivers rear body mount reinforcement wasn't attached any more, so i fixed that. welded some floor cracks under it, wire wheel, Auto Tech rust prep, weld-thru primer, and hot metal glued it back on.
then i set to work on the firewall, more sheet metal i've been dreading. started with smoothing out the rib that ended up under my brake booster, and then continued to fil holes. lots to go, but making progress.
6DoF is offline   Reply With Quote
Old 05-24-2021, 01:30 PM   #182
youngrodder
youngrodder's Avatar
Looks good. Your gaining.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-25-2021, 02:36 PM   #183
daddyjeep
daddyjeep's Avatar
That looks like a good time. Especially when it is 90 degrees out.
04 1500 crew cab
Old 05-25-2021, 02:39 PM   #184
6DoF
6DoF's Avatar
i have AC in my shop now
Old 05-25-2021, 02:42 PM   #185
daddyjeep
daddyjeep's Avatar
Nice.... I just have a beer fridge
04 1500 crew cab
Old 05-25-2021, 05:42 PM   #186
Rickysnickers
For somebody who doesn't like doing sheet metal work, you certainly are good at it.
Old 05-26-2021, 07:43 AM   #187
6DoF
6DoF's Avatar
thank you, i'm trying to take my time to get the details right. it just takes so much time, and i have at least one panel that now has an oil can effect
Old 05-27-2021, 12:32 AM   #188
BC Toy chest
BC Toy chest's Avatar
WOW! One of the most awesome builds on here. Thanks for sharing photos and info gr8 work.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 05-27-2021, 08:31 AM   #189
6DoF
6DoF's Avatar
there are some amazing builds on this site, that's a seriously motivational compliment! thank you!
Old 05-27-2021, 08:34 AM   #190
6DoF
6DoF's Avatar
so i'm still putting off having to do the floor repair, decided to take the firewall a little further tonight. wire wheels, cleaned, Auto Tech Rust Prep, cleaned, and primer to see it in a solid color. a little smoothing here and there, some body caulk, and she'll be ready for the Lizardskin. nothing like a nice textured black coating to hide even more imperfections.
also finished getting the old pedal and steering holes filled, while leaving the new steering hole in place.
Old 05-27-2021, 10:45 AM   #191
youngrodder
The firewall looks great. I too Raptor lined almost every surface. Love that stuff. I think I went thru 8 bottles.
Marc
Old 05-27-2021, 01:54 PM   #192
Gregski
Gregski's Avatar
looking great ! that tunnel should fit a Buick Straight 8 no problem lol
Old 05-28-2021, 08:23 AM   #193
lower50's
lower50's's Avatar
Coming along nicely. Getting stuff installed like the hydra-boost and painting the fire wall are things you can stroke off your list and helps motivate.
I suggest you plan to put a ps cooler in, I found with the hydra boost the oil gets really hot.
1951 MG TD
Old 05-28-2021, 11:10 AM   #194
6DoF
6DoF's Avatar
that's a really good thought ... i was kind of ignoring it for now, but probably shouldn't.
Old 06-01-2021, 07:47 AM   #195
6DoF
6DoF's Avatar
oh man, my cardboard list is getting shorter! i now HAVE to do the floor patch work before anything else on the cab, it's time to dive into the mess ...
fitted up some frame horn caps and gussets cut from extra box tube.
added the axle center pins to the truck arms. 7/16 cap head bolts slightly turned down down in a drill with a grinder, to specifically fit the smallest drill bit size i had that was larger than 1/2" to open up the perches with. then got the shock mounts, bag mounts, and finally the fish plates fully welded on the arms. just a quick gusset to add to each upright on the bag mounts (cuz beef, and cuz why not) to call these 100% done. the axle however now IS done and ready for clean-up n paint.
Old 06-01-2021, 08:52 AM   #196
daddyjeep
daddyjeep's Avatar
Nice.... I didn't get anything productive done in the shop on this long weekend. I went and played in the Jeep instead.
04 1500 crew cab
Old 06-01-2021, 09:00 AM   #197
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Doing a watts link I see? Good stuff!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-01-2021, 10:29 AM   #198
Gregski
Gregski's Avatar
just checking to double make sure we are still building a Chebby truck here or an Abrams M1
Old 06-01-2021, 10:33 AM   #199
6DoF
6DoF's Avatar
um ... yes?
tank burnouts!
Old 06-01-2021, 11:03 PM   #200
lower50's
lower50's's Avatar
1951 MG TD
