Old 05-06-2021, 02:38 PM   #1
Mapearso
Stock Radio Installation Help
Hey Team 67-72
I’m fixin to install the stock GM radio on my 72 Cheyenne Super. I haven’t done this job before but it seems pretty straight forward, especially if I remove the glove box.
Before I get started, I’m wondering if I have all the correct hardware for the install. I think I may be missing one of the cups. If so, can someone please let me know the best place to get the parts I need?
Mapearso is offline   Reply With Quote
Old 05-06-2021, 05:56 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Stock Radio Installation Help
Place a WTB ( want to Buy ) in the classified section . Those parts aren't reproduced .
Old 05-06-2021, 06:21 PM   #3
body bolt
The tuner shaft looks too short. Post a pic with the knob removed.
body bolt is offline   Reply With Quote
Old 05-06-2021, 09:17 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Details on installation:
http://67-72chevytrucks.com/vboard/s...d.php?t=518727
LockDoc
Leon
Old 05-06-2021, 09:40 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
In addition to the second mounting cup, you also need the rear knobs. And you'll need a power wire, speaker with radio plug, speaker mounting bracket, mount on the inside of the firewall, and the radio backstrap bracket.
Yes, I recommend installation by removing the glove box (and a few ducts if you have factory air). I did mine recently--it is straightforward if you have everything.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 05-07-2021, 02:05 PM   #6
Mapearso
Ok thanks guys. Here are some more photos
Old 05-07-2021, 02:07 PM   #7
Mapearso
Pics
Old 05-07-2021, 03:51 PM   #8
body bolt
Originally Posted by Mapearso View Post
Pics
It looks right. The tuner shaft is bit shorter than the volume/tone and I never noticed.
Old 05-07-2021, 05:39 PM   #9
LockDoc
LockDoc's Avatar
Knobs look like they are the wrong ones. Looks like they both have set screws in them. One looks like a wiper knob and one looks like it might be a throttle knob. The radio knobs do not have set screws to hold them on.
LockDoc
Leon
Old 05-07-2021, 05:56 PM   #10
body bolt
LockDoc
The one on the right has a spring and appears to be the correct volume knob but the other does appear to be a wiper knob.
Old 05-08-2021, 12:04 AM   #11
Accelo
Accelo's Avatar
Here are some pictures that may help.
The radios are easy enough to find.
Decent speakers can be purchased new as I did.
Show in the pictures below.
The brackets are a lot more difficult to come by.
When you wire the speaker be sure to get the black (-) on the correct terminal.
You can see the wood spacer that came with the new (reproduction) speaker.
This is so it will fit the bracket correctly. This same speaker was used in many other GM vehicles.
However, the brackets may be specific to the vehicle.
Rick
Accelo is offline   Reply With Quote
Old 05-21-2021, 05:49 PM   #12
Mapearso
So I found these at the swap meet.
Are the “tall” ones correct ?
Also, should the knobs have the metal center? Or are they just black plastic?
Thanks again for all the help!!
Old 05-21-2021, 05:58 PM   #13
HotWheelsFan
HotWheelsFan's Avatar
Not sure about the tall vs short...
I do know the knobs should have the metal insert though. It is a spring type of fitment to the shaft to keep the knob secure to the radio. Even metal raido knobs of that style will have the spring insert on them as well.
Bob
HotWheelsFan is offline   Reply With Quote
Old 05-21-2021, 07:08 PM   #14
body bolt
The short knob with a set screw would make it a wiper knob. Those have no spring insert. The other short one looks like a tuner knob while the 2 tall appear to be volume knobs.
Old 05-21-2021, 11:18 PM   #15
ho70
ho70's Avatar
if you have AC, good luck. I have had to replace my old hoses as they wouldn't allow me to get the radio in. Tried for hours with 4 others trying as well.
ho70 is offline   Reply With Quote
Old 05-22-2021, 12:52 PM   #16
body bolt
I just replaced my radio and had everything out; ash tray/holder and AC/heater controls. The hoses went in last.
