#51 |
Re: My 53 GMC 3/4 ton project
good idea to leave the frustarting things and come back to them. do somethimg you know you can make forward progress on. inside cab looks great, what did you paint it with?
I think a lot of guys grab a pedal they lie from a donor and make it work. they usually have a hard pedal arm so if you plan to bend or drill it then maybe heat it up and let cool first and/or try a cobalt drill bit. on the accel pedal, put the seat in and try it out for fit when sitting in the truck. nothing worse than a weird angle because you get a cramp in your leg on any trips with some seat time. get it in the right place and then wedge the bracket so you get full throttle with your carpet etc in place. its good to have a steering wheel in place as well, even if onlyn mocked up, just to get the feel of things. keep posting your progress, doing great. |
#52 |
![]() Join Date: Sep 2017
The cab is looking good. I can sympathize with the bushing issue.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#53 |
Blue 67
Thanks guys.
The interior paint is Duplicolor acrylic enamel gray spray can. I belive I have mentioned that I am not paint and body man and this is the first of its kind. Besides, I am spending all the money for this project on the drivetrain and suspension for now. I guess I still should sand and buff the paint though! These past couple of days, I worked on gas filler hole. I think it came out decent. The contour matched well ![]()
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
#54 | |
https://www.johnnylawmotors.com/cata...pedal-pad-kits Last edited by 6DoF; 12-13-2021 at 10:10 AM. |
#55 |
Blue 67
Thank you for the pedal information.
I played around with brake booster installation while waiting for this tranny bushing (8 days late!, thanks Fedex!). The hydroboost is the same as what I have used in my Nova LS swap, from late 1990 chevy van. The brake booster is from 2009 chevy Silverado. They say that LS engine doesn't make as much vacuum for brake booster but then, if Chevy is putting this booster with their LS based truck engine, that should work. I think the hydroboost looks cooler, cleaner and for sure create more pressure but, I don't have power steering gear box so, I don't have to have power steering pump unless I use the hydroboost. So, brake booster is easier and less part which equated to less work and less cost. Decision, decisions!! ![]()
#56 |
if running a manual steering box ... i 110% vote for NOT hydro-boost. that's just adding systems that aren't needed. very not KISS. on the other hand i gives you an easier "upgrade" later.
if running manual steering, why not manual brakes!?!? sure they feel different and can take a little more foot, but they work just fine. for a classic ride i feel like manual steering/brakes adds so much to the character of the drive. |
#57 | |
Blue 67
I am in total agreement with you when the whole setup is in stock form which this truck is far from.
#58 |
Blue 67
While I am still waiting for tranny bushing to get here, I keep busy with the inside.
I thought to make something out of the original radio spot without damaging the original cover, just in case I needed in the future. These covers are expensive online! Please ignore the cabinet door knobs! I didn't have anything at that size to cover those holes and the knobs fit great for now ![]()
#59 |
That works! Very nice.
#60 |
Blue 67
#61 |
Blue 67
So, I got the transmission bushing in (finally Fedex!) but now I am inviolved with interior. Here is what is happening with pedals. First, I got the gas pedal where I want it and where it can be:
#62 |
Blue 67
Then, I worked on the brake pedal. With this setup, I can move (adjust) the brake pedal higher/lower and to the left or right. Just in case it doesn't feel uncomfortable when all is done:
#63 |
Blue 67
The final:
#64 |
Blue 67
Okay, Happy New Year to everybody.
Back in business. I finally got the transmission case bushing and put things back together. I also revised my engine mount and crossmember utilizing CPP crossmember that I got. In addition, I got my American Shifter kit and tried to fiddle with it. Here are some pictures:
#65 |
Blue 67
Engine and tranny are in, hopefully for good. I also used CCP tranny cross member. I used 3/16" plates to box the section of the frame which tranny cross member bolts on to create some additional support:
#66 |
Blue 67
Headers: I have these LS swap headers for F-body chevy which seems work great for this project. Of course, it interferes with the steering box but my understanding is all headers or steering boxes need modifications to fit with these projects. Please correct me if I am wrong.
#67 |
I had to fiddle with the steering linkage to avoid headers.
Nice work.
#68 |
Blue 67
So, I have been away from the forum for a little while but not away from the project. Been working on my $150 electric steering conversion project. The steering wheel get closer to the dash which is what I wanted to do anyways to create some more room with newer thicker seats.
#69 |
Blue 67
So, to be able to get the steering column in the proper place, I had to remove the control module box to relocate it. In these Equinox/Saturn electric steering systems, the module is attached to the column.
#70 |
Blue 67
So, I took the brake pedal bracket out to finalize the electric steering bracket:
#71 |
Blue 67
I am using the steering shaft which I got with the unit. Since I have to move the steering box due to its interference with the headers, the shaft doesn't line up with the steering box directly:
#72 |
Blue 67
So, the steering box has nice clearance with the headers but now I have to move the steering shaft access to the cab to the side of the stock location:
#73 |
Blue 67
Next step is adapting the steering shaft to stock steering box. I used a grinder to form the proper shape on the steering box shaft:
#74 |
Blue 67
Some more progress on the electric steering setup. I wanted to use my stock steering wheel. So, I cut the old and new and graft them together. At the end, to make the weld stronger, I welded a 1.5" long tube over the area:
#75 |
Blue 67
Now, my stock steering wheel is on my new electric steering box:
