![]() Join Date: Nov 2018
Best compound for original paint?
I'm hoping someone has a suggestion for the best compound they've used with good results. My paint is original and doesn't appear to have had any buffing/waxing in quite some time. It's not really that chalky but it is oxidized and I've heard not to go too aggressive with the cut unless you need it. I started with Meguiars Ultimate Compound (see picture below), and wasn't that thrilled with results. I'm thinking I need something with more cutting. Thanks for the help.
Re: Best compound for original paint?
There is a lot of good info in this. The long and short of it is that you want to treat the paint first before you go working old dry paint.
https://www.autogeekonline.net/forum...ge-paints.html
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
Chemical guys look them up. alot of videos on line. I bought the 4 step kit and was amazed at what it did for my old no shine paint.
I really like Mothers Carnuba Cleaning Wax,works good on a polisher
![]() Join Date: Apr 2021
I have used liquid Bar Keepers Friend (Purchase at Grocery Store) on some of our older tractors for oxidation then buff out with light polishing compound. It removes the oxidation and cleans surface before buffing. Cuts buffing time by 2/3's and results in a nicer finish. I have also seen people use liquid Comet before buffing on Facebook.
I recommend try a small spot before applying like wax! |
The Older Generation
All I have ever used is Turtle Wax White Polishing Compound by hand. Works good for me. I never use a machine on old oxidized paint. Too much chance of polishing through the paint. If you do that there's no chance of going back..... Here is the hood on the '70 I polished out. I'm not looking for a show shine, just to clean off the oxidation. Your mileage may vary. Just my 2¢ worth. LockDoc
Mr. Cheyenne
![]() Join Date: Jun 2020
Doc, I kind of want that hood/bug deflector....
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
Thanks for the responses. I started with an original paint hood I found in the same color as my Blazer (medium olive). The hood had a ding that went in sharp, and when in did it cracked/flaked the paint. To keep that edge from peeling more I wet sanded down the edges to smooth and feather it back it so it wouldn't keep flaking. Besides the dent, that area looks amazing, almost mirror like shine. The rest of the hood with the compound I posted the picture of above, looks okay, still dull in comparison to the other. I don't really intend to wet sand the entire hood.
Sometimes a light sanding with 2500 or 3000 grit is best . Most modern compound is made for new paints and not aggressive enough . I used a rotory with a lambswool pad on my 68 but I did sand it with 1000 up 3000 paper . Lambswool is much more aggressive than a foam pad . Did you use a cutting pad? rotory buffer or an orbital buffer ? Makes a huge difference with type of buffer and pad choice. After the lambswool I went with a polish bad on the rotory then finished with an orbital buffer. No clear used in the truck just lots of wax after I got it shined up
Thread on my buffing the 68 https://67-72chevytrucks.com/vboard/...d.php?t=822190
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-05-2022 at 12:10 PM. |
That makes me wonder if someone else hadn't tried wet sanding just with a coarser grit. The paint has that cloudy look you get after sanding to remove orange peel. I was using a foam pad, two types actually, one for buffing and one for polishing.
I can't stress enough.. do not sand it!!
choosing a compound will depend on, are you doing it by hand or machine? If by machine..orbital or direct drive? I can help you from there, also what color is the truck? |
Why No sanding ? Stay off the edge just like buffing and lightly sanding with 2500 or 3000 makes it easier to buff . Been doing it for over 40 years that way on old school paint. Either way with a factory metallic paint you can and most likely will get some mottling .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-05-2022 at 07:52 PM. |
Pictures of what your working with would be helpful .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Jan 2011
It really all depends on what's left of the original paint. Does it seem thin in places or primer showing through ?
I too would wet sand, that's really the old way to get the old dead paint and chalky look off of it.. but there's gotta be enough paint there to do it or you'll blow through it pretty quickly. Post up a couple pictures of it and we can help you more.
#15 |
It's medium olive.., here are some pictures. I haven't done anything to the body yet. I recently found an original paint hood (Blazer had some homemade scoop hood when I bought it). All my work so far has been on the hood. Meguiar's Ultimate compound (posted picture at beginning of thread) with a foam pad and rotary buffer. And I've wet sanded a few edges of dings to smooth where the paint had cracked from the dent to keep it from chipping/peeling. That's it. I'm not sure if you can tell from the hood photo which was taken at night. Thanks for all the input.
#16 |
I would never sand it because the paint is less than paper-thin and it is metallic; that color was so translucent when it was new and fresh.
If all you want to do is give it a little shine use a dual action polisher with a light-duty compound and you will be fine. I will say because of the chalkiness of the paint it will get dirty and plug up the buffing bonnet. We all have opinions, but do what works for you after you try it on a test panel. Good luck |
#17 |
![]() Join Date: Jul 2000
As someone suggested above, start with a fine compound and get more aggressive if required. For example, polishing compound before rubbing compound before even 2000 grit sandpaper.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-10-2025 at 12:34 PM. |
#18 |
![]() Join Date: May 2011
Original Medium Olive is a single stage metallic, so you have to know on the front end that when you buff it (using electric rotary buffer), the metal flake will "pile up" and give a mild swirling look. You also have to know that you will be removing a lot of PAINT when buffing, and will more than likely burn through to the primer coat beneath.
That said, I love the look of SHINY original paint, including all of its defects and character. And even a paint job that has been "burned through to primer", can look beautiful.. Here are some pics of my '70 C20 I put some shine back in. Truck came out of Idaho, and was parked outside its' entire life. Not a lot of paint left when I started. Especially on the hood and top sides.... First pic is side shot of how dull she was... And a couple of before/after pics of the hood. |
#19 |
This is how she turned out in the end...
I spent 4 years as a detailer just out of highschool for both Chevrolet and Porsche. I've got a lot of time behind a buffer and trying out different brands of chemicals. My process is 3M Perfect-It line of products finished off with Jescar Powerlock and Collonite Insulator wax as the final step. This particular truck took a LOT OF BUFFING to get the primer to shine, and HOLD the shine. This also meant that there is some bare steel now showing. If I had a dollar for everyone that asks what kind of Clear Coat I used for that "Patina", I'd be a rich man... I was even called a liar for telling a guy that it was just buffed/waxed... ![]() ![]() A coat of Jescar and Collonite keeps the flash-rust at bay on edges and thin spots. I think that your Blazer would look AMAZING all shined up.... |
#20 | |
#21 | |
#22 |
My own approach is that I would rather retain as much paint as possible. At the risk of stating the obvious, when the original paint is gone, there's no getting it back. I think some of the examples here speak to trucks where the finish coat is worn through to the primer in quite a few places already. I want the process to be something I can do once a year without concern. I realize I may not get all of the oxidation off the first time I do it or have an immensely shiny result, but I won't hesitate to do it year after year for as long as I own the truck. Getting it as clean as I can and adding clarity and then protecting it is my approach. So I will put in another vote for the McGuire's number 7. Multiple applications with terry cloth will remove some paint, but will condition the paint that remains. From there, if needed, the ultimate compound that you have has worked well for me. After that, it's just a matter of protecting it with whatever wax or sealer you like best. On any paint without a clear coat, I only work by hand. And while I'm at it, backing up to the beginning, I first use an iron fallout remover which immediately deepens the color and adds clarity by removing decades worth of embedded contamination. Then I use a clay bar to remove contamination that is stuck to the surface of the paint. In my experience, each of these steps adds to the vibrancy of the paint. From there I like the McGuire's number 7 for conditioning and then finishing it out like I talked about above. Even if the paint doesn't end up shiny, the wax or sealer will add luster to it. Good luck!
#23 |
Again, thanks for all of the replies. I'm thinking that my cautious approach didn't take off that much and I need a little more cutting.., but not much. Here is a photo of what the hood originally looked like. Notice the rattle can primer in the middle. I had to carefully wet sand that off. That section now looks better than the rest of the hood, it has a mirror like shine. The rest of the hood looks so much better than before, just not at the same level where I had to do the wet sanding. I didn't set out wanting or looking for a mirror shine, but now I'm just trying to get the best match across the hood. And then replicate that effort across the rest of the Blazer. What do you think? Thanks!
#24 |
There are some good videos of this on Youtube by pros. It's called paint correction or restoration.
#25 |
![]() Join Date: Jan 2007
Good thread. I’ve always just used 0000 steel wool and CLR mix on original paint, carefully by hand, but the truck I have now in storage waiting til I have time needs the paint refreshed correctly.
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
| Bookmarks |
