Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-03-2022, 09:37 PM   #1
tim71
tim71's Avatar
1972 Blazer Underhood Wiring
I'm trying to get the wiring reinstalled in the 72 Blazer build that I'm working on. A PO had molested all the wiring harnesses. I also have a 71 GMC K1500 that I refer to since both the truck and Blazer have 350/350 with AC.
My 1971 GMC has two relays (tcs and emission) on the engine side of firewall just above and to the right of the fuse panel. The Blazer doesn't have these relays. Does anyone know, is this a Blazer thing or a 1972 thing. I want to find a underhood harness but don't know if the harness would have to come out of a Blazer, or could it be out of a 1972 C or K truck also.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 09-04-2022, 03:48 PM   #2
truckster
truckster's Avatar
Re: 1972 Blazer Underhood Wiring
My TCS was on the cab side of the firewall.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-05-2022, 11:56 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a picture of the TCS relays.
I think all 71 gmc and chevy vehicles with the 350 th had them even 6 cylinders. not certain however.
If you go to the search bar by your private messages and type in TCS then tick the 67-72 circle and click google you''ll get a lot of info in the tcs stuff.
Name:  TCS relays plus.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-06-2022, 08:00 AM   #4
tim71
tim71's Avatar
Attachment 2216551
That set up is exactly what my 71 GMC has. I understand how it functions and it's purpose. What I was getting at is that the 72 Blazer that I'm rebuilding does not have these relays. My blazers transmission has no provision for an electrical plug, nor does the carburetor have the idle stop solenoid that accepts electrical connection from relay. This surprised me to see an emission component go away.
The question in my post was regarding how to obtain an engine harness for the Blazer. Engine harnesses with the relays won't help me unless I take them apart and change them, which I am trying to avoid.
Old 09-06-2022, 08:02 AM   #5
tim71
tim71's Avatar
I assume your talking about your 1972 Blazer? What transmission does it have?
Old 09-06-2022, 11:44 AM   #6
pjmoreland
pjmoreland's Avatar
One option might be to use an engine harness from an earlier year that didn't have the relays. The 68-69 version might suit your needs. If you have an HEI distributor, you can get a harness that is already modified to work with it. https://gmcpauls.com/wireharness_2.htm
pjmoreland is online now   Reply With Quote
