09-07-2022, 01:31 AM | #1 |
No “off” option for heater fan?
My ‘78 had off as one of the options on the fan speed switch but my ‘79 only has low-medium-high. Even with the temp switch slid all the way to the cold side it still pushes air hotter than outside continuously. Is there an easy way to add an “off” option to that switch?
Evan B. |
09-07-2022, 11:46 AM | #2 |
Re: No “off” option for heater fan?
Might not be the fan.
Might be one of the doors(flaps) isn’t closing or opening like it should. Check to see if they do when you adjust the controls. |
09-07-2022, 02:58 PM | #3 |
If you have controls like this the top lever will shut off the fan in the 'off' position but you will still have air flow while driving.
If you are still getting only hot air then it sounds like a blend door issue or the control cable needs to be adjusted. http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
09-07-2022, 07:09 PM | #4 |
i
my 78 with air has no off-fan position also, I disconnected the yellow wire in the engine compartment on the heater box. Nowhen it is in the low position it is off, now I can shut off the fan . The yellow wire is the low speed for the blower motor |
09-07-2022, 10:57 PM | #5 |
73 and up had no wing windows so they made the fan blow a little to keep air moving. It's a feature not a defect.
You want the fan to be off, put in a switch. |
09-07-2022, 11:08 PM | #6 |
The fan will run on low all the time regardless of any position settings. I found this out about 3 years ago. You are right. The yellow wire at the resistor is for the low speed fan.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
09-07-2022, 11:25 PM | #7 |
IIRC - AC trucks have the 'no off' feature. I think the thought was to ensure some fresh air getting into the cab to avoid CO issues. Heater only trucks have the two kick panel side vents and guessing the assumption was they or the windows would be open during hot weather and the heater running with some vent air mix during cooler weather.
2nd the thought to double check the heat flap cable adjustment. Another way to keep low speed and have an off setting would be to install a switch on the ground wire from the blower motor. It would need to be a heavy duty switch. |
09-09-2022, 08:42 AM | #8 |
A/C system operation table and standard C/K heater air flow outline. Based on the air flow outline on how it is supposed to work your purge door is not closing off air flow to the heater core- need to adjust the cable or investigate why the door is not closing. The last line is key 'The temperature of the outlet air is dependent on the ratio of heated to unheated air (controlled by the temperature door).'
09-12-2022, 10:45 PM | #9 |
I put a ball valve on my heater hose. Turn it off in the warm/hot months
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
09-12-2022, 11:55 PM | #10 |
I unplug it during summer.
09-13-2022, 10:23 AM | #11 |
Huh?!? Every 73-87 squarebody left the factory with wing windows.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-05-2022, 11:52 PM | #12 |
Me thinking the exact same thing
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
10-06-2022, 03:22 PM | #13 |
Worth The Effort
After several decades of ownership I finally got tired of that warm/hot air blowing in all the time and decided to chase it down .
Turns out that from new the fresh air flap's Bowden cable was incorrectly installed . I removed it and lubricated it until it slides easily even when held in a loop, re installed it so the diverter flap is fully closed when it's supposed to be and Lo ! . It's far more comfy in the cab in warm or hot weather . As as result I'm fixing the A/C , might as well .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-06-2022, 07:03 PM | #14 |
Moderator
The blower doesn't have an off position just LOW - HIGH
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
