Old 01-27-2023, 01:08 PM   #1
KyleSeal
KyleSeal's Avatar
Master Cylinder & Booster Question
Looking to run a booster, 8 inch dual on my 67 disc drum conversion. I see a listing on ebay, booster + master + prop valve for around $200. It states the master is a 1 inch bore - does this sound OK for my application based on bore size and booster size? Running this booster for the clearance and also to flush mount on my firewall.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 01-28-2023, 09:18 PM   #2
jessemthompson
Re: Master Cylinder & Booster Question
Usually on power brakes with our trucks you would want the 1 1/8 master cylinder. Without the booster 1”.
It also appears we’re in the same neck of the woods
jessemthompson is offline   Reply With Quote
Old 01-29-2023, 08:48 AM   #3
Warrens69GMC
Warrens69GMC's Avatar
Check in the Vendors section, CaptainFab has a booster/MC/PV for our trucks- other vendors as well. Imo, you can personalize your system so you get what you want, and be able to communicate before and after if you purchase a unit.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-29-2023, 04:57 PM   #4
72SB
FWIW my PB/MC kit from CPP on my 72 (converted from manual to power front disc) uses a 1 1/8" bore MC
72SB is offline   Reply With Quote
booster, brakes, master
