Old 06-02-2023, 07:27 PM   #351
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: LS factory cruise control hook up
Originally Posted by A1971Blazer View Post
Just about ready to start wiring the CC module for my '67 LS1 swap.
My cruise stalk/switch (from some year of a factory vehicle?) has red, green, yellow, and blue wires.
So far I haven't found that combination in any diagrams.
Anyone have any info for it as far as which color wires are for which function or how to determine?
post a picture of the switch, maybe I can find a diagram to help
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-05-2023, 11:19 AM   #352
A1971Blazer
A1971Blazer's Avatar
here's a couple of pics...tried to upload off my phone....they're always sideways...
blue red yellow green
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-06-2023, 10:54 AM   #353
ls1nova71
ls1nova71's Avatar
Attachment 2273183
You Got lucky finding that switch, they're hard to come by these days. That is from a 1981 van or 81-83 truck.
Blue- Ignition 12v
Red- Set/Coast
Yellow- Resume/Accel
Green- On/Off
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-06-2023, 02:54 PM   #354
A1971Blazer
Blue- Ignition 12v
Red- Set/Coast
Green- On/Off
A million thanks....I've looked everywhere but wasn't sure what it came from....
another piece to the puzzle....
one last question, will this switch need relays or will it wire directly to the CC module?
1967 C10 Step side
1968 C10 Step side
Old 06-06-2023, 10:25 PM   #355
ls1nova71
ls1nova71's Avatar
No relays needed with that switch since it's a GM switch
Old 06-09-2023, 09:27 PM   #356
87chevy.com
found this online years ago, copied and pasted the name cant find it it online with a quick search...
http://www.87chevy.com/1984 CRUISE III_opt.pdf
page 17 shows some wire testing..
clint
Old 06-16-2023, 02:09 PM   #357
Paul Y
LS1 Nova - can you empty your inbox - trying to send you a message!
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 06-17-2023, 03:24 PM   #358
87chevy.com
P.
whats the question, maybe someone else can answer it
Old 06-19-2023, 04:28 AM   #359
Paul Y
Confirming payment for a switch and the correct delivery address.
Being based in the UK, getting PayPal to use American Zip Codes causes all sorts of issues when trying to use my American family as the shipping address and my UK address as the billing...
Appreciate you checking in though, pretty sure I will have some questions when it becomes time to hook it all up....
P.
Woody's Build -
Old 09-06-2023, 04:34 PM   #360
tallic68
Does anyone know if a 2002 dbw tac module or stock ecm has a cruise engagement signal. I have Dakota digital dash and was wanting to use the custom inputs to show cc on the dash. I’m thinking I could use the positive input available to show cruise on by tapping into the gray pin 14 wire telling the dash that the cruise is turned on. But is there a way to tell the dash that the cruise is engaged?
tallic68 is offline   Reply With Quote
Old 09-14-2023, 11:22 PM   #361
Skennon
Ls1nova71 do you have any of your switches available
Skennon is offline   Reply With Quote
Old 12-03-2024, 02:28 PM   #362
lts70
1970 Daily Driver
lts70's Avatar
Will this switch work?
It is a single button cruise control wand off of a van column, but I am not sure what year. It has three wires: black, blue and brown
We want to use it on my boys truck that has a 2007 Silverado 5.3 / 4l60E swap.
Our repined LS harness has a bundle of wires for the cruise: gray, gray/black stripe, dark blue, light blue. From what we have read connector C1 (the engine harness one, not the one going to the pedal) pin 4 dark blue wire is the set/coast, pin 5 gray/black wire is the resume/accel, and pin 14 gray wire is the on/off. We need an ignition 12v source to power these through the switch also the brake lights hooked up and the correct brake light switch for it to work.
With a volt meter:
The blue and brown wires have continuity until the wand button is pressed. With the button pressed in it breaks the circuit, once the button is released it has continuity again so it is a momentary switch.
The blue and black wires do not have continuity until the button is pressed (momentary).
The black and brown wires do not have continuity until the button is pressed (momentary).
Help on where the Black, Blue and Brown of the column switch tie into the LS harness would be appreciated.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 12-23-2024, 10:36 PM   #363
ls1nova71
ls1nova71's Avatar
With a volt meter:
This is probably a little late, but on the off chance you didn't get it figured out, I can try and help. But first, you need to have a Gen3 engine and 2007 was a year when they made both Gen3 and 4's but as long as its the older one, cruise is possible. So to answer your question, yes, that switch will technically work, but only the set/coast function. So basically it will work just like the older cruise control from the 70's. You will need to just hook the on/of to ignition power. It won't hurt anything, will be just like always having the switch set to "on", which is the way I leave mine in all my cars as I have never had a need to actually shut it off. You will lose the safety aspect of being able to shut it off during use, but since you will have the brake light switch to cancel it, it won't be a problem, and if the brake light switch malfunctions at any point, then it won't set, so really no problem there. To hook it up to the LS harness, you would just have to pick two wires that have continuity when the button is pressed and hook one side to ignition power and the other to the pin 4 dark blue wire on your harness. That wire just needs to see 12v when the button is momentarily pressed. Then provided you have both brake switch inputs hooked up, you should be good to go.
