Old 08-12-2023, 08:39 PM   #1
Nick_R_23
Nick_R_23's Avatar
Why the **** won’t my rear brakes work??
Need some serious help here, about to drag the truck out in my driveway and burn it over as much trouble as these brakes have been giving me. I’ll give a recap of what’s been done on this truck.
1978 Chevy K20. D44HD front end. Corporate 14 bolt rear end.
Originally a vacuum boost truck. Originally had 11” rear brakes.
Swapped from vacuum to rebuilt hydroboost unit from a 1983 CUCV.
Installed a new Master Cylinder for a 1993 Suburban K2500 (aluminum body/hydroboost)
Installed new spindles, rotors, pads, calipers, hoses, and lines on the front.
Sourced 13” backing plates and changed over to 13” brakes. Installed new wheel bearings, drums, shoes, wheel cylinders, hardware kit/springs, parking brake kit, and all new parking brake lines in the rear. Also replaced the rear brake lines and brake hose.
Went to adjust the rear shoes. I can tell the new drums are slightly out of round, as they drag slightly on the shoes on only about 1/2 of the drum. Both sides do this. However, at the adjustment sight windows at the bottom of the backing plates, the shoes have a small gap and don’t touch the drum. I could likely crank on the adjuster and force them to, but the drum would be locked up. It feels like the shoes touch the drum at the top before the bottom. The driver side is slightly better than the passenger side. Currently, I have it adjusted where there is some slight drag.
After attempting to bleed the brakes, the front worked fine. I could not get consistent pressure to the rear, although the rear brakes did work really well once sporadically. I determined the proportioning valve was shot. Ordered a new proportioning valve and the bleed lock tool for it. Installed both of those and had better results, but still inadequate pressure in the rear.
Warrantied out the brand new master cylinder for another one and rebled the system. Now I have good pressure to the rear. However, the hose from the frame to the axle was machined incorrectly, and the hard line wouldn’t seat and kept leaking. This damaged the new passenger side hard line. I warranted out the hose and reflared the hard line and replaced the fitting. Went to install and the drivers side threads pulled right out without even tightening down, damaging the driver side hard line. Replaced the hose again, with a different brand, and reflared the other hard line and replaced that fitting. Installed the new line and rebled the system again. Removed all the air and the pedal feels good.
However, if I have the pedal pressed I can still turn the rear drums by hand. They definitely drag more than what my adjustment was, but they definitely don’t work. Front seems to lock up solid and work great. For an extra brain scratcher, if I manually pull the parking brake cables by hand, both rear brakes will work perfectly via the parking brake.
I’m completely at a loss here.
Old 08-12-2023, 08:50 PM   #2
Dead Parrot
Re: Why the **** won’t my rear brakes work??
They should self adjust. Go in reverse about 10mph. Stomp on the brakes. Repeat a few times. The hard stop in reverse is the key.
Dead Parrot is offline   Reply With Quote
Old 08-13-2023, 12:26 AM   #3
Nick_R_23
Nick_R_23's Avatar
Self adjusters are working fine. I guess to clarify, it acts like the shoes are making contact first at the top of the drum (instead of at the bottom first like they should), coupled with the fact that the wheel cylinders don’t seem to be moving the shoes out much if at all, despite having good pressure in the system.
Old 08-13-2023, 12:32 AM   #4
Nick_R_23
Nick_R_23's Avatar
Just for reference in case anyone can point anything out, these were taken just before the drums were installed.
Driver:
Passenger:
Old 08-14-2023, 10:57 AM   #5
Nick_R_23
Nick_R_23's Avatar
So I managed to find an obscure thread on another forum where several members had ran into this same problem after rebuilding their 14BFF 13” drum brakes. Apparently, it was noticed that the front lining is supposed to be the thicker lining, even though normally it is also the shorter lining. After swapping the thin/short shoe to the rear and putting the thick/long shoe to the front, they all reported the issue to be solved. Thoughts or opinions on this?
Old 08-14-2023, 11:39 AM   #6
Dead Parrot
I found the following note in the Technical Manual for CUCVs. Covers both the M1009 Blazer and M1008 K30 versions.
NOTE
Primary brake shoe (17) has a
shorter lining than the secondary
brake shoe (5), and is always
installed toward front of truck.
Probable that the K20 is the same.
Old 08-14-2023, 04:56 PM   #7
rick1956
rick1956's Avatar
Does it have one of these stupid "load-sensing" things on it? GM advises removal and bypass...
https://rixsquarebody.blogspot.com/p...ommending.html
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 08-14-2023, 05:33 PM   #8
Nick_R_23
Nick_R_23's Avatar
Nope, nothing like that. Regular proportioning valve setup.
Old 08-19-2023, 09:51 AM   #9
Axle
Axle's Avatar
Randomn thoughts to throw at it;
What size rear drums go with the vehicle you got the master from? Aka, is the master able to push enough fluid for the larger drums?
I never looked into it on GM since it was never an issue (just fords) but where is the residual valve in the original setup, and where is it now? (part of the master in the original, separate screw in valve in the donor system? something of that nature is what I'm getting at).
Axle is offline   Reply With Quote
Old 08-21-2023, 10:59 AM   #10
Nick_R_23
Nick_R_23's Avatar
Same size. The master cylinder is a Napa M2904 that fits 1988-1994 Chevy/GMC trucks and Suburbans with hydroboost. This master cylinder also has the same specs as the OE 13” brake master cylinder, really the only difference is that this unit is aluminum instead of cast iron.
Old 08-22-2023, 05:14 PM   #11
SunSoaked
SunSoaked's Avatar
So have you verified the shoes are in the correct orientation?
SunSoaked is offline   Reply With Quote
Old 08-23-2023, 11:38 AM   #12
Nick_R_23
Nick_R_23's Avatar
Yes, I have pictures posted above for reference.
Old 08-26-2023, 02:55 PM   #13
Nick_R_23
Nick_R_23's Avatar
So this is what I was told by a long time Chevy tech:
This condition is somewhat normal to run into on these trucks. Don’t worry about the runout on the drums, just adjust the shoes like normal on the spot that they don’t drag (I.E., they should be difficult to turn by hand but should still turn with the wheel mounted) and take it for a test drive and bed the shoes in. Check the adjustment afterwards and he says it should be good to go.
It’s absolutely pouring rain this weekend, so I’ll tackle this when it’s nicer out.
Old 10-29-2023, 02:39 PM   #14
Nick_R_23
Nick_R_23's Avatar
Okay, I’m back at this again. Still can’t get the brakes to work. So far, I’ve gone as far as having adjusted the brakes so that the shoes drag heavily (wheel takes significant effort to turn by hand), but the pedal still won’t stop the wheel from turning even with the brakes fully applied. However, the parking brake functions beautifully. My observation is that the rear trailing shoe will adjust to the drum. The front shoe always retains a gap between the shoe and drum unless the parking brake is applied. My conclusion seems to be that the drum and front shoe have proper contact, but for some reason the wheel cylinder is only applying pressure to the rear shoe, or possibly not at all. I don’t have a way to check actual pressure seen at the wheel cylinder, other than the fact that the pressure seems to be adequate during bleeding. How can I have pressure at a wheel cylinder and still have no brakes?
Old 10-29-2023, 05:39 PM   #15
hatzie
Moderator
hatzie's Avatar
I've had trapped air that was difficult to remove on my T400
Not sure what the difference was but I didn't have these issues with the cast iron 1979 K30 hydroboost master cylinder I used on my 1976 K20.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-29-2023, 09:52 PM   #16
Nick_R_23
Nick_R_23's Avatar
So I gave up trying to diagnose this externally. Removed the drum assembly and inspected the brakes again. Everything appears fine, all parts are correct and installed properly. Ran a ratchet strap loosely around the shoes and had a friend apply the brakes. The brakes have great pressure and a good amount of travel. The shoes themselves have witness marks where they’ve contacted the drum and there’s not much area where there is actual contact being made. However, I removed both shoes and fit them to the drum, thinking that maybe the arches weren't the same, but the shoes both fit the contour of the drum damn near perfectly.
As a final observation, we can get the rear wheels to stop turning by hand with the brakes completely applied, but it’s further along in the pedal travel where normal braking would occur - it’s more down in the “panic stop” area.
Master cylinder was a thought, but it’s been replaced twice and shares the same specs as the original. It even is meant for the exact same rear brake setup, just on a newer truck.
Old 10-29-2023, 10:28 PM   #17
geezer#99
geezer#99's Avatar
Maybe you need a smaller bore master.
Old 10-29-2023, 11:43 PM   #18
Dead Parrot
Since you switched from 11" to 13" brakes, any chance the parts place gave you wheel cylinders for 11"? There might not be any difference but if there is and they did, could be a problem.
Old 10-30-2023, 02:50 AM   #19
Nick_R_23
Nick_R_23's Avatar
I think my only option would be to use an 11” drum Master then, as those spec out at 1.125”. My current master cylinder is 1.25”, which is also what the stock cast iron was.
The wheel cylinders are correct for 13” brakes, and have a 1.0625” bore. The 11” brakes had 1” bore wheel cylinders.
Old 10-30-2023, 09:35 AM   #20
cadillac_al
I have never had to do it but some people put a gauge on their brake line to test brake line pressure. It sounds like it isn't getting enough brake line pressure but I would have no idea why.
I never liked hydraboost in the past but I have it on my 86 motorhome and it seems to work quite well. I would think a K30 would use the same master cylinder as a P30. If not I would try something out of left field like try a master cylinder from an 86 P30. Good luck
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-30-2023, 09:36 AM   #21
geezer#99
geezer#99's Avatar
Lots of 1 inch or smaller bore m/c available.
Look here.
https://leedbrakes.com/p-27639-about-us.html
Old 10-30-2023, 11:08 AM   #22
Nick_R_23
Nick_R_23's Avatar
Feel free to correct me if I’m wrong, but wouldn’t I be wanting to go larger bore, like 1-5/16” off the 1 ton trucks? Reason being if I’m into the pedal around “panic stop” area, and building pressure, that sort of indicates to me that I’m not having problem building pressure, I’m possibly just lacking volume. The larger volume will fill the wheel cylinders quicker (engage higher up in the pedal travel), but increase the pedal effort, which shouldn’t be an issue because I have the hydroboost. Am I thinking this over correctly?
Old 10-30-2023, 11:26 AM   #23
geezer#99
geezer#99's Avatar
Bigger bore equals more volume but less pressure.
Smaller bore equals less volume but more pressure.
That info comes from my motors manual.
Also read that on Hemings, mppower and others.
Old 10-30-2023, 01:14 PM   #24
Dead Parrot
Based on this, it is possible your brakes are working closed to as designed. Before ABS, rear brake effectiveness on trucks was limited to prevent the rear brakes from locking up and the rear end trying to swap ends with the front during heavy braking. There was a period when trucks had rear only ABS to allow better braking without the cost of 4 wheel ABS.
Old 10-30-2023, 02:38 PM   #25
Wikid61
Wikid61's Avatar
There is contact points on the high sides of the shoes. Is the backing plate smooth/clean/shiny for the shoes to work back & forth?
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
