Old 10-21-2023, 01:15 AM   #101
NoNeck
NoNeck's Avatar
Re: Another one underway! Meet project Savannah
We couldn't find any upper radiator brackets that we like for the FrostBite radiator. After some experimentation we made up some simple aluminum brackets from 1" x .025" bar stock. They look right at home with the aluminum radiator. We are going to change out the black mounting bolt for a chrome button top.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 10-22-2023, 12:19 AM   #102
68bowtie
68bowtie's Avatar
Those look really slick, and fit very well!
Old 03-09-2024, 12:58 AM   #103
NoNeck
NoNeck's Avatar
Chad and I have started pulling things together for his truck now that Spring is just around the corner.
We had the bed tubs, front bed panel, rear bed panel, grille, and tailgate media blasted last week and delivered to the body shop for initial primer/sealer.
While we were at it they blasted the parking light housings and I detailed them and bagged them for reassembly.
The wood bed sills and front splash apron were blasted then powder coated GM Satin Black. They turned out nice.
The original Bowties shine pretty good after a little polishing.
Chad has chosen African Mahogany Sepele exotic wood for the bed floor. It has a nice grain and color and planes really smooth.
Truck is scheduled to go to body shop for prep and paint in a few weeks. Stay tuned!
POP
Old 03-09-2024, 07:37 AM   #104
nlped
nlped's Avatar
Phenomenal!!! Hope y’all keep plugging away at it.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-09-2024, 06:18 PM   #105
NoNeck
NoNeck's Avatar
Thanks Carter. Good to hear from you.
Old 03-10-2024, 12:35 AM   #106
cericd
cericd's Avatar
Looking great guys! Can't wait to see how this one turns out.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-26-2024, 05:55 PM   #107
omodified
omodified's Avatar
Originally Posted by NoNeck View Post
Nothing like an awesome set of Doug's 1-7/8" Full Length Headers bolted to those Gibbons Motorsports Heads. That 6.0 will like all that extra air flow.
POP
I just read through your build and it is coming along very nicely. Are these headers polished stainless or coated? I really like the fit on those. Keep it up!
Board Member #87725
Old 04-26-2024, 01:25 PM   #108
NoNeck
NoNeck's Avatar
We finished installing the MSD Coils on the engine today and started connecting the steam ports. We will be adding an ICT Low Mount Alternator Bracket, pulleys and a 2002 Camaro SS belt tensioner to match the Camaro SS water pump.
One day at a time...
POP
Old 07-07-2024, 11:19 PM   #109
NoNeck
NoNeck's Avatar
It's been a while since we posted progress on the truck. It's been busy and hot here in Tennessee but we are getting a few things done.
We are changing to ICT brackets on the front of the engine to lower the Alternator and raise the Power Steering pump. The lines to the pump were amost touching the frame so this will fix that problem.
We ordered a new AC Delco Alternator and Lares Power Steering pump for a 2000 Camaro Z28 LS1. These are required to work with the ICT brackets.
We installed a new Power Steering pulley and it looks really nice.
Our 6.0L block doesn't have the third threaded hole where the Camaro Alternator bolts up so we ordered an ICT Drill Template to locate, drill and tap the hole. That's next on our list. Then bolt everything up and measure for a serpentine belt.
Stay tuned...
POP
Old 07-08-2024, 07:03 AM   #110
nlped
nlped's Avatar
Nice, as always.
Carter
Old 07-13-2024, 11:19 PM   #111
NoNeck
NoNeck's Avatar
Using some trick ICT brackets, Chad and I drilled the hole in the block and mounted the new Camaro Alternator today. We also mounted the new Lares Camaro Power Steering pump to finish up the front of the engine.
Now we need to string the accessory pulleys to get a measurement for a Serpentine Belt. Getting closer...
POP
Old 07-14-2024, 10:55 AM   #112
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-11-2025, 10:11 PM   #113
NoNeck
NoNeck's Avatar
It's been awhile since we have been on the site. Life sometimes gets in the way of living. Tinkering around on these classic old trucks is my idea of living, so we have made a little paint progress.
The truck is in the Paint Shop and after almost a year there has been some paint applied. I will get some photos of the progress there soon.
We picked up some small parts from the Media Blaster and they are now finished in the Silver that Chad chose for the truck. I think it is a new Volkswagen Silver Pearl Metallic.
Here are a few pieces we picked up today.
POP
Old 04-11-2025, 11:38 PM   #114
TexasLS1
TexasLS1's Avatar
Awesome, nice to see the update!
TexasLS1 is offline   Reply With Quote
Old 04-14-2025, 10:30 AM   #115
NoNeck
NoNeck's Avatar
More progress in the paint booth...
POP
Old 04-14-2025, 12:40 PM   #116
CC69Rat
CC69Rat's Avatar
Looks great Pop !! I cant wait for it to be all together.
Dad mentioned the color, it is Volkswagen 'Pyrite Silver Metallic' It is s smoky silver in the right light, but it has some 'pop' to it when the light hits it. I cant wait to see it in the sun. The interior will be blue, I have a set of Snowden LB buckets just waiting to go in it. Blue carpet, door panels, etc. I just wanted something different. I will probably go with Raceline Element, with a grey / Titanium color center. The bed wood is a natural mahogany color. It be interesting .. stay tuned.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-14-2025, 11:21 PM   #117
Getter-Done
Getter-Done's Avatar
Great work on your Truck.
Do you plan to attend the SETN show this year?
The early bird gets the worm,
85 Chevy K-20
Old 04-15-2025, 05:44 PM   #118
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-15-2025, 07:02 PM   #119
zicc1835
zicc1835's Avatar
beautiful
zicc1835 is offline   Reply With Quote
Old 04-15-2025, 09:35 PM   #120
72 tigger
72 tigger's Avatar
Sweet!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-22-2025, 07:35 PM   #121
NoNeck
NoNeck's Avatar
We finished up the new stainless hoops, NOS parking light lenses and a blue Bow tie to complete the grille. Turned out pretty nice.
Chad received his beautiful custom made Snowden Bucket Seats and man are they awesome! I will let him fill in the details on the seats. He also got one of Snowden's Seat Brackets to mount the seats.
We also mocked the front bumper up to start aligning parts for the upcoming body mounting. Hopefully it will be out of paint soon.
POP
Old 12-22-2025, 07:52 PM   #122
CC69Rat
CC69Rat's Avatar
We're getting closer finally. The cab and front clip are in final prime, almost ready for sealer and color / clear. My painter is good but hes particular. In all fairness I asked him for his best work so I cant push him on it. Its hard to keep good help anymore so I've just been trying to be patient.
All the wiring from PSI is here now, I got everything under the hood and customizations from PSI. Upgraded wire loom, fan relays, grounds, ECM, fuse block, trans etc.
Gen 5 Vintage Air sure fit kit. Side mount compressor with the brackets
Dakota Digital RTX, BIM Module and Pop got us a new outer dash bezel.
AAW full chassis harness
Its coming together, stay tuned. I hope to have the cab and front clip back over on the 67 chassis by spring time. Ill have the 69 swb chassis for sale soon if you know of anyone who needs it.
Chad
Old 12-22-2025, 09:55 PM   #123
zicc1835
zicc1835's Avatar
looking forward to some pictures when you can
Old 12-25-2025, 09:48 PM   #124
CC69Rat
CC69Rat's Avatar
Truck is in the booth! We should have color the first of the week. Ill post some pics as soon as I can.
Chad
Old 12-27-2025, 12:35 AM   #125
nlped
nlped's Avatar
Awesome
Carter
