Old 11-07-2023, 11:17 AM   #376
KyleSeal
KyleSeal's Avatar
Re: My 1967 Build (Finally)
Some close ups, its tough to match patina, what I decided to do is match the old rocker I cut off as a good example.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 11-07-2023, 03:19 PM   #377
chewychevy67
Looks fantastic
chewychevy67 is offline   Reply With Quote
Old 11-07-2023, 07:21 PM   #378
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That turned out very well
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-10-2023, 01:14 PM   #379
jaros44sr
jaros44sr's Avatar
Late to the party
Rocker patina looks great
Great thread
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 11-13-2023, 09:05 AM   #380
KyleSeal
KyleSeal's Avatar
Originally Posted by chewychevy67 View Post
Looks fantastic
Originally Posted by jaros44sr View Post
Late to the party
Great thread
Thank you guys!
Old 11-13-2023, 09:08 AM   #381
KyleSeal
KyleSeal's Avatar
Speaker grille is in on the driver side door. Next to get all of the brackets and hardware on the backside in place. Now that its winter I am able to work more continually, but when I get off work it is pitch black so doing any large amount of grinding waits till the weekend. Thats okay though, theres always something to do on a project!
Size:  74.1 KB Name:  IMG_2804.jpg
Old 11-14-2023, 09:17 AM   #382
KyleSeal
KyleSeal's Avatar
Couple pics of the interior while the truck was outside
Size:  91.8 KB Name:  IMG_2819.jpg
Old 11-14-2023, 10:57 AM   #383
Shifty One
Shifty One's Avatar
Damn that's pretty!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 11-20-2023, 08:39 AM   #384
jasinger01
jasinger01's Avatar
Originally Posted by KyleSeal View Post
Satin clear put down on the firewall, dash, and interior. Came out good! I used the Spraymax aerosol can that has the button for the two part mix. Really impressed.
Attachment 2263926 Attachment 2263927
Attachment 2263928 Attachment 2263929
Hi Kyle, I am currently doing the same insulation on my cab right now. Wondering what you used to plug all the firewall holes? I believe they are there from the original insulation mat retainers. Thanks.
jasinger01 is offline   Reply With Quote
Old 11-20-2023, 10:41 AM   #385
KyleSeal
KyleSeal's Avatar
Are you using the factory style 'carded' insulation as well? I did the Kilmat/Siless and then did the carded stuff. I used the factory rubber plugs in the firewall and used some water/soap spray to help place them. If not using the carded stuff. you could always buy either some push in plugs or the same plugs used on the carded stuff.
Old 11-20-2023, 12:29 PM   #386
jasinger01
jasinger01's Avatar
Attachment 2316441
Attachment 2316442
Thanks! No I am not using the OEM style insulation; I am using a layer of Siless thermal insulation roll and then the same sound deadening that you have. Good idea I will order some more of the original style rubber plugs
Old 11-20-2023, 01:12 PM   #387
KyleSeal
KyleSeal's Avatar
They work good. The thermal insulation is a good idea. I would put the head on the engine side to make it look cleaner, they seal much better than the plastic plugs.
Old 11-21-2023, 10:05 AM   #388
loudchevy
loudchevy's Avatar
Looks fantastic in the sun!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 11-27-2023, 11:59 AM   #389
KyleSeal
KyleSeal's Avatar
I have been working on some wiring lately, and got around to testing the audio system since I have it wired up. It sounds GREAT. That Basslink is super punchy, the 6.5 Kappas are great at really pushing the music through the truck. I did have one bad wire running into the door speaker, so I had to work backwards and rewire that, which was a pain to determine since I had to tear the sound 'board' I made apart to determine the failure. It all works now though, so thats good!
I did finish the EFI wiring, so I need to dial in the Dual Sync distributor, and get the Sniper programmed for my setup, and I will be able to run it again. We are close.
Old 11-28-2023, 09:58 AM   #390
KyleSeal
KyleSeal's Avatar
Crazy to think this is the same area, on the same truck, about a year or two apart!
Old 11-28-2023, 11:29 AM   #391
Shifty One
Shifty One's Avatar
That's awesome Kyle!
Old 11-28-2023, 12:32 PM   #392
chewychevy67
That looks great especially knowing it's solid now. There are times I wish I went this way with paint rather than a full blow apart. Nice work.
Old 11-29-2023, 04:53 PM   #393
Racer2172
Wow just read entire thread great work.
Racer2172 is offline   Reply With Quote
Old 12-04-2023, 09:51 AM   #394
KyleSeal
KyleSeal's Avatar
Working on exhaust. Theres always something to do even when waiting on parts to move forward somewhere else! This is my first time making pie cuts to create a tighter bend, and it came out OK. Working with some not-so-amazing exhaust pieces but so far its working.
Ive got just about everything wired up, but am waiting on some break-in oil to run in the motor during initial start. The motor has been broken in, but it has been a couple years since I have run it. I am very close, I can almost smell the exhaust leak!
Size:  48.4 KB Name:  IMG_3197.jpg
Size:  48.6 KB Name:  IMG_3194.jpg
Old 12-04-2023, 10:27 AM   #395
KyleSeal
KyleSeal's Avatar
I appreciate it. I try!
Sometimes I do wish I had a truck that was real clean and painted. But then I accidentally bump the fender with a part and I'm like thank God but I do have a ton of respect for your build though - that's a ton of work (ask me how I know!). I cant imagine the feeling of driving it when its done, knowing its probably more solid than when it left the plant.
Thank you Shifty
Old 12-05-2023, 06:31 AM   #396
PowerdbyChevy79
PowerdbyChevy79's Avatar
In the midst of it all, I found myself back in the garage, looking for things to do (no shortage with a project) and decided I was tired of getting no call backs on a windshield install. I decided to install it myself, trim and all. First time ever doing it, especially nervous with the trim aspect. But its in, and a throwback to the old C10 Club stickers, I bought that little decal in like 2014/15 when I got into these trucks. Finally found its home.
Attachment 2275068 Attachment 2275069
Attachment 2275070
Hell Yes!!!!
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 12-06-2023, 03:05 PM   #397
KyleSeal
KyleSeal's Avatar
I am always watching other builds and one thing Ive noticed, especially on the Roadster shop stuff, is the use of some modern emissions stuff. Now, by no means am I a guy who would throw a whole modern emissions system on an old vehicle (due to its complexity and my lack of interest) but the charcoal canister that modern cars use to kill gas vent fumes is great. So, I made one out of PVC, with a scotchbrite pad on each end to filter and activated charcoal/carbon to filter the smell. It came out well!
Old 12-06-2023, 04:40 PM   #398
clay68c10
clay68c10's Avatar
I like that design. I'm planning on running a cannister also, fumes in the garage = fumes in the house.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-10-2023, 11:58 PM   #399
General23cmp
I’m restoring a 67, and am curious if your lower cab corner lip was spot welded to the inner rocker/floor in line and similar to how the outer rocker is? My factory assembly manual says three spots go there, but my truck had none. Also, when I try to pull the cab corner and inner rocker to meet there, it doesn’t appear like they would want to be joined there (the floor flange is almost too short and you’d have to pull the two very hard to meet. I know later trucks have them welded there.
General23cmp is offline   Reply With Quote
Old 12-11-2023, 04:01 PM   #400
KyleSeal
KyleSeal's Avatar
I remember mine having spot welds, albeit weak ones. The inner rocker where it was welded to the cab corner was very high comparatively, and it was pinched together pretty hard from the factory, very deep dents from the spot welder machine. My 67 is a later production though I must say, I think like 33,000th or so production number. These trucks are kind of haphazard sometimes, may have been a Friday-at-4:30 truck.
1967, custom, dropped, lowered
