#4326 |
![]() Join Date: Sep 2016
Re: What did you do to your truck today.The 3rd chapter
I was curious what you are using for a fan set up. I just installed a vintage air front runner and a new Dewitt alum radiator and it seems the fans are going to be tight
#4327 |
![]() Join Date: Feb 2002
I'd love to shoot you some pix of the 20 and 30 year-old flex fans on my two trucks, but I gotta work tomorrow.
#4328 |
Thanks but I was referring to Extended power he has a bbc with same serpentine kit as I just installed and was wondering what electric fans he is using.
#4329 |
ok/ nm
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-10-2023 at 12:19 AM. |
#4330 |
![]() Join Date: Feb 2009
I sure like that garage. Nice.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#4331 |
Got the new starter in wasn’t a very pleasant experience. I had to have the mounting block milled down . It was at almost .60 gab without any shims I think the machines milled down .10 ,it brought it to close but one shim brought it to exactly.30 .I also had to remove the Shaft shim to get the depth right too.
The isn’t charged in the picture so it’s slightly retracted when I power the solenoid it goes to proper depth on the Flexplate
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-09-2023 at 09:09 PM. |
#4332 | |
On the old 402 BB, I was able to run two 16” Syclone electric fans. (Which were 4” deep”) Now there is no room at all for them, and I had to find the slimmest 14” electric fans that still moved a lot of air. (Especially now with the added AC condenser, and power steering cooler added to the front, in addition to the already installed transmission cooler.) There is 1/8” clearance between the electric fans wire cover sleeve, and the belt tensioner on the passenger side of the engine. I just hope the fans move enough air to keep the engine cool. Don’t have too many more options. I can post a picture of just how close everything is in a bit.
"If it ain't broken, fix it 'till it is!" |
#4333 | |
It was to hard to see the gap between the fan and the pulley system, so I placed a white sheet of paper underneath for better results. I didn’t use any of the thermostat stuff. I went with a Derale 16759 adjustable fan controller with manual over ride.
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 11-10-2023 at 10:43 AM. |
#4334 | |
#4335 |
Pic added
#4336 |
#4337 |
Nothing too exciting with my truck other than put it on my trailer and backed into it's hiding spot til spring.2 cars,1 truck and my trailer all snoozing,1 more truck to hide,maybe tomorrow and then back to working on my old car.spring will be along eventually.
#4338 |
Nice CLEAN truck. It's worth babying.
#4339 |
#4340 |
Today I finally fixed that broken button in the door handle. Happy I finally got that fixed! Also started applying boiled linseed oil to the body, much easier than clear spray paint. Then messed with the EVR because it keeps buzzing and making so much noise. I need to chase down that diode in the brown wire to make sure it’s good. But also, I have HEI distributor and need to make sure I wired it correctly. Pretty sure I did but that was 7 years ago. If I can’t figure that out I’ll have to upgrade my alternator. Why does something always break when you fix something else non related?
1971 Cheyenne, The Blue Jay. The Blue Jay build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=516989 |
#4341 |
![]() Join Date: Aug 2011
Thank you, I'm real happy the way it turned out.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#4342 |
Nice shop you have!!!
#4343 |
thank you sir.i got one more truck stowed away yesterday so everything that has to be away,is.i am very fortunate with this new shop.i built it how i wanted after working for years outside,then a shop that was too small and with a broken furnace that never got fixed and poor lighting.i'm officially spoiled rotten with this new 64 x 32 building,it's a very nice place to work although i'm embarrassed to say,i wished i'd built it bigger but i'll shut my mouth and be happy with what i have.take care.Greg
#4344 |
![]() ![]() Join Date: Apr 2022
Got everything buttoned up on the 327 swap yesterday and was able to get it fired up
http://youtube.com/shorts/Y2wXICz-to...rwgOA7IufepgYR
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#4345 |
![]() Join Date: Jun 2022
Got the plug wires swapped. Pre SBC, I'd have thought this would be a 20-45m job, but routing under the ram's horns and over the starter and scraping off road filth at the same time and pulling one of the heat shields, and.......
#4346 |
![]() Join Date: Dec 1999
Got my old girl Detailed. Just like the wife going to the beauty shop. Back in the garage covered. Waiting for a sunny day with a purpose or the last show of the season.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#4347 |
Started wire brushing rust scale from the truck bed of my 72 c10. Gonna wipe it down with Rust Mort, then try the new sprat in liner from rust oleum.
#4348 |
Have close to 4 hours wire wheeling the inside of the truck box and tailgate. All the visible rust is gone. Tonight I’ll rust mort it. Depending on dry time, I might be able to apply the bed coating.
#4349 | |
#4350 |
![]() Join Date: Jul 2001
Just getting back from getting exhaust put on the 69 with my little helpers. Hope to hear it run in the near future.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2015 Chevy Tahoe LTZ 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
