Old 11-28-2023, 04:23 PM   #4401
HalfBrit
Re: What did you do to your truck today.The 3rd chapter
They’re Spintech 6000XLP. Had the 3000 series before and decided to tone it down a bit. Although the 3” system will probably offset that, lol.
HalfBrit is offline   Reply With Quote
Old 11-29-2023, 11:42 PM   #4402
novaX522
Got overloads, trailing arms w/new bushings, and rearend installed.
Waiting for shocks, springs, and 10k hitch.
novaX522 is offline   Reply With Quote
Old 11-30-2023, 02:21 PM   #4403
Chevys4life
It is looking good now for sure!!!!
Chevys4life is offline   Reply With Quote
Old 11-30-2023, 02:29 PM   #4404
novaX522
Question Re: What did you do to your truck today.The 3rd chapter
Thanks!
Old 11-30-2023, 10:07 PM   #4405
Ole Blue 71
Ole Blue 71's Avatar
2/4 drop complete
71 C-10 "Ole Blue"
72 C-15 - Current Project
72 K-10 - In Pieces (Sold)
70 C-10 - "Goldie" (Sold)
66 Impala Convertible
20 FLTRXS
Ole Blue 71 is offline   Reply With Quote
Old 11-30-2023, 11:13 PM   #4406
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
8.5 years to install my door panels. Only item pending is my front bumper is being re-chromed, at least I think so.
Can you believe they tried to give me a knock-off front bumper, declaring it rechromed? I was PSST. Yeah, they "found" my bumper. They had it 6 months and never touched it.
I don't like the logo on the floor mats, ordering plain black.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-01-2023, 05:08 AM   #4407
Rust_never_sleeps
Rust_never_sleeps's Avatar
Tony, that looks pretty. I particularly like your seats, are those from SMS?
Rust_never_sleeps is offline   Reply With Quote
Old 12-01-2023, 12:48 PM   #4408
71CHEVYSHORTBED402
Thank you, and I do too. Yes they are SMS, it's the original material.
Tony
Old 12-02-2023, 10:18 PM   #4409
Extended Power
Extended Power's Avatar
Picked up some parts from the border today.
Finally got to finish my top coolant line to the radiator.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 12-03-2023, 09:08 PM   #4410
novaX522
I got a DrawTite 14082 10k hitch. The frame rails were a little tweaked. I taped a board to each side and had some hammer time. Got them straight and 34” now.
Old 12-04-2023, 10:10 PM   #4411
Rust_never_sleeps
got my headlight and wiper switch replaced, got the broken defroster lever in. Still working on drilling out the pot-metal bosses to bolt that little plate back on over the lever pivots.
Old 12-04-2023, 10:12 PM   #4412
Rust_never_sleeps
Actually, I'm pretty sure I got the broken lever out and the new one in.... ;-)
Old 12-05-2023, 10:44 PM   #4413
novaX522
Got the shocks, springs, sway bars, and new track bar. I got 1” front and 2” rear drop springs. I will be switching to 31x10.50-15 tires. We’ll see how it looks when it’s back together with the new tires. I can always do spindles and drop blocks if need be.
Tonight I got the rear springs and spring cups installed. Got antisieze everywhere. I can’t even take the lid off without making a mess. Then got the shocks and track bar installed.
I’ll be ready to put the box back on when I can scrounge up some “volunteers” to help.
Old 12-05-2023, 10:55 PM   #4414
novaX522
I also plan to reposition the exhaust sections for the best clearance and have them welded to get rid of all the exhaust clamps.
Helen Keller did her best attempt with the rear brake line, but I’m gonna see if I can build a new one.
Old 12-05-2023, 10:56 PM   #4415
novaX522
Old 12-06-2023, 07:25 PM   #4416
Rust_never_sleeps
Marking wires and making pdf notes on the wiring diagram so my head won't explode.
Putting the ducts back together for hopefully the last time, reconnecting the a/c control panel, and swapping led lights into the instrument cluster.
Old 12-06-2023, 07:30 PM   #4417
Rust_never_sleeps
Also finally figured out how the A<-->B views of the fuse box work on the fact'ry diagram
Old 12-07-2023, 08:40 PM   #4418
howzzzit
howzzzit's Avatar
I took out the ignition switch and kicked the left front tire as I walked away.
howzzzit is offline   Reply With Quote
Old 12-07-2023, 09:52 PM   #4419
Rust_never_sleeps
Originally Posted by howzzzit View Post
i took out the ignition switch and kicked the left front tire as i walked away.
lol
Old 12-07-2023, 10:23 PM   #4420
'68OrangeSunshine
'68OrangeSunshine's Avatar
That'll learn it.
Old 12-08-2023, 12:28 AM   #4421
pjmoreland
pjmoreland's Avatar
Installed an 8k tach along with a modified OE lens. Designed the text based on the stock 5k tach and then had a local shop print it on there for me.
pjmoreland is offline   Reply With Quote
Old 12-08-2023, 05:05 PM   #4422
'68OrangeSunshine
Lookin' slick, Pat.
Old 12-08-2023, 05:06 PM   #4423
pjmoreland
pjmoreland's Avatar
Originally Posted by '68OrangeSunshine View Post
Lookin' slick, Pat.
Thanks, Brian.
Old 12-08-2023, 07:37 PM   #4424
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Installed new cab and core support bushings. Took 4 hours. Yay me.
desert-rat is offline   Reply With Quote
Old 12-08-2023, 08:44 PM   #4425
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's very nice! My FiL put a vacuum gauge in the tach location and a tach up by the A-pillar on the dash pad. I'd rather have the tach where it belongs and the vacuum gauge in the unused hole, but there is a trans temp gauge in front of that. I'm old and don't have your energy. It'll probably be like that when my son inherits it.
...and I don't think I'll ever run that BBC over about 4500 RPM.
~Steven
Simi Valley, CA
