12-11-2023, 11:28 AM | #76 |
Re: Thoughts on Gen 5 Vintage Air Install
Great info in this tread. What are you guys doing with the kick panel/cowl vent doors? Just keeping them permanently closed?
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
12-11-2023, 11:46 AM | #77 |
They are still usable. The passenger Vent door can't be opened all the way, but it can be opened enough to work.
12-11-2023, 12:12 PM | #78 |
My truck had factory AC, so the passenger kick vent and cowl vent had vacuum actuators on them. I read through the VA install and didn't see if and where they were reused/integrated into the new system. Only the drivers side kick vent had the manual rod to open/close it.
12-11-2023, 12:39 PM | #79 |
Maybe you could replace your passenger vent door with one from a non-A/C truck. Here are some photos
12-11-2023, 12:58 PM | #80 |
Thanks for the pics. I see why the vent can't be opened all the way, that is a tight fit! I think the doors are the same, I would just need the manual linkage.
