01-14-2024, 03:58 PM | #376 |
Re: 67 SWB First Build
Thanks for the compliments. I did the mod a couple years ago. It wasn’t terribly tough from what I remember. Fit it up how i liked it and then welded the bolts in place and removed the head. Then just some body filler and sanding to make it look smooth. It installed with no bracket modifications. I’m really liking the look, too.
01-15-2024, 11:54 AM | #377 |
low n' slo
oh nice. ya it turned out great..going to have to steal that lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-18-2024, 07:27 PM | #378 |
Just read through this build. Looks amazing. Love the color choice
01-19-2024, 02:28 AM | #379 | |
I appreciate the compliment. I think the color is going to pop when it gets outside. Hopefully that day isn’t too far down the road |
01-19-2024, 09:04 AM | #380 | |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-27-2024, 02:06 PM | #381 |
I appreciate the compliment. I was surprised at how long that install took. It definitely tested my patience, too!
01-27-2024, 02:24 PM | #382 |
Reassembly continued…
I spent a few evenings prepping and painting misc interior pieces. Then another few nights installing the freshly painted pieces. The glove box door turned out okay. It has its flaws, but overall I’m happy with it! Reinstalling the door guts was more time consuming than i thought it would be. I also need to clean the window glass still. The Altman door latches work terrific ! I’ll jump onto the driver door reassembly over the next week. |
02-07-2024, 02:06 AM | #383 |
Small updates. I’ve been very focused on getting as much of the interior put together as possible. It definitely makes for easy satisfaction! AC ducting mostly installed. Waiting on adapters for the reproduction defrost vents. I also got to installing more door pieces.
I currently have the precision door seals on. Even after all the threads i read about difficulty shutting the door, I thought mine would be different lol. Needless to say, I have new Honda seals ordered and on their way. Hopefully they work as good as everyone says they do! In the meantime while waiting for some parts, I’m taking a run at re-doing my seat upholstery. After some minor seat frame repair, i took the frame to the blaster and I’ve started diving into the foam repair. |
03-03-2024, 06:06 PM | #384 |
Interior progress continued over the last few weeks
Spent some time fitting the foam. It wasn’t terrible other than the big mess it makes. I also shot the seat frame with some black paint i had laying around. It turned out great. Lastly, I had to replace the broken pull cable for the seat adjuster. A quick trip to home depot took care of that. I also was able to install more interior pieces. The interior door arm rest and the headliner went in smooth. I ended up using adhesive tape for the headliner. We’ll see how that goes. Seat belts showed up yesterday, so i through those in. My seat cover is on order and should show up this month! |
03-04-2024, 12:53 AM | #385 |
Progress looking great!! It's definitely a lot of work, but it's paying off tenfold. I'll be following the rest of your journey.
Any tips for putting the door interiors together that isn't covered in the videos and guides?
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
03-04-2024, 10:18 AM | #386 |
Nice repair on the seat foam and seat adjustment cable.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
03-04-2024, 05:37 PM | #387 |
color combo in the cab is awesome can't wait to see the seat cover you picked
03-05-2024, 01:27 AM | #388 | |
I found a really good video on youtube that went through it pretty thoroughly, plus it was straight to the point which was nice. I disassembled the doors years ago so it definitely saved me time from the guessing game. https://youtu.be/Zay64xBOgD8?si=mTnr2gc9TBux4cJE |
03-05-2024, 01:30 AM | #389 |
Thanks for the compliment. Fingers crossed the foam holds up and is comfortable!
03-05-2024, 01:37 AM | #390 | |
My son seems to approve, too! |
03-07-2024, 11:03 AM | #391 | |
03-07-2024, 01:47 PM | #392 |
What tilt column is that? Looks kind of like the CPP one?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
03-07-2024, 04:52 PM | #393 |
It’s actually a refurbished tilt column. I had it sent out to a member here on the board years ago to be redone.
04-06-2024, 12:32 AM | #394 |
Update.
Been spending the last month verifying tolerances on my engine. Made some decent progress with getting the pistons installed. Hope to get the cam installed in the next week. It has been a fun learning experience for sure. Last night I jumped into the reupholstery on my seat. It wasn’t too hard at all and turned out great. The repaired side feels awesome and you’d never know it was repaired. |
04-06-2024, 09:15 PM | #395 |
I like the seat color, really nice complement to the body color.
04-06-2024, 09:28 PM | #396 |
x2
04-09-2024, 11:02 AM | #397 | |
Thanks! I’m really happy with it so far. It seems to be good quality and comfortable. Happy to check that off the list. |
04-14-2024, 06:17 PM | #398 |
Weekend update. Waiting on parts for the engine. I went ahead and got the back window installed with my brother. I had to laugh at the stickers they’ll be coming off eventually.
It took lots of soapy water and had a small minor tear on the interior corner but it looks good. The tear isn’t too big and should go unnoticed. |
04-22-2024, 10:50 PM | #399 |
Road block on the engine. The camshaft that came with the 383 kit is having issues clearing the piston rods. After researching it, it sounds like I’ll have to either clearance the piston rod bolts or get a small circle base cam. Disassembling the pistons isn’t sounding very appealing….
In the mean time, while i ponder that decision, I’ll just admire how far the truck has come. |
04-22-2024, 11:19 PM | #400 | |
Cam and connecting rod bolts is the main thing. Some of the Crankshafts need a little work also.
