Old 01-31-2024, 12:38 AM   #1
60short
60short's Avatar
T5 / sbc
Hey All,
I am trying to piece together some functional parts to get Rusty back on the road ... and I was hoping to run something by the great minds here and make sure I have all my bases covered.
I have a 350 that we rescued from the Craigslist (14010207 block - 80-85 "truck" motor) that I was able to hear run on a test stand and a rebuilt T5 (26 spline) with a warranty and now I've got the job of joining them together ...
I am hoping to keep using a hydraulic master cylinder ( I have Capt'n Fab's brackets and those components)
I was trying to find a kit that covers it all, and I found this :
https://www.jegs.com/i/JEGS/555/6008...UaAl7DEALw_wcB
or this questionable amazon offering :
https://www.amazon.com/ClutchMaxPRO-...evrolet+Camaro
will this kit plus some new flywheel bolts help me bolt this all together?
Is there anything else that I would / should need or does anybody else have any other recommendations?
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 02-01-2024, 03:21 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: T5 / sbc
Its just a clutch kit, any for the application will work.
Old 02-01-2024, 09:19 PM   #3
Husker
Husker's Avatar
Re: T5 / sbc
What Tom said. Just use the clutch kit for the 350. You will likely have to drill out 2 holes on the T5 to mount to bell housing. Other than that it should work.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-01-2024, 09:21 PM   #4
Husker
Husker's Avatar
Re: T5 / sbc
Good place to look here.
Ron
https://67-72chevytrucks.com/vboard/...d.php?t=438224
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 02-02-2024, 11:58 AM   #5
chevyguyase
Re: T5 / sbc
What do you have now? bell housing, fly wheel, pilot bearing etc. My '54 3100 came with a granny gear cast iron 4 speed. I used every thing except, I replaced the clutch disc with an 11 inch disc for an Astro van. It's the only part I bought. Good info in the above post. I wish I would have had all that info in one place when I did mine.
chevyguyase is offline   Reply With Quote
Old 02-02-2024, 11:20 PM   #6
60short
60short's Avatar
Re: T5 / sbc
Ron
Thanks,
That is a good start
Right now, I have a 3 speed Saginaw with what I think is the original bell housing I haven't replaced the pilot bearing - I am trying to dig out the old clutch to confirm diameter
Old 02-08-2024, 06:28 PM   #7
scottofksu
scottofksu's Avatar
Re: T5 / sbc
If not a "World Class" T5, go easy on her as you are likely right up against the torque limit!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
clutch, t-5, transmission
