Rear Coil Springs, Leveled Ride Height
I have a 1970 c10 long bed. I have bought two sets of rear coil springs that claimed to be 2 drop but were same as stock height. Has anyone found rear coil springs that leveled the ride height?
![]() Join Date: Dec 1999
Re: Rear Coil Springs, Leveled Ride Height
Seems to me that your original springs have sagged 2". If you want 2" lower than it was, you need 4" drop springs.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
On my 71, I had stock springs on front and 4" drop on rear. All 4 wheel wells were the same height off the ground.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
So your using stock spring up front ? Here is my truck with the level look I think you want. I used a 2 1/2 dropped spindle with original coil spring and truck has 92,000 miles so sure the front spring has sagged a bit. My truck had the factory Heavy Rear Spring, RPO G50, out back and initially I installed a 4 inch dropped spring with the spindle and the rear end was noticeably lower that the front. Installed a 3 inch drop spring and the truck, pictured, levelled out. Its like springs front or year sag at different rates depending on how the truck was used during it lifetime. So 2/1/2 drop spindle up front and 3 drop spring out back I got me the look I wanted.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
beautiful truck, already gone. brown 70
Thanks for the info gentlemen. I am guessing I need a 3 or 4 drop. I have submitted a request to POL for spring rate and unloaded height for 2, 3 and 4 drop
Heres before and after pictures with 2 rear drop coils
I also did the 2 1/2" drop spindles and 2" springs in the back along with 1" blocks for a 3" total. Keeping stockish size tires and factory overloads.
Thanks for the info
