Old 05-06-2024, 01:05 AM   #1
Codyweber
4x4 engine crossmember question
So a long story short I have a 1965 k10 project (sitting on a square body k10 frame) I need a 4x4 engine crossmember to replace my weird “horse shoe” engine mount I have currently. What I’m wondering is, does anyone make an engine crossmember for these trucks that will work or am I just going to have to pull one from a junkyard? I’ve found a few aftermarket ones but it seems like they are all for LS/LT conversions. Any help would be greatly appreciated.
Codyweber is offline   Reply With Quote
Old 05-06-2024, 03:03 PM   #2
adf5565
Re: 4x4 engine crossmember question
If you're installing at least a small lift Off Road Design makes a new crossmember.
adf5565 is offline   Reply With Quote
Old 05-07-2024, 08:03 AM   #3
v30crewcab
v30crewcab's Avatar
are you saying the factory frame crossmember is bent? I have a stock one if you need a replacement. otherwise, the offroad design one is a nice piece.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-10-2024, 02:37 AM   #4
Codyweber
The one I have at this moment is the “horseshoe mount” it is bolted to the frame and engine right under the harmonic balancer. And my old Bell housing is the rear motor mount. There isn’t a crossmember where the normal engine mounts mount to the side of the block. I got a different transmission and transfer case to replace the old one. Do you happen to have a link to the crossmember you are referring to?
Old 05-10-2024, 02:55 AM   #5
Codyweber
https://67-72chevytrucks.com/vboard/...d.php?t=844603
This is a link to an earlier post about my truck
Old 05-10-2024, 04:49 AM   #6
b454rat
That looks like the original frame. Squares don't have the horse shoe engine mounts. Also with the bolt on spring hangers.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 05-10-2024, 03:24 PM   #7
adf5565
https://www.offroaddesign.com/combin...ossmember.html
There’s ones for big block and LS too.
Old 05-10-2024, 07:25 PM   #8
Codyweber
What would you recommend doing to be able to remove that horseshoe mount? Will a square body engine crossmember bolt to my 60’s frame?
Old 05-10-2024, 10:36 PM   #9
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 4x4 engine crossmember question
we built a 63 short 4x4 for my nephew several years ago, built on a real 4x4 frame-65 if i remember correctly- and we used cross members from 72 4x4 for the engine and trans, had to drill some holes and it all bolted up without any issues. we used an SM465 205 combo with power steering and disc brake front diff. he has taken that truck all over the western U.S. hunting deer and elk without any problems. if you need help locating 67-72 cross members for the engine and/or trans I have both and i'm sure other members on here can help too. as was stated earlier, your frame is not a squarebody frame, my guess is 66 or older.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-11-2024, 01:47 AM   #10
Codyweber
I really appreciate your input. It seems that someone did the same to this 65 c10. It has a disc brake front axle also. This was the exact information I was hoping to find. What would you want for the members?
Old 05-17-2024, 09:50 AM   #11
jerry moss
Born Psycho
jerry moss's Avatar
Cody,
i'll give you a call tonight after work, in case i forget i p.m'd. you my number. they will be pricey to ship but i'll work on getting a price if we work out a deal, i can do $150.00 for both plus the freight.
jerry moss
