Old 08-23-2004, 11:35 AM   #1
Guff
Guff's Avatar
Front Disc Brake Conversion
I'm sure this has been posted before, but since the search is disabled, I'll ask again. What parts are necessary to swap 1971+ disc brakes onto a 1969 C10? I know I would need spindles, rotors and calipers, but are there any brackets or other parts I'd need, like a proportioning valve? I'm looking for the cheapest way to convert to disc brakes, doesn't matter to me if it 5 or 6 lug.
-Guff
1969 C10 LWB, 350, 700R4, 3.73 gears
Guff is offline   Reply With Quote
Old 08-23-2004, 11:44 AM   #2
Deuce
Deuce's Avatar
You need all the parts you listed plus the Master cylinder.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 08-23-2004, 12:56 PM   #3
neonlarry
neonlarry's Avatar
You will need 71-72 ball joints but I don't know if they will fit ½ton arms or not. 71-72 outer tie rods and an adapter to fit them with your inners. As ^ disc/drum master AND p/valve. Flexible brake lines to fit from your hard lines to calipers.
Cheapest way to discs would be a whole disc brake x-member. They can be had for the price of aftermarket spindles alone.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-23-2004, 01:07 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
I did my '70 using '71-72 method. The 71-72 ball joints will work. You will want 72 everything for the brakes and a 71-72 master/booster set up off a 1/2 ton. Get the tie rod coupler from Classic Performance Products, If I had it to do over I would have probably did the crossmember swap, but this way will work fine.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
