Squarebody brake questions.
Starting a secondary thread concerning my current C10 project and a future one to figure out the parts needed for both trucks.
From the RPO code breakdown I got a long time ago for my '84 it has the JD5 brakes which from what I am reading is the 1.25 (1 1/4) front rotor with 2.75 (2 3/4) rear shoes. And further reading suggests the JD5 is simply a higher-weight capacity version of the JB5 which makes looking up parts a bit easier. Now my question is what is the core difference between the 1" (JB3 and lower) brakes and the JB5/JD5? The 1 1/4" rotor is obvious, but I'm assuming the calipers are different as well. I did the brakes on it last winter and had to grind down over half the pads to fit partly because I was sold the wrong pads. And partly because I suspect someone swapped on 1" rotor application calipers. Since I need to redo the brakes again this fall to do the job properly. Last time was a slap-it-together-and-get-it-running situation. Thus why I ground the pads down to make it work. I just want to be certain I am buying the correct parts this time. Are the pads the same between the two applications just different width calipers to make up the difference? Rockauto is giving no clear answers on this. Now to muddy the waters further.... I am in the process of buying a '73 C10 Custom Deluxe this summer and it too needs some front brake parts. However, when I look up parts for it on Rock Auto it doesn't even list a 2 3/4" rear shoe option. Did the early squarebodies only have the 1" front brakes?
'84 Chevy Custom Deluxe 10 "Frankenstein" http://67-72chevytrucks.com/vboard/s...d.php?t=690587 '69 Chevy C10 |
Re: Squarebody brake questions.
The '84 brake chart is a little hard to read, so I'll post up the 86 chart (should be basically the same).
The main difference between the "JBx" and "JDx" designations is the addition of hydroboost. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Ahhh ok, Yea I got looking at my thread on GMsquarebody and found the scans of the RPO list I got for it. I thought I had JD5 when it has JB5. Either way from how you explained it if it was JD5 it would have Hydraboost while JB5 has Vacuum. Either way, it means I have the 1 1/4 rotor and 2 3/4 shoes correct?
Correct.
The small rotor is specific to manual brakes and JB3, which we didn't build many of. K
So the odds are pretty high the '73 C10 Custom I'm working on buying will likely have JB5s as well then with that said. That will def make parts sourcing much easier.
