05-28-2024, 07:31 AM | #1 |
Junior Member
72 ck 20 paint code 51410 (med red)
This is the original paint from the factory. Almost could be a mix of the red and hugger orange
Anyone else use this paint ? And is it a 2 part base paint ? % using 2 part sealer primer vs hi build Thank you guys |
05-28-2024, 12:37 PM | #2 |
Re: 72 ck 20 paint code 51410 (med red)
In '72 it most likely, would have been a single stage. Today, most likely it would be sprayed as a base/clear. But a 2k single stage is also perfectly acceptable. If that's what the customer wants.
A 2k (2 part ) high build, is a catalyzed primer/surfacer for use in the bodywork stage. A 2k ( 2 part ) catalyzed sealer. Is used in the painting stage. To provide a uniform base color, and a chemical bond between the base color and the final sanded substrate. Depending on brand and the exact product,. There are some 2k primer/surfacers that can be sprayed as a high build,medium build, and sealer. Generally speaking . . . Last edited by Grounded63; 05-28-2024 at 12:52 PM. |
05-29-2024, 10:00 AM | #3 |
Junior Member
Grounded . That's GREAT INFO that will go A LONG WAY in my restoration of my dads truck
I remember driving home with from the dealer with it. I plan on now going your route with both 2k primer types you mentioned. I finished 2 restorations on 2 motorcycles which required no paint and good ole "BIG RED" gets it's long overdue love . ZERO MODS "except a intake, carb, 9:1 flat top pistons " Everything else stock stock stock Rg500gamma |
05-30-2024, 12:30 AM | #4 |
ive been using sherwin williams single stage paint..im well pleased with the results
also used their epoxy and high build primer, but ive now gone to SPI primer
