Old 06-03-2024, 05:55 PM   #1
68Gold/white
1971 C-10 gas gauge ot working...
I helped a friend locate this 71 C10, around Covid time, March 2022.
It seemed like the gas gauge worked when he got it, but has seldom work for quite a while.
I had the sender out of it, recently. This is a California emissions pickup (350), sender has 3/8 and 1/4" pipes on it.
I tested the float movement with an ohm meter. That functioned fine.
Right after I reinstalled the sender it went to 1/8 tank reading, which was likely correct. Now it just reads a fuzz off the "E" mark. I put $35.00 gas in it a minute ago, gauge did not move....
I'm wondering what the common problem could be with these pickups, if there is one...
Gauge cluster is original, old...it is the 6 hole type.
Thanks!!!
68Gold/white is offline   Reply With Quote
Old 06-03-2024, 09:31 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1971 C-10 gas gauge ot working...
Thanks!!!
Did you try hooking up a ground wire from the sender tube to the body? A piece of wire with alligator clips on each end would work.
Leon
Old 06-04-2024, 08:00 AM   #3
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 1971 C-10 gas gauge ot working...
The float itself will fail.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 06-04-2024, 02:59 PM   #4
HO455
HO455's Avatar
Here is a link to Tbone1964's great troubleshooting guide for fuel guages. The guages are pretty trouble free but they are 50 plus years old so they might just need some love.
https://67-72chevytrucks.com/vboard/...d.php?t=640615
RIP Bob Parks.
Old 06-04-2024, 04:33 PM   #5
68Gold/white
Thanks, all.
My next stab at working on his pickup will be in a couple of weeks.
Jeff
Old 06-05-2024, 07:42 AM   #6
1970cstblazer
Wink Re: 1971 C-10 gas gauge ot working...
An extreme example of what can happen to the 50 plus year old brass fuel sender floats:
