Old 06-15-2024, 04:26 PM   #1
Too Slow '90
Too Slow '90's Avatar
Power Booster/Oil Canister Interference
I'm working on tying everything together for the power front disc brake conversion on my '60 with a 235. I am using the Captain Fab bracket and one of the recommended boosters. The oil filter canister is in the way of mounting the booster. I didn't see this issue on any of the write ups but I don't see any other way it could go on.
I will have to relocate the oil filter canister. Does it matter where it's relocated? Thanks in advance.
Too Slow '90 is offline   Reply With Quote
Old 06-17-2024, 01:15 PM   #2
rideblue00
rideblue00's Avatar
Re: Power Booster/Oil Canister Interference
Pics?
rideblue00 is offline   Reply With Quote
Old 06-19-2024, 10:07 PM   #3
theastronaut
theastronaut's Avatar
Another option is to use a smaller bore master cylinder without the booster, and leave the brake pedal pushrod in the original manual brake hole for more leverage on the master cylinder. I have a front disc brake swap on my '66 with the original 6.25 to 1 pedal ratio and a 1" bore master cylinder with no booster and the brakes work great without excessive pedal effort. You could use a 15/16 or 7/8" master cylinder instead for even less pedal effort, but you don't want to make it too easy since you don't have ABS.
I don't really understand the point of adding a brake booster when half of the modifications that go along with adding a booster take away line pressure- altering the pedal ration from the stock 6.25:1 to around 4:1, and using a larger 1.125" master cylinder both take away line pressure that the booster is adding. It's better to just use a properly sized master cylinder and the original manual pedal ratio without a booster. It cleans up the look under the hood and the brakes are easier to modulate.
theastronaut is offline   Reply With Quote
