Old 06-29-2024, 07:32 PM   #1
hatzie
Moderator
hatzie's Avatar
What have you done with your trucks today
Hunting a water leak.
Front left floor is wet.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-30-2024, 07:11 AM   #2
K10-Kansas
K10-Kansas's Avatar
Re: What have you done with your trucks today
Fabricated a stepside hinge since my truck didn't have one when I bought it.
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
Old 07-10-2024, 03:52 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re charged the '03 Tahoe Battery.
Sprayed WD-40 on door catches. Hoping to chase a DOOR AJAR Gremlin.
'68OrangeSunshine is online now   Reply With Quote
Old 07-10-2024, 03:53 AM   #4
'68OrangeSunshine
A/C related?
Old 07-10-2024, 07:24 AM   #5
hatzie
Moderator
hatzie's Avatar
Originally Posted by '68OrangeSunshine View Post
A/C related?
I wish.
The water is showing up on the carpet along the LH sill.
There's no holes in the floor and there's no damp underneath the HVAC box.
There's no damp underneath the air vents in the back of the cab either but I replaced them. The seals were looking a little rough but there weren't any leaks.
Old 07-10-2024, 05:04 PM   #6
'68OrangeSunshine
I wish.
How about precipitation? Get much rain there? It rains so seldom in AZ that I don't consider it much. And Locals are very grateful when it does. This year has been dry for a monsoon season.
Does it smell of coolant?
And what year, make and model truck are we talking about?
Old 07-11-2024, 02:16 PM   #7
hatzie
Moderator
hatzie's Avatar
There's been so much rain this summer it smells like a swamp. It feels like Hotlanta in March to early April.
Usually by this time of year it's hot but dry with high fire hazard and the rain is lower until early Sept.
My pond that drops to almost nothing by late July is still full.
Old 07-12-2024, 01:22 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The '06 Silverado K2500HD that I gave my Dad some years ago, ended up back to me when he passed away back in February. It had been sitting for quite some time while he was fighting cancer. So it has a few things wrong, that need to be addressed.
The drivers side extended cab rear door latch is broke, and needs to be replaced. I also have to replace the vapor canister purge valve and/or the fuel tank pressure sensor, so the check engine light will go away (code P0446) hoping to get this done in the next week.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-12-2024, 03:01 PM   #9
'68OrangeSunshine
Sorry for your loss. Cancer killed my Dad too, but 40 years ago, now.
Old 07-21-2024, 07:13 PM   #10
SRU1436
Gary
Sorry for the loss of your dad.
SRU1436 is offline   Reply With Quote
Old 07-21-2024, 10:39 PM   #11
'68OrangeSunshine
Today I crimped a fresh Ring Terminal on the end of a ground strap going from the Firewall to the Hood of my '03 Tahoe. According to a schematic, this ground is the Radio Ground Plane, so my FM reception should improve.
Since it was adjacent, I also inspected and cleaned up [w/ a wire brush] the ground srtap end from the Block to the Firewall. It wasn't bad but it's good to keep up.
Thursday I was going to help a friend troubleshoot the dead headlights on his '16 Subaru Forester. But I couldn't find the special Fuse Pliers I ordered off Amazon. So we cracked the beers early.
I looked again today, but I had put them somewhere ''safe''.
[From me.]
Old 07-22-2024, 09:13 AM   #12
hatzie
Moderator
hatzie's Avatar
[From me.]
Barn Gremlins got them or they're hiding from you.
Get another one. The original will get jealous and show up. It's called tool Envy
Old 11-07-2024, 01:29 AM   #13
'68OrangeSunshine
No the Gremlins just put them in my briefcase, instead of the electrical tool bag. Sneaky Devils. Turned out my friend's Subaru had blown bulbs, like I suggested. He wouldn't let me pull a continuity check on his headlamps. Insisted they were new. Maybe they were, but still burned out. So he had the Dealer replace them. Hopefully under warranty.
Anyway, Today, I took the '03 'Hoe in to Discount Tire. The truck has a nasty shimmy/shudder above 60 MPH. I figured a balance and rotation would either eliminate that gripe or pinpoint it. Without moving it, the Tire Tech, showed me there was irregular wear on the Left Front, probably from bad alignment. That tire rated at 4 of 10. The other three were 6s. While rotating that tire to the rear, and getting an alignment at another shop would have been the No or Low Buck solution, I remembered I have a set of Cooper 235/75/R16 tires just sitting in the sunshine and gathering spiderwebs.
A couple of years ago, when gas was up to $5 a gallon, I decided to remove the 33x12.50x15 Falken meats from the GMC Jimmy, my only runner at the time. An old friend had taken off a set of aluminum rims from his new-to-him '99 Suburban. He thought they were too ''bling-ey''. He gave them to me. I got 2 pair of 2'' aluminum spacers and had them mounted on the Jimmy. They ran fine. My speedo was true, according to the GPS, They handled very well in city traffic.
But one rainy day I was on the freeway to see an old college buddy, some 60 miles way, and weird vibrations at speed scared me. I got towed home. First I pulled the aluminum rims and put the old 33x12.50x15s back on. Bad vibes continued. I put the GMC up on jackstands, and rotated the propshafts. My Transfer Case had accidently slipped into 4 HI. I put it in 2 WD and it was better. But a U-Joint was AFU. When I was under to R&R it, I saw the Carden/Lloyd constant speed assembly on the Front Prop Shaft was FUBAR. So my 4WD Jimmy is currently a 2WD. A new Front Prop Shaft runs $500. I ogled the Front Prop Shaft still on my dormant '67 K/10 Suburban, looks near identical, but if I extract any more parts from old White Fang, she'll never rise again.
The result was I parked 4 good, expensive tires behind the Suburban for a couple years.
Tonight, I loaded them on the back of the '68 C/10 Stepside. Tomorrow, I'll drop them off at Discount Tires and they can mount them on the 'Hoe.
The rims should fit fine, since a '99 Suburban is the same platform as the 2003 Tahoe.
I measured the current tires on the 'Hoe: they were 29.5'' high. They are 265/70/R17s. The diameter on the Cooper 235/75/R16s is about 29'' but it's hard to read when not mounted on a vehicle. [Coincidentally, the height of the 33x12.50x15s is also 29-1/2''.]
If the diameter is radically different, will I have to get anything reprogrammed?
Old 11-08-2024, 07:17 PM   #14
'68OrangeSunshine
I took my 2003 Tahoe to the shop [Brake Masters] today for an alignment. Cost $100, but it shouldn't wobble at freeway speed now.
My attempt at putting four 235/75/R16s on this truck was a bust.
Discount Tires refused to swap them out with four 265/70/R17s. They said the Drivers Front was irregularly worn from bad alignment, and strongly hinted I should buy a new one. They rated that one at ''4'' [out of 10, I guess] and the other three at ''6''.
The 235/75/R16s were mounted on some aluminum rims a friend kicked off of his '99 GMC K/15 Suburban [before the Yukon XL name change]. I had them on my '71 GMC Jimmy with 2'' adapters. When I heard irregular noises I took them off and went back to 33x12.50xR15 tires. But they are 2022 Cooper tires with very little wear.
I figured a 2003 C/15 Tahoe was about the same platform as the '99 Sub.
The tire expert at Discount said the set-back was different on the rims, and also the 235/75/R16 tires were rated at 1008, but the 265/70/R17s were rated at 1111. [What ever that was.] I still think they were trying to upsell me another tire.
The guy at Brake Masters said to go to another tire shop he recommended and they would probably put the Coopers on my Tahoe, since I'm not likely to be zooming around above 100 MPH, ever.
In the meantime, they put the ''4'' tire over on the Passenger side, so it'll even out the wear.
Old 11-10-2024, 08:50 AM   #15
S10Fan
Old Heap Driver
I finally got around to buffing and waxing my 99. I still need to paint the roof and hood. 4.3 V-6, 5-speed, 177k miles, spindles, hangers and shackles, 05 GMC wheels.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-13-2024, 03:24 PM   #16
GASoline71
GASoline71's Avatar
Got thrown a curveball this past weekend, as the ol' Silverado started making a wicked knocking/clacking sound from behind the engine. Sure as heck... cracked flex plate. So need to slide the transmission/transfer case back to get to it. Going to replace the rear main seal while I'm in there. Good times... LOL
Thanks to those of you that commented about my Dad.
Gary
Old 11-23-2024, 01:40 AM   #17
'68OrangeSunshine
Today I got 4 Cooper tires mounted on my '03 C/1500 Tahoe. They are 235/75/R16s on aluminum rims. The rims came off a Pal's '99 K/1500 GMC Suburban [just before the Yukon XL model name BS]. He didn't like them, [''Too Blingy''] and was gonna recycle them for the aluminum. I said I'd give him $20 each for them. He's been my friend for 30 years, so he just gave them to me.
I got 2'' wheel spacers to make them fit my '71 GMC Jimmy K/1500 and mounted the above 16'' tires on the old truck. They worked fine. Good handling. The speedo was even accurate for once -- as checked by GPS.
But I heard a noise and got paranoid that the spacers were coming loose.
So I put the 33x12.50x15 offroad tires back on. The noise turned out to be the front Prop Shaft eating itself up. I took that off so my K/1500 is a 2WD anyway.
The 2003 Tahoe had a bad shimmy above 60 MPH. It had not been aligned for years by the women POs.
I had it aligned. Better, but still funky over 70. The Front Right tire [265/70/R17] was cupped and shot. The other three were at about 60%. Discount Tire, where I got the 16'' Coopers, [back in 2022 when gas shot up to $5/Gallon] refused to mount the 2 y o tires on the '03. They cited load range issues, but I think they just wanted to sell me $200 worth of new rubber.
Today Western Tire mounted them for free, but with a $25 wheel balance charge. Cost another $40 for lug nuts. Still need 4 more. But being back on good tires feels good.
My speedo now reads 40 MPH while the GPS clocks 37. I may have to get the ECM reprogrammed for the new size.
Old 11-23-2024, 09:36 PM   #18
D.B
D.B's Avatar
I bought a steering wheel at the swap meet last weekend for $40 and installed it today on my 72 C20.
Darrell
1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck)
2000 S10 Xtreme (Black Magic) (My Drag Truck)
D.B is offline   Reply With Quote
Old 11-24-2024, 08:02 AM   #19
4u2nv
Attachment 2405711
Attachment 2405712
That's a nice match with the gauge insert for sure
4u2nv is offline   Reply With Quote
Old 11-26-2024, 09:17 PM   #20
'68OrangeSunshine
I put in a fresh Air Filter on my 4.8L '03 Tahoe.. Old one wasn't too evil, but I don't trust the PO.
Old 11-30-2024, 10:02 PM   #21
'68OrangeSunshine
Today, I put a Quick Disconnect terminal on the negative battery pole. I had been using new terminal bolts and a 5/16'' speed wrench. Last week I overtorqued it in the dark. Surprisingly the threads on the Bolt were stripped or galded, but not the threads on the battery.
I couldn't find a Side Terminal-specific QD unit at my local FLAPS, so I cobbled one together for the Top Post type. A Top Post terminal went in the Negative Terminal bolt hole. A short end [~6''] of an old Side terminal negative connector was joined to the OEM Neg Connector end with some star washers and a nut and bolt, then taped over with 3M electric tape. The end of the cable was stripped back 3/4'' so the knob connector assembly could be attached.
This way I didn't have to cut the OEM Negative Connector. It's completely reversible.
I disconnect the battery every night because there's a hidden drain on the 2003 Tahoe's electrical system. Leaving it on will flatten the battery.
Old 01-09-2025, 10:26 PM   #22
'68OrangeSunshine
Can anyone tell me the proper Torque Rating for Lug Nuts on my '03 Tahoe, C/1500?
They are 14mm/1.5.
When I went to a set of aftermarket rims and tires, I could only buy lugnuts in 20 piece sets. Not even the manufacturer, Dorman, could sell me only four. Wasn't about to buy another bunch of 20, just to have 16 loose nuts for a slingshot war.
Anyway, I got a set of 4 from the Lugnut Guys, but they are 5-splines, not the six-spline like the Dormans. So I guess they'll function as Lock Nuts, even though the Dormans already need an adapter to use the lug wrench.
I probably could have gone on with 5 out of 6 lugnuts per wheel til Doomsday, but it made me uneasy.
Old 01-10-2025, 09:34 PM   #23
hatzie
Moderator
hatzie's Avatar
The 2003 Tahoe owners manual claims the torque specification is 140 ft lb
https://www.chevrolet.com/support/ve...et&model=Tahoe
Old 01-11-2025, 12:31 AM   #24
'68OrangeSunshine
Thanks.
Old 11-09-2025, 12:34 AM   #25
'68OrangeSunshine
Yesterday I located an 8 Button Switch for the Drivers Door Panel.
Saw it on Craigslist. Guy [junkyard] was selling clean 03 - 06 Chevy Door panels. Complete with switches speakers and lights, Pair for $260.
Curious, I went down to South Tucson to check it out. $260 was very high.
I told the guy I only needed the 8 Button Switch. He pulled one off a door, and it cost me only $35. I still have to clean it up. Open it and clean the contacts and printed circuit with Q-tips and alcohol, but it's a start.
